FixYa.com
Tags:
Garmin Forerunner 305 GPS Receiver
Garmin 305 not communicating with Training Center (by 16 users)
posted by Mimir on May 05, 2008
When I plug my 305 into the computer, it opens the window for Training Center, and then a message appears: There was a problem while communicating with your device. Please make sure it is connected to the computer, then try again.
It just started this after 15 months without a problem. I also sometimes get this message: The remote could not be resolved or something to that effect. Thanks.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
15 Other Users Have The Same Problem
Comment by wood13, posted on Sep 04, 2008
I'm having the same problem. I ran my best run and I can;t record it in the trainer. Just started happening. any suggestions?
Comment by lmkay, posted on Aug 27, 2008
I have the same problem. I've deleted everything on the watch and it connects for the first time but doesn't transfer data. This is so frustrating. This has worked for a couple years with out this problem... suddenly boom.
Comment by Guest, posted on Aug 13, 2008
I could solve this problem when I removed/erased all my programmed routes from my Garmin Edge 305. As soon as I transfer my defined routes from the TrainingsCenter to the device, I get the same communication error again.
Comment by Guest, posted on Jul 30, 2008
I've had the same conflict problem. I copied the error message and sent to Garmin Tech support. They were very helpful and have suggested that the problem could be that I have an out-of-date Operating System installed on my unit and an old version of Garmin Training Centre on my PC. I've just recently installed the latest version of the OS for the 305. It's still too early to tell if this has solved the problem.
I have also from time to time had a complete TC meltdown which resulted in all the maps for my run traces being lost. I've also had some GPS inaccuracy issues, e.g. my unit has recently measured a certified accurate 10km race course at 250m !! longer on an open landscape with no possibility of interference from high buildings or trees. Not happy. Maybe I'm expecting too much from a small hand-held GPS unit?
Comment by Guest, posted on Jul 27, 2008
same
Best Solution
posted on Jul 05, 2008
FixYa! (100)
Fix-Fox
Rank:Apprentice Apprentice
Rating: 98%, 8 votes
I am new to the Garmin Edge 305, and started getting this problem yesterday. Indeed, yesterday it was the first time that I downloaded Courses.
I followed the Guest solution, deleted all new courses from my Garmin, and it now WORKs!!!!
Uploading my courses back again to the Garmin made the problem return back. I need some more work to identify the bad course.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jul 01, 2008
FixYa! (100)
Guest
Guest
Rating: 0%, 0 votes
delete new courses you uploaded ...some have bad data ponts that cause the error
Solution #3
Not Rated (0)
marcantels
Rating: 0%, 0 votes
I have had the same issue now with my second 305. I returned my first thinking it was a defective system and reordered another one. I used it about 3 runs and got the error again. I got really upset (because the watch is great when it works). I deleted all the routes on the Training Center and the watch of courses I ran. I uploaded my latest data from the watch and the error no longer appeared and then I just sent the old routes back to the watch. Problem solved. Hope it works for you too.
Can you Help with these GPS Devices problems?
no power
Pace Alerts not updating from...
Hi, I edited my pace alerts on... Answer This...
Forerunner 305- didn't load in...
Multi sport training on the... Answer This...
Garmin 305 battery replacement
Hi Phil... I am interested in... Answer This...
opening forerunner 305
my two year old Garmin 305 shut... Answer This...
15 Other Users Have The Same Problem - Continued
Comment by kim74, posted on Jul 04, 2008
I have the same problem with my garmin edge 305. Since I updated the firmware and the software, I have this communication error. Before it worked fine for a while. I uninstalled the drivers and the software and after reinstallation the problem was still there. I even installed everything on a Mac.... but still the same. After each firmware update it works for one, two times and then the error appears again.
I got the same problem with the Garmin Edge 305, after having updated the software and the firmware. Before it worked for a couple of weeks but since I did the update nothing works anymore. I uninstalled all drivers, went back to the old firmware... nothing changed. I even tried to install everything on a Mac.... the same stuff.... the wired thing is that after updating the firmware the communication works for one, two times... and then the same story again
Comment by SSminnow, posted on Jun 27, 2008
This same problem started about two weeks ago. I can get my data uploaded to Motionbased and Training Peaks. What is the solution?
Comment by nick868, posted on Jun 21, 2008
I get exactly the same problem. It worked fine for the first couple of weeks, and now it says there is an error communicating with the device. I've tried uninstalling and reinstalling the software but no joy.
Comment by ironman bob, posted on Jun 10, 2008
garmin forerunner 305 wont communte with computer at least 30 seconds to turn on the watch device to just start the unit it was 5 months old when i started having promblems can anyone help me please !
Comment by woodgie, posted on May 25, 2008
Mine comes up with a bunch of gibberish and asks you to copy the eroror to a clip board and e-mail it to tech support. Well I did that twice and never heard back anything. I also called twice but the reponse time is very slow - over 15 minutes. When I finally got someone they said they would have to transfer me to someone who handles software issues and it would be another 20 minute wait. Geezzz. Can anybody help? Even when I reinstalled I still got the error. I am using Windows XP. JB
Comment by richardgario, posted on May 17, 2008
When connecting device to pc nothing happens.
When I open TC and try to receive from device I get the 'unable to communicate' problem.
I have not updated software, using Vista and has been working ok for last 3 months.
Comment by OneBadApple, posted on May 16, 2008
I'm getting the same error message. It worked fine the first 2 times, but when I went to upload my data last night I got the message. I have tried everything I can think, even installing the software on another computer and still have the same issue.
Comment by bikerpaul, posted on May 15, 2008
I have the Edge 305 whihc has the same error. GPS is new and worked the first three times I uploaded then stopped. It does however upload data to motionbased.com
Comment by Guest, posted on May 12, 2008
I couldn't get the Garmin 305 to turn on. I got that fixed but now I can't transfer the info to my computer. It says "an error has occured..."
Repair Service
Find GPS Device Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
