Samsung CRT model CT25MB no power at all
My TV was on and suddenly went off, can´t turn it back on, the outlet is fine and the fuse inside is not burnt.
Type # A51QDXDX992X
Thank you,
Gregory
costarica@attorneykearney.com
  • Anonymous Jun 30, 2008
    samsung 32 inch tv-model TX-s3082WH. Two years old.Cost was $900. Turned off. Came back and turned on a couple of hours later and wouldn't turn on. No red light indicating power on. Tried different outlet. Used remote. Looked at the trouble shooting guide, none of these things worked.
    Problem Solver:
  • 9 Answers
Any of several things could have happened, but your power supply or a something inline to or from the power supply has quit. A good shop can tell you or give you an essimate for a fair fee. THe fes differ from shop to shop. Cheaper doesn't always mean less quality, just ask some friends or coworkers if they know of a good repair shop.
Posted on May 06, 2008
Samsung startup problem
serial number on 6.17.8.1
Sep 21, 2013 | Televison & Video
We have a Sony KV-35V36 TV. Will watching TV and the power just went off. We get no power all all anymore. How do you ge the the fuse on this TV.
The fuse is inside the chassis and likely soldered. Unplug the TV, press and hold the power button for 30 seconds, repeat. Plug it back in and see if that has reset it.
Is the outlet good, or did the power outage trip the breaker?
Apr 22, 2011 | Sony KV-35V36 35" TV
32' lcd hdtv tv lost power all of sudden bought tv on 2/22/09 outlet works fine
if the tv al of a sudden stops working. the first thing you should inspect is the fuse. more than likelly it blew out on ya and replace with same fuse.
Nov 22, 2010 | Emerson Televison & Video
I have a trutech undercounter mount DVD/TV combo. It was working fine, and all of a sudden it turned off and will not come back on. We checked the outlet and it is fine.
Unplug the power cord from wall outlet and take the unit apart follow the power cord inside the unit it goes to the fuse. Check the fuse most of the time the fuse is bad.
Jul 22, 2009 | TruTech LMD-5702RT Portable DVD Player
TV was playing then went out and will not come on.
could be the fuse is inside of set just fallow the yellow brick road the power cord it is a glass looking tube with silver ends on it Be sure to unplug tv befor you take the back off of it if fuse is ok then you have other problems in set.
Mar 05, 2009 | Fisher PC-25S80 25" TV
No power
Check the power cable and test a different power outlet.
If you are in UK also check the fuse inside the TV power plug.
If you do not find anything wrong , then either the fuse on power board, or one of the power board capacitors had blown, and the TV must be disassembled and tested to fix the problem.
Feb 18, 2009 | Televison & Video
Screen went black and never ressurected
It is repairable.Open the TV and check the fuse and then the flyback transformer for any loose soldering. check for obvious burnt transisters, resistors, capacitors etc. the flyback is the component that has a wire to the picture screen on the inside of the TV. Be careful. Capacitors and picture tubes retain high current. If you don't know what your doing take it for repair.
Dec 29, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Panasonic HDTV /no power
the loss of power was do to a blown fuse. could not access it through the small opening near where the power cord went in at the back of set.. carefully took the back of just far enough to access the fuse and replaced it. Working fine.
Nov 25, 2008 | Panasonic CT-36HL43 36" TV
TV no image no sound
That happened to my parents tv, I vacuumed out the back of the television to get out all the dust and it came back on. Hope this helps.
Oct 24, 2007 | Samsung TX-R2735 27" TV
Samsung Flat Screen Won't turn On
yea take your tv to a tech tv has a problem in the power supply there is 10mf cap in the power supply that likes to go bad replace it if that model does not have it check regulator and the microchip.however your problem lies in the powerand related circuit.good luck
Apr 02, 2007 | Samsung TXN3275HF 32" TV
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Electro Med Services...
