Question about Panasonic Lumix DMC-FZ18 Digital Camera
Lumix fz 18 zoom is stuck wont take pictures - Panasonic Lumix DMC-FZ18 Digital Camera
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 25, 2010
Where can i get a manual for a lumix dmc fz 18
The manual is available from the Panasonic website. Here is the link. You will need a PDF reader like Adobe Acrobat of Foxit. http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Digital-Cameras/Lumix-Digital-Cameras/model.DMC-FZ18K
Jul 08, 2011 | Cameras
I have just purchased a canon eos 600 digital camera.efs 18-135mm lens All excited.\r\nBought it home and on autofocus can't zoom the bird on the dam up very close? I can look through my point and...
Your not doing anything wrong, your Panasonic probably is using digital zoom (which is basically just cropping the picture imitating zoom). Your eyes sees similar to a 50mm lens so your 135mm lens is less then 3x zoom.
Do not be discouraged you will soon learn your cameras strengths and weakness.
Good Luck
Jun 15, 2011 | Canon EOS 60D Digital Camera with 18-200mm...
Black dot on Lumix Fz18 screen
It is either a faulty pixel in the CCD or a piece of grit in the lens. has it moved at all.
If it moves it's a piece of grit.
Will require servicing, they can either remove the grit or remap the pixels in the CCD.
Cheers.
Sep 21, 2009 | Panasonic Lumix DMC-FZ18 Digital Camera
Lumix fz-20 panasonic has message please turn camera off and then on again
Does the camera start up as normal? Is the message intermittent? When does the message appear? (i.e. when zooming, when taking a picture, etc)
Unfortunately this message doesn't have one clear meaning. Or rather, it does - it says "something is wrong with the camera". From what I noticed with Lumix cameras, lens is usually the reason for this. (e.g. if there is a bit of dirt stuck in lens gears you would end up with the same message). If it's dirt in the lens, the solution isn't easy, you either need to have it repaired at panasonic service, get a replacement lens from an otherwise defective donor camera from e.g. ebay and replace it, or alternatively dismantle and clean the lens yourself if you're brave.
On one occassion I saw this message appear due to a problem with flash circuit. Disabling the flash sorted it out.
I would recommend first trying to disable any fancy options in the menu (e.g. flash, image stabiliser, macro, etc) and resetting the settings to factory state via the menu.
Good luck,
Raf
Nov 18, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
Wont take pictures
First of all you should take a look to the little "guide" that I posted to the "stuck lenses" problem for LUMIX. But in your case the camera is very different, so: first thing you should do is (hoping that its just a simple stuck problem, try moving the zoom gently doing circular movements and then more gently in and out with the camera on. VERY GENTLY!!! if that does not help, try disassembling the camera, the structure is similar to the one I described in the text, although its parts are smaller and more delicate. Every LUMIX camera cheaper that $ 1500 seems to have this kind of problems... REMEMBER TO BE REALLY CAREFUL or your zoom will say good bye.
Feb 27, 2008 | Panasonic Lumix DMC-LZ7 Digital Camera
If you zoom to less than 12x
The macro setting on the fz series allows you to get within a couple of centimeters of the subject and obtain focus. That is pretty close. That is too close. The camera will throw a shadow. You need some room. Most high zoom cameras (notably Olympus) have macro capabilty throughout the zoom which not only increases the magnification but also allows you (requires you) to put some distance between the lens and the subject. The panasonic fz series is different. They do not have macroability at zooms greater than 2x-3x. Beyond that there is no increase in magnification. Why? I dont know. Maybe this feature was designed on a Monday. Fortunately this can all be rectified with the use of a closeup lens. Now the fz series will react like most other high zoom cameras and do it well. The Olympus b-macro is such a lens. There are many others
Sep 06, 2005 | Panasonic Lumix DMC-FZ10 Digital Camera
Low light situation
Where the Panasonic FZ-20 does very well, is with conditions where you need a long zoom under low light. Most lenses will lose light as they are zoomed out. The Leica lens in the FZ-20 does not lose light when zoomed. No matter which camera you are using, you will have to use the manual controls for the best results. So learning about exposure and how to use it, is necessary.
Sep 04, 2005 | Panasonic Lumix DMC-FZ20 Digital Camera
Panasonic Lumix DMC-FZ18 Digital Camera Logo
94 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
