Question about HP OfficeJet 7130 All-In-One Printer
Out of Ink and can't change my cartridge
Hi, the print carriage is supposed to move to the center of the unit when the access door opens and this one will not. It just stays there on the right. What can I do?
    Problem Solver:
  • 9 Answers
Vandybaby, you could have several issues here:
1. Your maintenance door sensor is not working/jammed, and the printer does not recognize the door is open- Verify that you are getting the flashing exclamation mark and message that the door is open, and that it goes off when closed.
2. There is a carriage validation sensor that was often a problem with the 7100 series, becoming glued down in drying ink when it was supposed to retract and allow the carriage to pass by. On this one, the question basically is "When the carriage doesn't come out of the service station "parking" area, is it trying to? Are you hearing or seeing the carriage trying to leave the service station, catching on or hitting something then pulling back, or does it just sit idle and never attempts to move.
Answering this, particularly #2, will be of great help in narrowing down your problem. Right now it could be anything from simply cleaning the encoder strip, to being as costly as needing a new logic board.
If you can provide a little more info, it will greatly speed up getting you the correct information in diagnosis. For the most part, this is likely to be very simple, probably only needing cleaning or realignment of a part to get you running again.
David
FatrCat
Posted on May 04, 2009
Print head jam
Check the LCD on your printer control panel or the status monitor on your computer for an error message. If there is an error message, follow the instructions to clear it.
If there is no error message, or if the problem continues:
  1. Open the access door.
  2. Disconnect the power adapter from the back of the printer.
  3. CAUTION: Do not use force on the printhead carriage to move it. Gently move the printhead carriage from side to side to see that it moves freely and there are no obstructions.
  4. Remove any obstructions that may prevent the printhead carriage and ink cartridges from moving to the center position.
  5. Close the access door.
  6. Connect the power adapter to the printer.
  7. Remove the ink cartridges from the printhead.
  8. Verify that the labels on the ink cartridges are intact, and that the cartridges are not damaged.
  9. firmly until you hear it click into position.
  10. Insert the color ink cartridge into the printhead, then press down firmly until you hear it click into position.
  11. Close the printer access door.
  12. Press OK to clear the error.
  13. Make a print.
May 06, 2014 | Kodak Office Hero 6.1
I am looking for a color access door for a print carriage on an hp psc2210 all in one printer. (C8654A)
  1. If you are putting in a new cartridge, make sure to remove the tape.
  2. Turn on the unit, then open the print carriage access door. The print carriage moves to the center of the unit.
  3. Fit the cartridge into the proper carriage.
    • The carriage with the gray latch is for the black ink cartridge (HP 56), or the optional photo cartridge (HP 58).
    • The carriage with the blue latch is for the tri-color cartridge (HP 57).
    Slide the cartridge into the carriage at a slight angle, as shown in the illustration above. When the cartridge is fully inserted into the carriage, rock it upright.
  4. Hold the hinged flap of the latch out while lowering the latch.
  5. When the latch is fully lowered, release the hinged flap. It should catch under the tabs on the carriage, as shown in the illustration.
  6. Close the cartridge access door.
  7. The LCD display may indicate that the cartridges need to be aligned. Press Enter on the front panel. You may discard the alignment page that prints.
Remove cartridges
  1. Turn on the unit, then open the print carriage access door. The print carriage moves to the center of the unit.
  2. Press down lightly on the top of each ink cartridge latch and pull the lower section of the latch out to release the cartridge.
  3. Pull the cartridge out of the print carriage and relatch the empty print carriage. The print carriage may move to the right automatically, and if the latch is up, it could be damaged.
Aug 23, 2011 | HP PSC 2210 All-In-One InkJet Printer
How do i change the cartridges of hp psc 1215
1. Turn on the unit, then open the print cartridge access door by lowering the handle. -- The print carriage moves to the center of the unit.ionstorm_0.jpg
2. After the carriage stops moving, push down on the print cartridge to release it, and then toward you out of its slot.
3. Remove the new print cartridge from its packaging and, being careful to touch only the bright pink plastic tab, gently remove the plastic tape to uncover the ink nozzles.
Caution! Do not touch the copper contacts or ink nozzles.
Once you have removed the plastic tape, install the print cartridge immediately to prevent the ink from drying in the nozzles.
4. Push the new print cartridge into the appropriate slot at a slight angle until it clicks into place.
Caution!
Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle.
The tri-color print cartridge goes on the left and the black cartridge goes on the right.
5. Close the print cartridge access door.
May 06, 2011 | HP PSC 1215 All-In-One InkJet Printer
Hp f30 has new ink cartidge and paper but ink button still flashing and not printing alignment page.
Here are some steps that can help you resolve the problem.
Close the cartridge access door securely, if cartridge access door is open even slightly, the print cartridge light will blink.
1. Open the cartridge access door, once carriage moves to the center of the printer.
2. Check inside the printer and make sure that there are no obstructions that are preventing the cartridge access door from closing , if there's any obstruction remove it.
3. Close the cartridge access door completely.
Do the Print Self Test
Press and hold the Cancel button, and then press the Start Copy Color button
Release both buttons at the same time
If the issue persists, Make sure that the cartridges are installed
2. Wait until the carriage is idle and silent
3. Check the cartridge slots in the carriage to make sure that the cartridges are installed.
4. Try to reinstall it again.
5. Lightly press down on a cartridge to release it, and then pull the cartridge toward you out of its slot.
6. Check the nozzles on the cartridges to see if the protective tape is still attached
Note: Do not touch the copper-colored contacts or ink nozzles
7. Hold the cartridge by its sides
8. Slide the cartridge into its designated slot at a slightly upward angle.
9. Press the cartridge inward until it snaps into place
10.Close the cartridge access door
If still the problem persist contact HP for the service.
I hope this will be able to help you.
Thank you for choosing Fixya
Mar 10, 2011 | HP DeskJet F380 All-In-One Printer
How to change ink cart. in hp psc 2210 all in one printer
  1. Turn on the unit, then open the print cartridge access door. The print carriage moves to the center of the unit. Never attempt to move the carriage by hand.
  2. Press down lightly on the top of the ink cartridge latch and pull the lower section of the latch out to release the cartridge.
  3. Pull the cartridge out of its holder.
  4. Carefully remove the protective tape from the new cartridge.
  5. Reinsert the new cartridge into the carriage at a slight angle. When the cartridge is fully inserted into the carriage, rock it upright.
  6. Hold the hinged flap of the latch out while lowering the latch.
  7. When the latch is fully lowered release the hinged flap. It should catch under the tabs on carriage.
  8. Close the cartridge access door.
  9. The LCD display may indicate the cartridges need to be aligned. Load paper and press "Enter" on the front panel.Discard the alignment pages that print.
Feb 01, 2011 | Office Equipment & Supplies
How too change ink
Follow these procedures to help you get access the cartridge. This is taken from the online manual of Fixya. http://www.fixya.com/support/p378621-hp_psc_2210_all_in_one_inkjet_printer/manual-3472/page-58
1. Turn on the unit, then open the print-carriage access door by lifting the
handle until the door locks into place. The print carriage moves to the center of the unit.
2.
After the carriage stops moving, lift the latch to release the print cartridge, then pull it toward you out of its slot.
3.
If you are removing the black print cartridge in order to install the photo print cartridge, store it in the print cartridge protector.
. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape.
5. Push the new print cartridge into the appropriate slot until it clicks into place. The tri-color print cartridge goes on the left and the black or photo print cartridge goes on the right.
6.
Pull the end of the latch toward you, press down until it stops, and then release. Make sure the latch catches below the bottom tabs.
7.
Close the print-carriage access door.
Please rate this answer. Thanks for using Fixya.
Aug 15, 2010 | HP PSC 2210 All-In-One InkJet Printer
I have an hp officejet 7110 all-in-one and I've been getting a message saying that supply expired on the black cartridge. i replace it and it still won't let me print. what else could be wrong
Hello there:
This problem is usually due to a print head that needs to be replaced
I have provided the information that you will need ok
best regards mike
This document provides information on how to replace a printhead or ink cartridge.A printhead may need replacing when print quality issues cannot be resolved by cleaning the printheads or a front-panel display message indicates a printhead needs to be replaced.An ink cartridge needs replacing when a front-panel display message indicates either:
  • Low ink levels
  • Ink cartridge approaching expiration date
CAUTION: Never remove an ink cartridge and a printhead at the same time. Use the table below to identify the correct ink cartridge part number: Ink cartridge Part number HP 14 black print cartridge C5011A HP 14 tri-color print cartridge C5010A Use the table below to identify the correct printhead part number: Printhead Part number HP 14 black printhead C4920A HP 14 cyan printhead C4921A HP 14 magenta printhead C4922A HP 14 yellow printhead C4923A Replacing the ink cartridges Follow the instructions below to replace the ink cartridges:
  1. Turn on the unit, and open the print-carriage access door by lifting the handle until the door locks into place. Figure 1: Opening the access doorc00064456.jpg
  2. The print carriage will move to the center of the unit.After the print carriage stops, remove the ink cartridge by pressing the gray release button, then lifting the cartridge up and out of its slot. Figure 2: Removing the ink cartridgec00064457.jpg
  3. Remove the new ink cartridge from its packaging and, being careful to touch only the black plastic, remove the tape. Figure 3: Removing the tapec00064458.jpg
  4. With the ink cartridge label face-up, push the new ink cartridge firmly down into the appropriate slot until it clicks into place.The color ink cartridge inserts into the right-hand slot as indicated by the rainbow colored oval. Figure 4: Inserting the new cartridgec00064459.jpg
  5. Close the print carriage access door. CAUTION: If the ink cartridge is removed before a replacement is available, close the print carriage access door and replace the ink cartridge within 24 hours.
Identifying parts of the printheads Use the table below to identify the parts:
  1. Printhead handle
  2. Printhead tower
  3. Copper contacts
  4. Plastic tape
  5. Ink nozzles
c00064460.jpg Do not touch:
  • Copper contacts
  • Ink nozzles
  • Printhead tower
Jan 24, 2010 | HP OfficeJet 7110 All-In-One Thermal...
How do i change ink?
If iam not wrong you want to replace the Ink Cartridge. Please follow the below mentioned instruction.
Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access doorc00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridgec00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tapec00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridgec00034769.jpg
  5. Close the print-carriage access door.
Back to top Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Regards,
Shrey
Oct 08, 2009 | HP Officejet 5510 All-In-One Thermal...
How to change a cartridge on c4345
Installing new cartridge:
Remove cartridges:
Nov 26, 2008 | HP Office Equipment & Supplies
Paper jam?
Check Paper light flashes but there isn't a paper related problem The check paper light may also flash if there are other problems. Verify the following conditions:
  • Verify that the print cartridge door is closed.
  • The print carriage may be jammed, follow these steps to correct the problem:
    1. Open the print cartridge access door. If the print carriage can move, it should move to center. If the print carriage stays all the way left, unplug the power cord and then plug it back in. This will reset the unit and may allow the print carriage to move from the left.
    2. Disconnect the power cord from the all-in-one.
    3. Remove both print cartridges.
    4. Move the print carriage left and right slightly to verify that the print carriage will move freely. If the print carriage will not move freely, check for obstructions.
    6. Plug the power cord back in.
    7. After the all-in-one initializes, the print cartridge light will flash. Open the access door and install the print cartridges.
    8. Close the print cartridge access door. If the problem returns, remove the print cartridges and wipe the electrical contacts before reinstalling them.
  • Try to make a copy. If the all-in-one pulls in paper but cannot make a copy, there may be a problem with the scanner mechanism. Contact HP for assistance.
Nov 01, 2007 | HP PSC 1410 All-In-One InkJet Printer
76 people viewed this question
Ben Johnson
