Question about Fantom Vacums FM741 Twister Bagless Upright Vacuum
Lost the bottom of dust canister for our Fantom FM 741 B vacuum
SOURCE: Fantom Canister Vacuum parts
http://geeksquad.fixya.com/ThreadView.aspx?prdid=12055&thid=723654
Posted by jaybird73 on Jun 30, 2008
Hi, Don. I'm in need of a part for my Fantom Canister. It's a little difficult for me to describe but here goes...the part is the small metal "pins" that are found in the connection between the hose and the motorized floor attachment. There are normally 2 found in that area, they are about an inch long and I guess they pass the electricity between the hose and attachment. Any help is appreciated.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sound so me that it could be a lower wand with the pins in the end or the part of the power nozzle and the part that the lower wand fits into is called the gooseneck and that can be replaced as well. If it is part of the hose then you may have to replace the hose and that could be expensive or over $100.00 or more, as an estimate. The best place to get the information is the owner’s manual under trouble shooting or to cal the Fantom factory of which I will provide for you @ the bottom; or your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.fantom.com/ Customer Tech Support 1-800-798-7398
Hours are Monday thru Saturday from 9:00 AM to 6:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 03, 2008
defrankond
  • 65 Answers
SOURCE: fantom fury vacuum
HOW DO I CHANGE THE BELT ON THE FANTOM® THUNDER® AND FURY®? a.gif fantombeltchange1.jpg
  1. Unplug the machine.
  2. From the front of the machine, remove the collection bin.
  3. Facing the back of your vacuum, remove each of the Philips head screws located above each of the rear wheels. (Figure 1)
  4. To remove the base cover, place your thumbs in the two screw holes in the back of the machine. Push forward and up on the screw holes to disengage the 3 cover locking tabs. Put the cover off to one side, and go to the front of the machine. (Figure 2)
  5. Check the drive arm for any black streaks which indicate residual rubber from the last belt. The drive arm is located on the right side of the motor. The easiest way to remove any residual rubber is with some nail polish remover on a rag or with steel wool.
  6. To attach a new belt, remove the brush from the base of the machine by pulling up straight up with two hands.
  7. Take the new belt and hook it over the steel drive arm. Pull back on the belt slightly, to create some tension.
  8. Put the brush inside the belt loop so that the track for the belt is aligned with the belt itself.
  9. Replace the brush by aligning the metal end so the points face downward. (Figure 3)
  10. Rotate the brush by hand to check that the belt is running freely and easily in its designated space between the bristle.
  11. Replace the cover by placing the nose in first. Once in place fasten with the two cover screws and then replace the collection bin.
Posted on Nov 30, 2008
SOURCE: Tube to Fantom Thunder canister blocked
I cut a strip of window screen about 1 inch wide and 12 inches long and slid it up the tube from the back of the vacuum. The screen edges grabbed the gunk and as I pulled the screen strip out from the tube the gunk came with it, clearing the blockage.
Posted on May 28, 2009
  • 58 Answers
SOURCE: Kenmore central vacuum has great suction however
Is it a bagless/ filterless system? if so the unfiltered air goes through the motor and is ehausted out. All of the older systems from kenmore i have seen worked like this and must be ehausted outside. I will say that this is a terrable design because the dust going through the motor is **** on it. I would replace the entire tank with a bagged or at least filtered system. Nutone or Hayden would be my first choice. You can always vent it outside to help, but that isn't going to make your motor last.
Posted on Jul 26, 2009
  • 4 Answers
SOURCE: My fantom vacuum stopped sucking stuff up
Most likely there is a clog, either in the 'knuckle' between the power head and the wand, or in the connection where the hose comes into the canister. In either case, unplug the hose and you should plainly see it.
Posted on Oct 25, 2009
Euro-Pro Fantom FC-251 Canister Vacuum; Bought one of these 'gently used' at an auction. Would like a user manual if available.
You can download the manual by following the instructions on the following link. I used the security code to download it.
http://safemanuals.com/314159.php?k=4789186c8ac87e31888cf7e7294a3bd7&ID=347344&q=FANTOM FALCON FC251
Jan 08, 2011 | Euro-Pro Fantom FC-251 Canister Vacuum
I lost the inner filter that is inside the big filter of the fantom vacuum. What is that part called. the vacuum model # is FM741H
if you have lost it, you really should try EBAY, as for what it is called, even I with my exerience dont remember what exactly it was called. However, you will not find a new one now because that model has not been made since 1999.
Good luck.
Nov 15, 2010 | Fantom Vacums Lighting Canister Vacuum
Looking for the wand for the fantom lightin canister vacum, anybody know where I can find one.
they have gone out of business so I would check on craigs list and used vacuum stores.
Oct 07, 2010 | Fantom Vacums Lighting Canister Vacuum
Cant find one
Hello. You can call the Fantom company directly at 800-798-7395. Or use their website http://www.fantom.com/fantom/default.aspx
please rate my answer as very helpful. thanks. Joe800-800----
Apr 21, 2010 | Fantom Vacums Lighting Canister Vacuum
Where to purchase Fantom Vacuum parts? Not filters, belts, bulbs
I am sorry to inform you but fantom is out of bussiness and the parts are no longer widely available. If anyone has them it would be the guy i am refering you to.
ask for joe
302-698-2133
I am not sure of his hours but take into consideration he is on the east coast.
Apr 13, 2009 | Vacuums
Go Ahead. Use Us.
Jun 30, 2008 | Fantom Vacums Lighting Canister Vacuum
Fantom fury vacuums
Most power heads have some screws from the bottom to take out, the the top comes off, then you can get to the belt.
Feb 07, 2008 | Fantom Vacums Lighting Canister Vacuum
Fantom Canister
It sounds like you have a hose problem. You should be aware that the Fantom company went bankrupt many years ago. I know that the Fantom name was bought by another company and there may be Chinese units sold under that name, but service and parts availability is an issue. There may be an issue with the power delivery to the powerhead. This is through the hose, from the canister connection and down the wand assy. You should check the continuity from the canister down to the powerhead.
Dec 12, 2007 | Fantom Vacums Lighting Canister Vacuum
Fantom Vacums FM741 Twister Bagless Upright Vacuum Logo
Top Fantom Vacums Vacuums Experts
woodzowl307
ray gallant
Are you a Fantom Vacums Vacuum Expert? Answer questions, earn points and help others
