Question about Garmin GPSMAP 176C GPS Receiver
Can you read a 16 MB data card like you can a SD card?...I've got a Garmin USB 2.0 data card programmer, but I can only upload from Mapsource and it won't accept maps...Is there any way to copy a gmapsupp.img file onto the data card....I've got a 176c and coonect through a series <>USB converter...I can't seem to find a way to read the file either on my garmin 176c or the data card itself using the USB 2.0 data card programmer
  • robmacriner Aug 25, 2010
    Thanks for your help and very quick response...I was aware of how to load a gmapsupp.img onto a SD card...The problem I was having was when I was using a garmin 16mb data card on a USB 2.0 data cd programmer. ....I wasn't able to actually get to the gmapsupp.img on that data card to replace it. I was hoping like with a SD card that I could somehow open the data card like I can open a SD card...but it doesn't seem possible. The Mapsource program will see the data card programmer and alow me to load waypoints etc to it using mapsource....but I'm not able to load maps to the data card...Do you know a way that I can read the data card like I can read an SD card?....Thanks Rob
  • 17,970 Answers
If you plug the microSD card into a card reader, Garmin’s MapSource software will recognize the card reader as a legitimate destination for uploading, and allow you to send mapsets to the card at a speed limited only by the USB 2.0 port and the read/write speed of the microSD card. In my case, using such a card reader to upload data cuts the total time, including indexing and creating the map set, from 50 minutes down to less than 15 minutes – nice!
But once you’ve created and uploaded such a mapset, and you want to use it again in the future, there’s an even faster way to get it onto your microSD card than using MapSource. The microSD card will show up as a removable drive in My Computer in Windows; open this drive and you’ll see one folder called “garmin”. Open that folder, and it will contain a single file called “gmapsupp.img”; this is the file that contains all of the combined map data that’s been uploaded. You can copy this file to your hard drive, and save it for future use. The next time you want to use this map set, just open up that “garmin” folder again on your microSD card, delete the old gmapsupp.img file, and copy the gmapsupp.img map set file you want to use into the “garmin” folder. When you put that microSD card into your Garmin and turn it on, it will take a few seconds for it to index the data, but then you’ll be ready to use that map set data. Copying over the gmapsupp.img file I created above from my hard drive to the microSD card took only about 4 minutes, because there was no need to run MapSource to index and assemble the map set. Double nice!
But you can also use this capability to increase the total number of maps stored on your microSD card to more than the 2025 map limit, although you’ll still only have access to a max of 2025 at any one time. First, break up the maps into multiple sets, each with less than 2025 maps. Upload one set to the microSD card, then open up the microSD card and change that mapset’s name to something else other than gmapsupp.img. Upload another set, and change its name to something else as well. Keep doing this until you run out of mapsets, or out of space on the microSD card. To enable your Garmin to use and display and of those mapsets, change the name of the mapset you want to use to gmapsupp.img. You can access these files to change their names either through the SD card reader, or by putting your Garmin into USB Mass Storage mode (available from the Interface screen in the Setup section) while it’s hooked up to the computer through the USB connection to make the Garmin act like an SD card reader.
One caveat: I’ve tried this only on Garmin map data that doesn’t require an unlock code. It should work on lockable map sets as well, as long as you upload them to the unit they’re unlocked for, but I can’t swear to that; let me know if there’s a problem with those. All in all, handling the Garmin data in the microSD card this way could save you lots of time and effort.
Finally, if you haven’t updated your unit’s firmware recently, you should do so. The original units had a limited memory capacity for saving track data, but the updated software allows you to save track data directly to the microSD card, so you’re only limited by the amount of free memory available on the card. You can set this option in the Tracks => Setup Data Card Setup section; check the box next to “Log Track To Data Card”. Tracks logged here will *not* show up either on the display, or in the Track list, and you can’t download them using EasyGPS or other standard GPS utilities. They’re saved as date-stamped GPX files on the microSD card, so you’ll have to open up the microSD card directly from the computer and copy them over; either plug the microSD card into a card reader, or put your Garmin into USB mass storage mode to access these files, copy them over to your computer, then delete them on the microSD card to free up space for new tracks.
Hope helps.
Posted on Aug 25, 2010
  • ZJ Limited
    ZJ Limited Aug 25, 2010
    Try to find somethign like this: Garmin Format Data Card, 512 MB, for Garmin GPS Units
    Description: Max out the memory in your GPS unit with this data card. Holds up to 512
    megabytes of data from MapSource CD-ROMs so you can download a ton of
    street-level map detail, points of interest, business addresses and
    phone numbers, topographic information and more.
    Good luck.
A good software programme for putting maps onto a garmin etrex legendhcx
Try an Old Garmin "Mapsource" version and maps data with very low quality. I read somewhere that new versions of mapsource can't load map to Legend types
Oct 02, 2011 | Garmin eTrex Legend GPS Receiver
Lost maps
You do not give very much information to go on.
Perhaps you have downloaded some data such as routing or some other details from your computer via "MapSource". If so AND you have a mini SD card in the GPS, you have overwritten the SD card with the data from MapSource ...the map data on the SD card is now gone!
But the MapSource Data remains.
If you have copied the original data on the SD card, just copy and paste to re-place it.
If NOT you will need to contact Garmin to get a new SD data card.
What you have to do to prevent this in the future is to temporarily remove the Data Card from the Garmin GPS, then download the MapSource data from your computer. Then the MapSource Data goes to the GPS on-board memory.
Jul 21, 2010 | Garmin GPS
POS Garmin Streetpilot C330.... HELP REQUESTED!
I think this one is a return to seller or send to Garmin.
Jul 05, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin nuvi 360 can't read sd card
Make sure you format first the sd card and then the maximum giga byte is 2 mb and the minimum is 16 mb.
Jun 09, 2009 | Garmin NUVI 360 GPS Receiver
GPSMap 172c Can not read Garmin Data Card
I have the Sounder 178C. It will only work with 128 Mb Cards (or smaller). It does not work with the 256Mb Cards - says "Reading Card" forever.
Per Gramin, I had to buy the 128 Mb card and DVD map update. Then program the card with a USB data programmer to make it work.
May 01, 2009 | Garmin GPSMAP 172C GPS Receiver
Having a problems with uploading maps to gps
HOW TO INSTALL CN NA 2009NT ON A STREETPILOT C330
The CN NA 2009 NT mapset is too large to be installed in the C330 without putting part of it onto an SD card. My recommendation is to build an image file containing the lower 49 states, PR & the USVI and upload it into the internal memory as a new 'gmapprom.img' file, and then build a new 'gmapsupp.img' file for an SD card containing Alaska & Canada.
Start the process by using MapSource to create a new 'gmapsupp.img' file, choosing the lower 49 states plus PR/USVI. Make sure that the total mapset size is no more than 975MB (930MiB) MAXIMUM. Anything that's very much larger will cause the installation to fail, due to insufficient internal memory. Note: Even though MapSource lists the mapset size in "MB", it actually measures it in "MiB". DO NOT EXCEED 930.0 MAPSET SIZE AS LISTED IN MAPSOURCE! (Can you get away with "just a little bit more"? Yes, you can, but why push it when you can simply put the rest on an SD card? Otherwise, you'll spend 40 minutes uploading it to your C330, only to have it fail at 99%. No fun... )
After selecting these maps tiles, choose 'Transfer > Send to Device...', but do NOT select your C330 as the destination for your new 'gmapsupp.img' file; instead, choose to send it to a blank 1GB (or larger) SD card plugged into one of your USB ports by way of an appropriate adapter (or to the 'C:\Garmin\' folder on your primary hard drive if you're running a specially-modified MapSource executable). MapSource will automatically create a 'Garmin' folder on your SD card and create your new 'gmapsupp.img' file within it.
Once you've successfully accomplished this task, copy the new 'gmapsupp.img' file to your hard drive's 'C:\Garmin\' folder (unless that's where you sent it in the first place, as noted above), then re-name it 'gmapprom.img'.
Next, repeat the process, selecting Alaska plus all Canadian provinces instead. Do NOT select any of the U.S. map tiles you selected the first time around. Capiche? This time, however, after creating the new 'gmapsupp.img' file on your SD card, do NOT copy it to your hard drive and do NOT re-name it. Just plug your SD card into your C330.
Finally, we're almost ready to upload the first file you created -- now called 'gmapprom.img' -- into your C330. First, we have to make sure you have a copy of Garmin's WebUpdater package installed. Open your 'C:\Garmin\' folder. Is there a 'WebUpdater' folder there? Yes? Great! Look inside and you should see a file named 'WebUpdater.exe'. If you've got it, you're almost there.
You don't have WebUpdater installed? Go get it and install it; it's a free download from Garmin. I'm using Windows XP; be sure to get the Windows version that's right for you. (To the best of my knowledge, this procedure does not work on a Mac. Sorry... ) http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Now that you've got it installed, do the following:
- Right-click on an unoccupied area of your Windows Desktop; when the menu pops up, choose 'New', then 'Text Document'.
- Double-click this document; this will open up a brand new blank document in NotePad (or whichever text editor you've chosen).
- Copy and paste the following line of text into it...
C:\Garmin\WebUpdater\WebUpdater.exe /upload_file rgn=49 path=C:\Garmin\gmapprom.img -autorun usb /i
- Select 'File > Save' then 'File > Exit'.
- Re-name the file to 'C330_Map_Update.BAT'
- With the C330 connected to the PC by USB (your drivers have already been installed previously, yes???), double-click on your new 'C330_Map_Update.BAT' file.
- Sit and watch as the WebUpdater application opens up a command-line window and copies your new 'gmapprom.img' mapset into your C330!
- It will take approximately 35-40 minutes if all goes well.
-Don't forget, you'll need to have previously entered your 25-character unlock code into MapSource. That unlock code must be specific to your C330; just because your Nuvi's unlock code allows you to create mapsets in MapSource doesn't mean that those mapsets will work in your C330!
Jan 18, 2009 | Garmin StreetPilot C330 GPS Receiver
Backup Streetpilot C330
The CN NA 2009 NT mapset is too large to be installed in the C330 without putting part of it onto an SD card. My recommendation is to use MapSource to build an image file containing the lower 49 states, PR & the USVI and upload it into the internal memory as a new 'gmapprom.img' file, and then build a new 'gmapsupp.img' file for an SD card containing Alaska & Canada.
Jan 15, 2009 | Garmin StreetPilot C330 GPS Receiver
Loading to usb data card programmer
you can not see the data card programmer as a drive in My computer , but you use Mapsource to send dat to your card
May 09, 2008 | Garmin StreetPilot C330 GPS Receiver
New Maps - Can't update unit
The new maps will be unlocked to your GPS using the code Garmin supplied you.
You will have to add these maps to a second SD card if your present card is full, or else purchase a larger card. Since all the Mapsource NT 2008 Europe maps are 1,395MB in size, you'll need to purchase at least a 2GB SD card.
Mar 27, 2008 | Garmin StreetPilot c510 Deluxe GPS...
Garmin GPSMAP 176C GPS Receiver Logo
170 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
