Question about Cell Phones
What type of carrier circuit is a TDGS.XXXXXX..LB? For instance, a DHZA.XXXXXX..LB is a DS1. A DZZD.XXXXXX..LB is the D-Channel of a PRI. A FDDC.XXXXXX..LB is a 2 or 4 wire analog data circuit. Cant figure out what the heck a TDGS circuyit is....help?
  • Bart Aug 28, 2010
    Right on. Thanks!!!!!!!!!
  • Cell Phones Master
  • 4,737 Answers
Try this (click here to view the html format)
Or click here to download the pdf, open the link, click "Download Now" wait for 20 seconds and again click "Download file now" link.
Or you can check out the formulae and detailed description here: click here
{this is not a solution, this is only an assistance}
Good luck.
Thanks for using FixYa.
Posted on Aug 25, 2010
  • 12,061 Answers
Www.att.com/Large-Files/RIMS/.../ATT-TR-NIS-000-000-003.pdf
Have a look at the above link, there, it's sescribed as a Video over network, standard protocol.. all explained, well sort of in this document above, just search for TDGS. in the document.
Posted on Aug 26, 2010
What if no pinion bearing preload was recorded before disassembly of rear diff pinion seal
The only way you can get an accurate preload reading is with an in/lb torque wrench on the pinion nut with the carrier removed.
Not knowing which differential is in the truck, I'm guessing a 9.25" rear loader type.
The correct way to do it is remove the axles and ring gear carrier. Set your preload with a NEW crush sleeve and in/lb torque wrench. Re-install the ring gear carrier and check contact pattern and backlash.
That said, you probably will be alright if you re-torque the pinion nut to spec plus a hair. Look it up in a manual. EXAMPLE: if it's 210 MINIMUM ft/lb add 5-10 lbs. Preload is 10-20 in/lbs. I have seen shops do this to save the customer money (or charge them for complete disassembly and not do the work). It should take up the slack from the crush sleeve.
This is NOT the correct way, but if you are in a bind it might work. I can't guarantee the bearing won't fail in the future.
Apr 05, 2015 | 2001 Dodge Ram 1500 Truck 2WD
While listening to my scanner every so often, does not seems to be a specific interval, maybe 3 or 4 seconds usually, I get a silent pause missing conversation. For instance the ambulance dispatcher might...
sounds like you have another channel set for priority and it is scanning back to check that channel. In the manual mode scroll thru channel's until you find one set with a "p" or "pri" on the screen. Hit the priority button and this should resolve the problem.
Sep 09, 2011 | Uniden SC230 Handheld Scanner
I am configuring a pri ckt in mitel sx200icp i cannot make outbound calls i have programmed pri card as per carrier in form 42 with NI2 - NI2bell have tried all procol variant incoming is fine
It sounds like the outbound Caller ID is not set up properly in form 22. You will need to insert *6 into the dial string. If this isn't set up, many carriers will reject the call as it doesn't see the correct outbound caller ID.
Sincerely,
Mark
Mar 16, 2011 | Mitel PRI Card T1 E1 (9109615001)
I have echo on incoming calls/outgoing calls.
What kind of phone system? What kind of lines? What kind of phones, IP digital or analog?
Oct 11, 2010 | Avaya TN464F Universal DS1/PRI Interface...
Does teh DKT 2010-sd have a PRI card slot for voip
Since a DKT-2010 is just a phone that attaches to a Toshiba Key System, it's hard to say.
PRI and VoIP are two entirely different protocols. PRI is delivered on two pairs of wires and it contains up to 23 circuits and a data channel. It requires a card in your system, a DK, CTX, or CIX Key service unit.
VoIP can be delivered via an Analog Terminal Adapter, or directly into the KSU if you have a CIX-100 or higher system. Likewise, faxes are deliered on trunks to analog stations, or it just requires an analog line to receive. It can work within your system or outside of your system.
If you look at the manual, starting at page 21-23, this will give you an idea of the capabilities of a CIX system. http://cdgenp01.csd.toshiba.com/tsd/docum/gen_desc/CIX/CIX-GD-ALL-VF_E.pdf
Carl
Apr 15, 2010 | Toshiba Lands Phones
How can i text someone living in syria? i live in
You can Send text messages from Mobile.
How To Send TEXT Click here
Syria mobile numbers like follows:
932 xxxxxx SyriaTel
933 xxxxxx SyriaTel
988 xxxxxx SyriaTel
999 xxxxxx SyriaTel
OR
For Sending Free SMS try Here...
(After typing Number you want to Send & message Click on Submit.Don't forget to Type Verification Text in Specified field)
For Your Blackberry's User-guide Click Here (For better Usage)
I hope THIS HELPED you..
Anyway i like to know FEEDBACK..
Thanks for Using FixYa
Apr 10, 2010 | RIM BlackBerry Bold 9000 Smartphone
What is an E1/
see the relationship between the E-carrier system, the T-carrier system, and DS0 multiples, see digital signal X. E1 (or E-1) is a European digital transmission format devised by the ITU-TS and given the name by the Conference of European Postal and Telecommunication Administration (CEPT). It's the equivalent of the North American T-carrier system format. E2 through E5 are carriers in increasing multiples of the E1 format.
The E1 signal format carries data at a rate of 2.048 million bits per second and can carry 32 channels of 64 Kbps* each. E1 carries at a somewhat higher data rate than T-1 (which carries 1.544 million bits per second) because, unlike T-1, it does not do bit-robbing and all eight bits per channel are used to code the signal. E1 and T-1 can be interconnected for international use.
Mar 22, 2010 | RTO Pelouze Scale With Remote Display -...
Merlin Magix PRI
If D-channel is dropped, you will get red light.
When B-Channels are in use, you will get amber light.
Sep 08, 2008 | Avaya Merlin Magix/Legend Control Units,...
Avaya ds1
I would call the T1 provider. Sounds like the ISDN is down.
Jun 30, 2008 | Avaya TN464F Universal DS1/PRI Interface...
Cell Phones Logo
529 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
