Works itermittently. Fills with water and drum moves once/twice then dial begins to click round. Whilst dial is clicking machine sounds like drum is moving or trying to drain ( but isnt ). Thanks
    Genius:
  • 1,073 Answers
What is the model number
Posted on May 05, 2008
Wf02466gb overfills, what should the water level be
The drum turns after fill and then fills more an turns again until level is correct
the level is deferent dependent on cycle but in most cases it should be just touching the glass window
sounds like you pressure switch is faulty
Aug 17, 2014 | Bosch Washing Machines
WFL2400AU fills with water then stops
probably just the carbon brushes on the motor the only way to get at to check is to remove the motor and they can be a arkward to get off
Mar 03, 2014 | Bosch Washing Machines
Indesit w83 dial just clicks round, is there a reset button some where
Washed any coins lately? I had a front loading washer and when mine did that it was still under warranty so the service came out and pulled a quarter out of the drain trap. If you not sure where that is contact me
Dec 20, 2013 | Indesit W 83
Bosch Exxcel 1200 (WF02464GB) not heating
The machine only heats when it takes the detergent, all three rinses are cold only and this time of year the load will be very cold when it comes out. If the machine is not taking extra time (like a hour or two) longer to run a cycle, then there is no problem.
If you want to check the heater is functioning, try this
1 Put the dial to off
2 press and hole the start button whilst turning the dial one click to left (easycare 30)
3 release start and either two of the progression lights are lit or if it has a diplay should show 8.88 or 0.00
4 turn dial to 90 cotton, take the the long way round ie not thro the off or you will have to start again
5 press start
6 drum will fill and the heater will come on, wait a few minutes and if the heater is working ok you will hear a noise like a kettle boiling.
The drum does not turn during the test to allow you to hear this without the movement of the drum obscuring the sound.
If it sounds ok, cool. put dial to off, wait a second then select drain to get rid of the water in the drum
All the best
Apr 08, 2013 | Bosch Exxcel WFO 2264 Front Load Washer
WATER GOES IN BUT WILL NOT SPIN ROUND
check the lid switch. if its bad it will not spin. and also check for a broken drive coupler, from motor to the transmission. to check lid switch. pull the lid switch out. tape the 2 wires together, if it works fine then youve found the problem. good-day !
Apr 20, 2012 | Washing Machines
Bowl won't turn or spin. belt is fine but motor doesn't turn. the washing machine begins it's cycle fills with water but once it begins it's washing cycle the dial rotates to safety. The machine will also...
It sounds like you will need a new motor. You pump seems to work and that leads to the motor because it does not spin or move. Motor should be easy to replace good luck
Jan 08, 2011 | Asko W6021 Front Load Washer
Hotpoint WD62 Drum wont turn
tilt the machine backwards. with a multimeter, check continuity across the brushes - if open circuit then brushes need to be replaced
Oct 02, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Dial clicks round
Open the rear panel and look for a broken or worn belt. If this is the problem you can replace it easily. Good luck !
Jun 15, 2006 | Ariston Technologies AWD121WH
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
