Question about Invicta Watches
I just bout my invicta skeleton ghost. Its an automatic watch and for some reason it won't work for longer than five minutes. Is there something that I did, or am doing, that u could point out to me?
    President:
  • 2,501 Answers
If the watch has been allowed to run down, then it may need some considerable activity to wind it up again.
Hold the watch level and shake it gently from side to side for a few minutes (this should operate the self winding mechanism and wind the watch up). After this, wearing the watch should keep it wound up.
Posted on Aug 25, 2010
Invicta 8926A gains about 2 or 3 minutes after winding.
Send in for warranty repair with a description to Invicta
Oct 12, 2012 | Invicta Automatic Pro Diver 8926A Wrist...
MY INVICTA IS AN AUTOMATIC WATCH. I'VE TURNED THE CROWN SEVERAL TIMES BUT WITHIN MINUTES THE SECOND HAND STOPS
If hand winding does not work then try waving it gently from side to side for 100-200 times (yes! that is what some makers recommend).
Since self winding watches thrive on use, it is best to wear it daily to keep it functioning.
Mar 10, 2011 | Invicta Watches
The stem cover will not open, not sure why, and also not sure which end to exert unusal pressure, as nothing works now short of getting out a screwdriver and trying to pry it open. also, are the upper and...
mcdevito75 here, the stem may have a screw down cover if it"s been screwed down to tight you may not be getting a good enough grip to loosen it, Look for a small watch repair shop for this problem. Donot use ant tools yourself to loosen this screw down cover.
Jul 07, 2010 | Invicta Corduba Skeleton Techno Strap...
Does my 2010 invicta corduba have pins or screws in the braclet? how do I remove them? They look like screws but juts spin around both way when i turn them.
Sometimes the split ends of pins look like screws. If the slot is extremely thin its a pin A screw slot will be a bit wider. I pin removal toll inserted into the smaller end should do the trick.
Apr 30, 2010 | Invicta Corduba Skeleton Techno Strap...
No problems
The movement in this model is Japanese.
Apr 04, 2009 | Invicta Skeleton Mechanical 9839 Wrist...
Can't pull out knob on side of watch to change time
You may have screwdown crown. Try to unscrew it first and then pull out. If the crown is turning but you can not pull it out, there is a rust in the watch and you will have to find your nearest watchmaker to sort that.
Rate, please.
Mar 28, 2009 | Invicta 2636 Ocean Ghost Chronograph Watch
Invicta Ocean Ghost Chrono Model# 2636
Did you recently have a battery changed. A lot of times on chronos when the battery is changed the battery has to be short circuited to the AC. Which is done by taking tweezers. & touching the positive part of the battery to the part of the watch marked AC. Then try to pull the crown all the way out to time setting position press the top rt button & the second should move keep moving until it lines up with zero. If you haven't had the battery changed try what I told you to do with the crown & the top right button.
Mar 13, 2008 | Invicta 2636 Ocean Ghost Chronograph Watch
Watches Logo
268 people viewed this question
Top Invicta Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you an Invicta Watch Expert? Answer questions, earn points and help others
