I have an HP pavillion DV2000 laptop and it will boot up and come on but, no video. Can you help with this.
  • George Maeweather Aug 25, 2010
    Hello Hal,
    I am a IT tech and have the skills to break down the laptop and repair it. I would very much like to repair it and need your help to get it doon.
    Thanks
    George
  • George Maeweather Aug 26, 2010
    very much so
    thanks
  • 560 Answers
Hi. Please connect an external monitor to see if the laptop is booting up completely. If you get video on external monitor, one of the 3 components of your LCD assembly had gone bad. There are 3 possibilities: 1st - bad LCD screen, 2nd - bad Cold Cathode Fluorescent Lamp (CCFL), 3rd - bad inverter.
To see if the problem is with CCFL, turn on your laptop and tilt the LCD backward. You should see an image on the screen but its really dim.
You need a known-good inverter to determine whether you have a bad LCD or inverter. You need to disassemble your LCD panel to test the inverter and LCD and I suggest to have your laptop checked by a certified laptop technician to avoid further damage.
Let me know if you have the tools, skills and willingness to purchase parts and spend time to disassemble your laptop and I will help you with the diagrams and instructions. Good luck.
Posted on Aug 25, 2010
  • 4 more comments
  • Liza Halbrook
    Liza Halbrook Aug 26, 2010
    Did you check if its a bad CCFL?
    Yes I did and there was no image at all. On the boot up I get all he lights across the top but no post lights at the caps lock or the num lock. Then it will do nothing. I tried another power cord and battery and got the same thing. I did a hard reset and still nothing. Do you think it could be the board. The hard drive will spin and then nothing. I checked the hard drive in another machine and it will come up and read hte data. Any suggestion short of sending it to hp?
  • Liza Halbrook
    Liza Halbrook Aug 27, 2010
    Have you tried connecting it to an external monitor to see if you get anything?
  • Liza Halbrook
    Test the output voltage on the power adapter/charger and see if you get the correct voltage. If the voltage is correct, remove laptop's battery, connect the power adapter, turn it on. Let me know the result. Thanks.
  • George Maeweather Aug 27, 2010
    Went through all the checks and even used a new power adapter witht the correct voltage. When I remove the battery and connect the power adapter I get the same thing. I get lights across the top of the laptop and the hard drive light will flash once and stop. The power light is lit, but it seems as if everything is just hanging and will not go any further.
  • Liza Halbrook
    Liza Halbrook Sep 01, 2010
    Sounds like a bad mainboard, not bad LCD.You may have to bring your laptop to a service center. Mainboard is harder to troubleshoot online.
    Genius:
  • 1,035 Answers
Hi. This might be an LCD problem that you are encountering. Let us try to troubleshoot the issue first. Take out the battery first and unplugged the power adapter from the wall socket. Press and hold the power button for 30 secs then put everything back in. If Nothing happens after this procedure, then i suggest to have your laptop repaired by HP since you have a 100 percent LCD problem in your computer.
Posted on Aug 26, 2010
3 Suggested Answers
  • 3 Answers
SOURCE: HP Pavillion dv2000
the inverter is the problem and must be replaced .
Posted on Jun 03, 2008
SOURCE: Unable to install Windows XP on HP Pavillion DV2000 ( Built in Vista )
Best Solution is to disable Native SATA support in BIOS ,
Now Win XP will recognize the Hard Disk
Posted on Jul 13, 2008
Hp pavillion dv2000 laptop has no windows n turn off need help to fix some help please
Please explain what is the problem. What you are saying makes no sense. What happens when you hit the power button? Does it boot up? Do you hear fans running, hard drive spinning, see lights?
May 24, 2012 | HP Computers & Internet
My hp pavillion dv2000 laptop is not turning on
Hi i'm Rain.
Remove the battery and plug it into a wall outlet. now try booting up your unit. if this works you will need to replace your battery.
Dec 03, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Help me
Faulty GPU, you need to replace the systemboard or reflow the GPU. You can find a DIY reflow guide here www.bootmylaptop.com
Sep 24, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
Hp pavillion dv2000 laptop display problems
There is a known problem with the video card in this machine, certain models are covered by an extended HP warranty.  Symptoms are overheating and finally not starting at all.
See this link http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us
May 03, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
Hp pavillion dv2000 ethernet controller
If you're just looking for drivers and pretty much everything else, check this out.
Hope this helps.
Oct 03, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP Pavillion dv2000
well, try hooking it up to an other screen and see if it boots up,if it does your screen has taken a flop if it doesn't your viedo card is gone. lala linda
Jun 03, 2008 | Computers & Internet
How to install Widnows xp on HP Pavilion dv2000
Please help me, I bought a HP Pavillion dv2000 Laptop which came with a built-in Windows Vista. Thats cool, but the problem arises when I try to install windows XP. After inserting the Windows XP SP2 CD and after primary driver loading it is unable to detect my harddisk
May 07, 2008 | Computers & Internet
Sep 05, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
David Payne
David Payne
