Question about Life Fitness 9500HR Next Generation Remanufactured Treadmill
How do I change the treadmill band on a 9500hr commercial treadmill?
  • 79 Answers
Step one: remove the screws to calibrate allens belt in the opposite direction clockwise allens wrench 5 / 16 "
Step two: remove the screws above the deck allens wrench 5 / 32 "
Step three: with a flat screwdriver to lift the lever of the Idler belt and remove the drive belt motor pulley. be careful
Step four: remove the rollers carefully.
Step five: Remove the deck
Step Six: Remove the philips screw that holds the spray nozzle
Step seven: now carefully remove the belt.
to install belt now repeat these steps from back to front Once installed you must calibrate or belt slack to avoid turning the screws slide the meaning allens counterclockwise you can start with a speed 1.5Mph and increasing to 4.5Mph any questions send me an E-mail to cardiotech_me@hotmail.com
Posted on Sep 11, 2010
Testimonial: "Thanks!"
Can a 9500hr next generation treadmill be disassembled to go through a 34 inch wide door opening?
Probably. Owner's manual should have instructions. No instructions? go back to store purchased from or Manufacturer.
Mar 04, 2015 | Life Fitness 9500hr Next Generation next...
Life fitness 9500hr treadmill belt not moving and speed sensor error comes up on the screen
see the video and lube to the rollers bearing front+back .
and Run the calibration software for easy diagnostic for s. sensor
God bless you
Oct 17, 2013 | Life Fitness 9500hr Next Generation next...
Treamill 9500hr is reading weight in pounds and not kg
Please go to the Menu, and go to the section go caractheristic and change the Lbs to Kgs.
God bless you
Jan 09, 2013 | Life Fitness 9500HR Next Generation...
I have Lifefitness 9500HR, commercial, when belt is running it produces load rubbing sound and when somebody is in it, the sound gets louder. What causing it?
this happen because lack of maintenance schedule, shut down and produce enough friction and loud, and shut down for to protect the electronic systemLUBE Inmediately the deck belt,maybe is time to replace the deck belt. by WORN.
2) LUBE THE rollers bearing too
3) test the motor voltage input, if there are the MOTOR need REPAIR.see my persosnal TIPS.
God bless you
Oct 16, 2012 | Life Fitness 9500HR Next Generation...
9500hr treadmill said "notify maintenance
Your treadmill is notifying you that some maintenance operation has to be performed.
Nov 21, 2017 | Life Fitness 9500HR Treadmill Next...
My Life Fitness treadmill needs to have the motor control board replaced. A new one is costly, where would I get a used one? We are in Ontario Canada.
if it is a classical model 9500/9500HR/9100/9100HR can take the card to a qualified technician mail, you must open the controller and change the following components: D4015L (2) 2N6507 (2) TIP110 (1) and in the latter case there to change the IRGBC40S.
if you treadmill is the Next Generation you should buy new and can find on sportsmith.com
Sep 04, 2010 | Life Fitness 9500HR Next Generation...
How do i change from metric to miles on the 9500hr tread
press stop and when the screan is still blank hold down pause until it the cousle comes back up and then tagel to managers mouds then enter then tagel to whare you change from english to what ever
Aug 20, 2010 | Life Fitness 9500HR Next Generation...
Hi have life fitness 9500hr.when i opne MOTER
Every time I have gotten this message, I have had to replace the motor controller.
Feb 27, 2010 | Life Fitness 9500HR Next Generation...
Heart rate monitor chest band not working with Life Fitness 9500H
This mean that you unit is not equiped with a receiver inside the treadmill. Some models that was an option. Polar is the only brand that works with Lifefitness. You may have a bad upper display board. You can buy a replacement for a small amount of money.
Mar 12, 2009 | Life Fitness 9500HR Next Generation...
Life Fitness 9500HR Next Generation Remanufactured Treadmill Logo
280 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
Craig Butler
Craig Butler
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
