Question about Refrigerators
Ice maker frozen up in door. ice in shute can 't get ice cubes out. How do I turn off freezer so ice can melt in door. Needs to be cleaned out.
  • 1,531 Answers
Usually unplug it but you can also use a hair dryer and defrost the ice chute in the door.
Posted on Aug 25, 2010
Water collecting in the water compartment
what is question as well as make ,model of unit
Nov 13, 2016 | Refrigerators
Sometimes ice melts in ice maker. Water drips down and refreezes.
There is a heater built into the ice maker bottom to help release ice cubes from the machine. Under normal conditions the heater only come on when the ice maker starts to run and then jambs against the frozen cubes. When it stalls and jambs against the frozen ice cubes, the heater comes on to melt the cubes enough. I think you have a defective ice maker and the heater is coming on to much or at the wrong time, Since your temps go back to normal with the ice maker turned off, I am almost sure thats your problem.
Mar 16, 2015 | GE Profile PSC25MSWSS Stainless Steel...
Ice maker stuck on crushed ice instead of cubes
most likely you have ice built up in the door or icemaker that has frozen hard easiest thing is to turn of fridge empty freezer leave door open to melt the ice remember to empty ice maker wash it out removing all ice ect. then when all is dry and clean start it up and see if that doesn't fix it.
Aug 20, 2014 | Kenmore Refrigerators
Ice cube maker not working. I saw water frozen in the plastic shute leading to the ice trays.I used a hair dryer to melt the ice in the shute. The white gear IS turning. Still no filling of water. Door...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
Jan 02, 2010 | Whirlpool ED2FHEXN Side by Side...
The ice maker on my refrigerator has stopped making ice. Water is still flowing but the tray doesn't fill and the whole mechanism seems not to function.
Pour about 2/3 cup of water into the ice maker . If the ice maker dumps the frozen cubes , but doesn't refill with water , you should replace the water inlet valve , behind the refrig , where the wall water line connects to . If the Ice maker does not eject the frozen cubes , replace the ice maker .
Also , check the ice maker fill tube , from the back wall inside the freezer , to the ice maker fill cup , to see if it's frozen . If so , you will need to remove it , and clean the ice out . This would be caused by a " seeping " bad water valve also .
Check the coils under the refrig , to make sure they are clean of dust , lint , pet hair , etc , as this will raise the freezer temp above 5 degrees , which is the temperature which the ice maker needs to operate properly .
Oct 10, 2009 | Refrigerators
Movable arm on ice maker is frozen in place. No ice cubes are being made.
Use a hairdryer on the arm area to melt the ice, then see how it does. Too much air leaking into the freezer from the door gaskets or opening the door can cause excess icing.
Jul 11, 2009 | Refrigerators
Ice Dispenser clogged with frozen ice
I have the same problem. Found this posting:
http://www.applianceblog.com/mainforums/sears-kenmore/10491-kenmore-ice-maker-dispenser-door-shute-clogging-missing-heating-element.html
Maybe our heater is not working?
Jul 05, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Magic Chef Side by Side MOdel RC224RDA
I have the same problem. It turned out to be a problem with the doors. When my kids go to get a snack and close the fridge door (read slam the door) the air pressure pops the seal open on the freezer door causing the ice cubes to begin melting. The bottom items stay frozen (warm air rises). It took me a long time to work this out.
Remove the ice maker tray. Remove the ice blob, being careful to put the u-shaped wire ice-level sensing wire thing, in the up position or the system will dump ice and water all over the freezer. Put all back clean and dry and buy a velcro adhesive strip and install it on top of the freezer door to prevent the door from always blowing open.
Hope this helps
Jul 03, 2008 | Magic Chef (CSD2610KRW) Top Freezer...
Ice dispenser in door clogged up or frozen
I would contact Hotpoint direct for this one. It sounds like a design fault to me.
What I think may be going on is that the cubes are melting too much, then refreezing lower down.
Set your freezer to -18, and the fridge to +2 and see if that changes things any.
Check seals in that area. Where is the moisture coming from to generate the frosting? - Is the location high in humidity?
Jun 11, 2008 | KitchenAid KSRS25IL Side by Side...
Refrigerators Logo
55 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
