Question about HP Pavilion dv6000z Notebook
My computer is fully charged but it keeps cuttin off. it barelt will get pass a screen that says safe mode. start normally. safe mode networking and something else.....do u know what the problem is
    Sergeant:
  • 223 Answers
Sounds like a booting issue. try taking the battery out to eliminate battery issue. Sometimes a computer will do that if its overheating Get a can of air in there and blow out the processor.
Posted on Aug 25, 2010
Why won't my sylvania netbook which runs WINDOWS CE..but it NEVER gets to the desktop page...what wrong?
I'm not familiar with Windows CE, but I have had similar problems with Windows 7 on laptops.
Try keeping the F8 key depressed when starting it up. The F8 key should allow you to start in 'safe mode'. I would imagine that the F8 'safe mode' is also to be found in Windows CE.
Keep pressing that F8 key as it powers up and hopefully it will present you with a screen that gives you a choice of 'safe mode' or network prompt. Choose 'safe mode'.
If your computer then starts in safe mode (it's just a minimum amount of drivers loaded to start the operating system) .. restart it again and see if it starts normally. You may have to 'play' and keep restarting it and pressing F8 ..
You can also change the boot up sequence as the computer starts. This is usually done by pressing the 'delete' key -or escape or f12 key (it varies from computer to computer)..
.. to take you to the bios settings. Change the boot order..if the dvd drive/usb is the first boot up device change it to hard drive as the first boot up device .. and see what happens.
It's almost as if the computer gets stuck in an endless cycle of 'trying to boot up' which is probably due to software conflict, for whatever reason.. some driver may not be loading to allow it to boot up correctly.
Jan 06, 2015 | Sylvania G-Netbook
I cannot get passed the Windows Error Recovery screen. If I select Launch Startup Repair nothing happens. If I select Start Windows Normally it goes to starting windows screen momentarily and returns to...
First try starting your computer in safe mode. Power down, then hit power button and tapping F8 will get you to this option window. You can also choose safe mode with networking. While in this mode check for any new updates. If you installed new software or hardware uninstall these. Try restarting computer. If this doesn't work and you have a recovery disk put it in while computer is on and then restart.
Apr 27, 2013 | Gateway NE56R10u Laptop
Starting Windows comes up that passes then all I get is a white mouse on a blank black screen for ever whats the deal?
Try restarting the computer and as soon as it begins to start up click on your " f8 " key repeatedly until a start menu comes up. Click on " safe mode" the computer will try to boot up to a simpler mode of windows. If this is successful you will get windows up with larger icons on a black background. Click on shut down / restart the computer will reboot to normal mode. This is often sufficient to resolve windows start up problems. If safe mode worked but the computer still does not fully start click on three keys at the same time " ctrl alt and delete" when you have the mouse only screen. This should bring up the " task manager" click on " run new task" and enter " explorer.exe" this should bring up your desktop
Feb 11, 2013 | Computers & Internet
I have a Lenovo U350 ideapad. When i rebooted it, it keep coming up Windows Error Recovery. I tried all the options (Safe Mode, Safe Mode with Networking, Safe Mode with command Prompt, Last known good...
Welcome to Fixya
Looks like the Windows OS is already messed up. You should be able to boot the computer to safe mode to troubleshoot the issue. In your case, it is not booting up to safe mode then the only way to use your computer again is to restore it from the factory default state. If you want to do that, just turn off the computer then press the ONE KEY button located beside the power button then follow the on screen instructions.
Thank you for using Fixya!
Sep 05, 2011 | Lenovo Ideapad U350 Laptop Notebook
Computer is not loading..black screen keeps coming with the message input not supported..how can i turn my computer on normally.it loads on safe mode.
Input not supported could be the screen having problems. It loads in safe mode so the display driver is corrupt or set to a too higher resolution for your screen.
Adjust it as required.
Jan 08, 2011 | Computers & Internet
My Lenovo laptop starts up and shows Microsoft Windows starting to load but a few seconds later the screen goes black. The computer is on but it shows a black screen.
Try running in Safe mode.
Start the computer and hit the F8 key many times till you get Windows Advanced Option menu - Choose safe mode with or with out networking.
Does your computer seem to be working now? (safe mode is a limited use mode)
Chances are that your computer is infected and preventing normal use..
Restoring the computer would be the easiest way to fully clean out all infections and needed software corruptions. A full restore DELETES all DATA from the hard drive - Make sure you have all your data backed up. You can back up your DATA in side safe mode.
The information given relates to CORRUPTIBLE software like a virus....
Other issues may factor in to this but, not believed to be so.
Thank you for contacting Fixya.com.
Nov 11, 2010 | Computers & Internet
Posiflex jiva 5700/5800 keep restarting
Your operating system is corrupted, you need to reinstall the operating system
Dec 16, 2008 | Posiflex Jiva 5800 All-In-One...
My computer keeps on going to the start up screen
yes, my laptop was working perfectly normal yesterday and when i get home from school it does this
Aug 13, 2008 | E-Machines T1090 PC Desktop
Windows won't start
the reason it does this is because a program was interrupted before it finnished or a incorrect driver was installed.start up in safe mode to repair the problem.if you know of a new driver youve just installed either roll back to previous driver or delete it.
if unsure use check disk.when done restart.pc
Jul 20, 2008 | HP Pavilion dv4000 Notebook
When I start my computer it goes to a black screen that tells me my computer did not start successfully and that that I can pick to start my computer in safe mode, safe mode with networking , safe mode...
while you in the booting screen like safemode , safemode with command prompt In that screen press F8 key you goto the other screen like safemode etc., select Enable Vga mode and select the operating system.If it is not work properly then you have reinstall the missing file in the operating system that means you have Repair the operating system.If you dont know how to repair the operating system plese inform to fixya.com
May 13, 2008 | Computers & Internet
HP Pavilion dv6000z Notebook Logo
24 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
