Question about RCA RS2056 Shelf System
Not reading CD
For the past months I have not been able to have the stereo recognie any of the CDs that I am trying to listen to. I even tried to use my cleaning CD and the stereo did not recognze it. What do I need to do to get the stereo to recognize the CDs?
The optical CD reading mechanism needs to be changed, take it to a repair center. These parts are not user-replaceable.
Posted on May 05, 2008
I have a 2005 Jeep grand cherokee...with a 6 disc cd player. It has worked fine for 3 years since i bought the vehicle...(i used burned cds in it usually) and all of a sudden it will not play or read the...
this is a typical problem with the factory stereo. usually there is nothing you can do for the Cd player, because most likely a cd got jammed and broke or bent some internal components. however try usig a credit card to help eject. insert it partially into the slot and pull out if the cd tries to come out. if this doesen't work then you will have to have the cd removed by tearing it apart. this usually ends up with at least one or two scratched cds and a deck in a million pieces.
Jan 18, 2011 | 2005 Jeep Grand Cherokee
Car cd player won't read cds
I have a Dual xdvd8180 dvds multimedia reciever 7" digital touchscreen in my car and it worked fine for the longest time but now it wont read any of my cds.. burnt or original discs.. nor will it read dvds.. i tried cleaning it with a disk cleaning kit and it wouldn't even play that without skipping..idk whats wrong.. any help??
Jan 04, 2010 | JVC AM FM CD DET FACE CAR STEREO
Wont read divx on cds
I have had this same problem on my Toshiba. I went through the Control Panel and their were settings for the dvd player it used. You can change settings and they sometimes change automatically.
May 22, 2008 | Toshiba SD-K760 DVD Player
I have an aiwa nsx 5200 mini system the cd player broke
Soooooooo many people have complained about this system not reading discs properly, yet the solution is incredibly simple. All you need to do is calibrate the lens, and you can do this without even opening the stereo! Here's how:
With the stereo all unplugged, turn it around so the back is facing you.
Now use a flashlight and, looking through the grating on the back, approximate where you think the cd lens mechanism would be. You should see 2 8-pin connector wires side by side (one red and one white) and to their right a small black circle screw type thing.
Using a screw driver, turn the screw thing about 1/10 of a revolution clockwise.
Plug in, and test with a clean cd. If nothing happened, repeat the procedure turning the screw thing in tiny increments (don't over do it.) Eventually, the cd player should recognise the cd. Keep fine tuning and testing until you've found the "sweet spot" where it recognizes and plays cds optimally.
Overall, you should NOT have to turn any more than a full revolution, and even half a revolution is pushing it. What you are really doing by turning this screw is fine tuning the "data reading point" of the laser. Too close and it will focus on the area between the cd and the lens, causing failure to recognize the disc. Too far and it will focus past the data perhaps recognizing the disc but not being able to read it. I believe the major problem with these players is that as they settle in, the area between the lens and cd changes. This would cause a gradual degrading in performance until the player finally failed to recognise any data at all (which is exactly how mine went personally.) There isnt a problem with the quality of the lens itself, therefore it is very fixable!
I have heard that all 3cd Aiwa Mini-systems share this problem so, as long as the calibration tuning screw is exposed through the grating on the back, this fix should work for any of the Aiwa mini-systems with this particular problem. If the screw isnt exposed, it is still possible to get at by opening and dismantling the player. (Unfortunately, i did not originally notice that the screw was accesible through the grating, so i went about pulling the entire system apart and wasting hours of my life. You can thank me later for saving you this tedious trouble as you're listening to cds on your newly fixed player ;-) )
If this doesn't work, or doesn't fix the problem completely, try cleaning the lens. You can do this by either by using a cd lens cleaner (looks like a cd with a brush built into it) or opening up the stereo and using a soft cloth on the lens. You may also want to try putting the screw back to its starting point and using the same procedure but turning the screw counter-clockwise. (I personally had to turn clockwise but who knows, maybe your player settled in differently.)
As for the mechanism itself, i have no idea. I did notice, however, that the lifting mechanism sometimes picks the cd up off-centered causing failure to play. You can semi-fix this by holding the stereo at an angle while it picks up the cd or placing it off-centered in the tray. Its annoying, but it works :)
Feb 19, 2008 | Audio Players & Recorders
Stereo won't read cds
You might try running a cleaning CD in it (which cleans the lazer lens). These are available from Wal Mart and many other sources. If a cleaning doesn't get it going, then you may have a lazer that is weakening and might need to be replaced (sorry!). Hope just a good lens cleaning will do the trick.
Jan 09, 2007 | RCA RS2652 Shelf System
CD 8445 not reading CDs
Have you tried cleaning the lens with a CD? The pickup might even be bad. Check this out: http://www.techlore.com/article/14550/ That article is completely applicable to car players as well.
Aug 13, 2006 | Eclipse CD8445 CD/MP3/WMA Receiver
CD and MP3 discs burned or otherwise do not load
First of all, you aren't going to like this solution because it's the truth. If you rate me poorly, it's because you don't understand the truth. The optical pickup is bad and needs to be replaced. Anything made by Jensen/Durabrand is poorly built. Yes, you're lucky to have even gotten four months use out of it. I've seen some that only last for two months and they die. Fortunately, that's why you didn't pay that much for it. I would suggest getting a Pioneer in the future.
Jun 15, 2006 | Durabrand WD810
RCA RS2056 Shelf System Logo
157 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
