Question about Xerox Phaser 8200 Laser Printer
Phaser 8200 I have an error code that reads 07,005.47:6355 do you know what this means? steve
    President:
  • 2,072 Answers
Normally its the maintenance tray clutch slipping.
Or the maintenance tray ends are worn.
You can remove the left cover and clean the clutch, its on the lower part of the frame, and take your kit out and there are 2 tabs sticking out the ends that were on the last 1/4th inch.
The Printer's Front Panel Displays Printer Error - Report Fault: 07,005.47
Cause:
The Drum Maintenance home sensor actuated, but not at the expected time. Solution: phaser 8200 - thumbsup.gif Fixed! Did not fix. TRY FIRST (Solutions without parts): The wiring harness from the clutch is not seated properly on the I/O Left board. Check all wiring connections to the I/O boards and verify. connectivity. TROUBLESHOOTING TIPS AND HINTS: Inspect the maintenance drawer lift pins for wear. See Service Bulletin #445 Rev #1 Replace Drum Maintenance Cam Followers for Inadequate Drum oiling Due to Worn-out Lift Pins. Run diagnostics to verify clutch and sensor operation. Also verify that the drum maintenance shaft is properly assembled. PARTS:Parts are listed in the order of highest probability for repair. NUMBER QTY DESCRIPTION PROBABILITY% MODEL S/N FROM S/N TO S/N 401087100 1 CLUTCH; LARGE,DM,SAFETY CONTROLLED 436041400 1 MAINTENANCE DRAWER W/10K ROLLER & COUNTER/PHASER 860/8200 367051501 2 FOLLOWER,CAM; DM CAM,SAFETY CONTROLLED, QTY 1
Posted on May 05, 2008
  • Rick Kasper May 05, 2008
    Here is the clutch part number
    401-0871-00
    call 1-800-835-6100
Error Code
Hi Steve,
Please try Josh's Lab solution (on YouTube):
Josh Lab 9 Canon Printer Error 6A00 Fixed
G'Luck !
Apr 11, 2014 | Canon Office Equipment & Supplies
Prima LPR730
Hi Sue this may be the problem. Found it on the net.
F7 error fault code
This is flow meter failure. The flow meter impulse wheel (situated in the water tank) is not turning correctly, too fast or too slow therefore the electronic impulses received by the module/pcb are not correct, also the water valve can be faulty.
Hope it helps.
Steve
Oct 12, 2013 | Washing Machines
My copier is reading a e120 error code and i dont know what it mean
Check in the manual or on the manufacturers website to find out what the error code means.
Mar 01, 2011 | Computers & Internet
Hi,i have a samsung washing machine,p1253.model and i keep getting a code UE,and it appears not to be spinning.....please advise what this code means and is it possible to read an instruction manual on...
Hi, UE error means unbalanced load, loosen the washing and try again, if the load is to heavy take out some of the washing and spin in 2 lighter loads.
UE Happens if you overload the washing machine.
CLICK HERE for the user manual.
Hope this helps.
(Dont forget the thumbs up if this helped)
Feb 12, 2011 | Samsung Washing Machines
Will not play cd's and gives error code
I am not sure it is much help but as far as I know the eprom is in the computer. The computer is directly below the CD player.
So duff computer?
Nov 12, 2009 | Nostalgia Electrics Classic Music Jukebox...
What does it mean when it reads "C-error" on my radio screen?
hi,you can ask your dealer to provide your code number for your radio,ty
Mar 30, 2009 | 1994 Mercedes-Benz C-Class
One Red Light in cpntroller number 4
Steve, what error code are you getting? Go here and find out what your error code means. http://llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Nov 23, 2008 | Microsoft Xbox 360 Console
Service code EC?
CODE INDICATION
05 Refrig. Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
06 Refrig. Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
07 Freezer Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
08 Freezer Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
20 Defrost Under-heat with No Voltage Feedback Through Gray/White Wire at Defrost Start
21 Defrost Overheat
22 No Voltage Feedback Through Gray/White Wire at Defrost Start
23 Defrost Overheat with No Voltage Feedback through Gray/White Wire at Defrost Start
24 Defrost Under-heat
30 Excessive Icemaker Water Valve Solenoid Activation (Exceeded 15 Seconds)
40 Excessive Freezer Compressor Run
50 Excessive Refrigerator Compressor Run
Jan 21, 2008 | Sub-Zero 632 / S
Xerox Phaser 8200 Laser Printer Logo
294 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
