Question about Kenmore 98702 Stacked Washer/Dryer
I have a Kenmore laundry center model 98702. It is sqeeking and we cannot get the back panel off to access the belt. There are no screws around the panel.
  • annettva2 Aug 25, 2010
    Thank you for the information. We were able to stop the noise. the manual will be very helpful.
    Top Expert:
  • Kenmore Master
  • 78,919 Answers
Please go to the attached link, there is a picture of the part that causes this problem as well as the belt, there is also a link to the factory repair manual that explains how to install the belt and pulley in a Kenmore stacked laundry center, the file is large so once you click the link at the bottom of the part picture give it a few min's to load the pdf file of the repair manual, it is free.
http://forum.appliancepartspros.com/dryer-repair/51107-dryer-squeaks-real-loud.html
Posted on Aug 25, 2010
417.94802301 does it have a washer belt?
Model 41794802301 KENMORE LAUNDRY CENTER Parts Yes. Look for two screws at the bottom of the front panel. Remove them and pull down on the front panel to remove it. You will have access to the washing machine components.
Feb 22, 2018 | Washing Machines
How to acces washer belt assembly
Remove screws at bottom of front panel. slide front panel down to remove and gain access to machine
Nov 21, 2013 | Kenmore 98702 Stacked Washer/Dryer
My Kenmore stacking dryer heats up but does not spin. How do I get to the belt?
you shoud be able to look at the belt from the back access panel and double check to see if it is broken.
if you need to replace the belt the the control panel has to come off then the front panel needs to be removed and you can get a new belt around the drum.i hope this info is helpful it is time consuming.if there is anything else i can do le tme know good luck
Jan 23, 2010 | Kenmore 98702 Stacked Washer/Dryer
How to open upright washer dryer to change belt on washer
FIRST TURN OFF THE POWER TO THE MACHINE,
LOOK AT THE BACK AND YOU SHOULD SEE SCREWS AROUND THE BOTTOM PANEL REMOVE THEM AND THE PANEL YOU SHOULD SEE THE DRIVE BELT CONECTED TO DRUM PULLY AND THE DRIVE MOTOR LOOK FOR A TENSIONOR LOOSEN IT AND REMOVE BELT TAKE THE BELT TO AN ELECTRICAL AND PLUMMERS SUPLLY STORE FOR REPLACEMENT BELT REFIT IT AND REPLACE PANEL AND YOUR MACHINE SHOULD WORK FINE , GOOD LUCK .
Nov 26, 2009 | Kenmore 98702 Stacked Washer/Dryer
Squealing dryer
Most dryers have a vented access panel on the back on the bottom that is held in place by a couple of screws so you can get to the motor & pully assy. Check to see if the grease has dried up on either the iddler pulley or drive pulley. If needed, push down on the iddler to release pressure on the belt and give the pulleys a spin. If they seem fine then it will be the belt or possibly an overloading problem.
Jul 09, 2009 | Kenmore 98702 Stacked Washer/Dryer
Adjust motor/heating elem to put screws back - Kenmore Dryer 417?
pull them away from the wall and see if you have an access panel in the rear of the dryer. If you do remove it and undo the belt so that you can freely sway the drum in either direction. it may re-align the holes for you to replace the screws if not you'll have to open the dryer possibly by prying the top up and undoind the screws that hold the front panel to the cabinet. from there you should be able to move the drum about to get the scres back in but f you do get it opened take the time to clean it out. Make sure you undo door switch wires before removing front panel.
Apr 02, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore dryer
Are you getting heat and can you hear the motor running? If so then you've just had a belt snap. It's a pretty easy fix. You just gain access to the dryer through the back. Remove the several screws that hold the back pannel in place. You will most likely see the broken belt as soon as you remove the panel.
A new belt is very inexpensive! Good luck!
Dec 15, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryer won't spin, appears to be out of alignment
REMOVE THE 8 SCREWS ON TOP PANEL, THEN GO FROM THE FRONT NOT TO DIFFICULT ,,,
Nov 25, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryer drum wont turn- burning rubber smell
could be a stuck gear box. burning rubber smell is coming from the belt sliding .
or the belt is just loose and can not turn the drum to spin it.
tnx 4 using fixya,
drcool
Oct 11, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Stacked Washer / Dryer Model Number 417.97802792
can the rear bearing on the drier be oiled/greased though the back casing, any easy way of stopping sqeek!
Nov 07, 2007 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
382 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
