Got a new basket drive and dont know how to install it
  • 1,028 Answers
Why a new basket drive ??only on rarely do they give problems unles you have a belt drive whirpool/kenmore then it may be worn out
Posted on May 06, 2008
you need to drive it about a week of normal driving or two days of driving as close to 50mph for 10 miles straight
Sep 28, 2012 | Cars & Trucks
Both of the Pegasus baskets in my sink have come apart. I put them back together and they come apart again. I would like to purchase new baskets, but can only find the entire drain assembly, which I do...
I know what you mean I had similar problems with my sink strainers, unfortunately is you want to get a good working basket you have to buy the whole drain assembly. You can get some cheap ones at a home store but they will only break again and probably won't match up. What I recommend is swapping out your drains with a drain brand that won't break again like Kohler, Moen, or Elkay. All you need to install a new drain is the new drains, a drain nut removal tool and some plumbers putty. Take the old drain out clean around the whole and install the new one with a ring of plumbers putty around the hole.
Jul 09, 2010 | Pegasus Technologies Pegasus Kitchen Sink...
Yz 250 clutch basket, can the groves be filed out and it be reused? Also, what years used the same basket
if you file the grooves, the plates will move about and likely break the basket, as the filing is not likely to be exactly even it will cause poor clutch opperation. sorry i dont know what years will fit but they dont change that sort of part each year, the bike breakers\wreckers may know that one.
Apr 14, 2010 | 2003 Yamaha YZ 250
Washer does not spin but makes loud clicking noise?
sounds like you could have a problem with your basket drive tube,around the clutch brake area! my machine would not spin and i found out the bottom of the basket drive tube had been ground off by the thrust washer which resulted in the clip that holds the brake release arm fell off and broke the 2 little pins on the brake release arm and it would not disengage the brake to allow the basket to spin, i bought a used basket drive tube and a new clutch ,installed and unit works fine now,,,so take a look also check your motor coupling see if it is broken ,,, and 1 more thing ,up under your agitator is the basket drive block sometimes it shears off the notches on the top of your drive tube!
Feb 17, 2010 | Kenmore 24032\24036 Top Load Washer
Problem with Kenmore Washing Machine.
IF your coupling is broke then put a new one on and see, but without a coupling then you dont have a washer period. Whirlpool is very good make if a new coupling does not work and you can hold the tub while it is spinning then you have a bad basket drive. but put a coupling on and then put it in spin, bypass the switch with a ink pen or something and try holding the tub if you can then its the basket drive if not your good to go.
Apr 19, 2009 | Kenmore Washing Machines
Front loading washer makes loud noise
may i know the model of your washing machine ?
if it is a kenmore you can check this suggestion.
With the lid open, set the cycle to spin and press the lid switch button with a pen. Wait until the drum gets to full speed and release the lid switch. If the drum makes a knocking/ thumping noise and doesn't stop spinning within 2-3 seconds, the basket drive block is worn and needs to be replaced. (The basket drive block is located on the gearcase drive shaft, under the tub and agitator) If this has been happening for a long time you may need to replace the brake and drive tube assembly as well.
Basket drive block part number is 389140
A dozen or so loads shouldn't have caused any damage to the brake and drive tube assembly.
The basket drive block is about $20. You will need a spanner wrench to remove the span nut
that screws onto the basket drive block. They have one for about $20
If the brake and drive tube tabs are bent, your best bet would be to replace the brake and drive assembly. You can try gently bending them back with pliers, but I would hate for them to snap off completely. Be careful not to damage the seal in the process.
Depending on the severity of the bend in the tabs, you may not need to do anything to them. Make sure to line up the tabs to the slots on the new basket drive block and hammer in down completely until the tabs and slots are flush. Inspect to see if the bent edges of the tabs are bent inward further than the width of the basket drive block slots. If they're bent too far in, it may wear the new block out quickly and the same issue will come up.
When you re-install the spanner nut to the basket drive block make sure to tighten it hard (use the spanner wrench and a hammer/malet.)
You don't need to grease the shaft.
Mar 20, 2009 | Washing Machines
Drive tube replacement problem Kenmore 70 series
ok the only way i can help now is start fro the begging ok,,check point taking that unit is apart..ok...first you took motor mount plate off and change couple,,now you remove a silver gaurd over the clutch brake assm,,next is a brass u shaped you have the clutch brake asss..theres a c shape pin holding the clutch to the top of the gearcase..remove now all you have is the gearcase,,put the new one back together in reverse order..where good there if you already removed the to inner basket withblock can pull the drivebasket out,,(spintube) note this when putting back make sure you drivebasket goes up first and all the way,,next push your transmissin and clutch assmm,,up nice and smooth make sure that the brake spring which is inside the clutch doesnt hit the plastic cam on the bottom of the replace you three boltsin the transmission...go back up too the top of the basket drive and put your drive block back now on top the basket drive theres to little pins and on the drive block theres 2 groves knock your driveblock down slowly and make the block go down through the pertruding pins of basketdrive,,until you get a snug fit,,now put your basket back,,,tightn down spanner nut,,,onthejob..keep me posted
Jan 14, 2009 | Kenmore 24032\24036 Top Load Washer
Would a new basket drive help?
not that unique, whats happening is the transmission has a wig wag and shift cam bars that are not moving at the right time. you probably have an open coil on the wig wag and its normal for them to do this when a coil fails. just take the 5/16 screw out of the wig wag and lift it off the plungers, then replace it with a new one. all should work correctly after that.
ok so now i have seen your ? 4 times and you dont need a basket drive either.
you might want to make sure you didnt unhook a wire from the wig wag when you changed the motor and it could also be the cam bars are just stuck, which ever, just look at the wig wag and bars. that will be your area to repair.
Jan 06, 2009 | Whirlpool GSC9455 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
