Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Computer cannot detect camera message comes on lately when we try to download photos from our SD750.
  • 7 more comments
  • jack8503 May 07, 2008
    I have the Canon PowerShot SD600 Elph. I installed the disc that came with it on my computer, and the program is on there but when I try to transfer my pictures from camera (after following the instruction CORRECTLY) a screen appears that says, Cannot detect camera! Please check connection, and retry. This is sooo frustrating
  • Anonymous Jun 12, 2008
    When I plug in my camera a message appears that says "Cannot detect camera"
  • Kimba870 Jun 16, 2008
    I have the same problem. My camera is new and I didn't have a problem the last 2 times I tried downloading pictures.
  • missla Jul 15, 2008
    also having the same problem. worked fine, now won't read the camera
  • oMarker Jul 24, 2008
    i can't even turn on the camera. so i tried plugging it in w/ the usb cable, but then the computer said itt couldn't detect the camera, try again.
  • mmittleman Sep 21, 2008
    Have the same issue - worked fine for awhile, now sends "Cannot detect Camera message. Have uninstalled and reinstalled the software - still does not work. Installed on a new computer - works fine.... Want it working on THIS computer... Any solutions?
  • Anonymous Dec 01, 2008
    this sucks mine does the same?!?1
  • sfouts08 Apr 12, 2009
    i connected my camera to the cable in the usb port and no noise was made, and no window popped up. when i go to zoombrowser, i click connect to camera, but it says cannot detect camera try again. i have done this soo many times and restarted my computer soo many times its just not working.
  • vjcinnyc May 15, 2009
    Same problem with Canon SD1000. All was working fine until 2 weeks ago. Vista updates must have casued the problem but I can't restore to a point far enough back to resolve the issue. I also tried reboting several times, a new usb cable and also downloading the most up to date software from Canon as suggested below. Nothing works.
  • 3 Answers
I had the same problem and after a lot of research and attempting all the same things everyone else probably has I found the simplest answer possible. Go to Canon's website and download the most recent version of software compatible with your camera. It appears that some updates made to Windows can cause issues. Personally I was using XP on another computer fine but as soon as I went to Vista I started having these problems. I upgraded to version 6.1 of zoombrowser and it works flawlessly now. You may need to uninstall the device and software and start over but the new version will likely work.
Posted on Jan 11, 2009
I have
Posted on Jun 08, 2008
Windows 7 cannot detect canon ixus 100 is
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
May 07, 2014 | Canon PowerShot SD750 / IXUS 75 Digital...
Download photos
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jul 22, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Camera is not detected by computers I have a Canon SD750. Camera is not detected by the Windows XP SP3. A USB generic driver is added, and that's all. No removable media becames available. Canon software...
You may have a defective USB cable. Try a different cable, or try plugging the cable into a different USB plug on your computer. If neither of these work, the camera may have a defective USB plug on the camera. Double check that the camera is turned on. If all else fails, you can copy the photo files by removing the memory card from the camera and putting it in a card reader built into your computer, your printer, or use a separate memory card reader. You can buy them at most camera and computer stores - they are inexpensive, usually less than $20.
Dec 27, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
download this and clean the registry
http://www.filehippo.com/download_ccleaner/
kind regards and please don't forget to rate us
Dec 04, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Computer cannot detect canon powershot sd750
Consider NOT connecting your camera to your computer.
Aug 26, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Downloading images
Hi everyone
I figured out why my camera stopped working, my DPOF settings were wrong. I had to go and set the setting to select all of my images. Then i was able to download.
Jul 28, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Cannot Download pictures from camera to computer
There are numerous solutions for importing digital pictures from your camera to your hard drive. You can use Windows Explorer. By doing this, u maintain complete control over where ur digital images are stored on the computer. If you prefer to use an external application, Google's Picasa remains the best solution available. In addition to being a convenient way to manage your images, Picasa also includes common photo editing functions, supports some of the best photo organization works with low level photo data from your camera, and assists in uploading images to the Web or creating slideshows on your local system. Picasa uses the timeline features that shows when images were taken in relation to all your other images (which only works if your digital camera is set to the correct date). Picasa is free for Windows 2000, Windows XP, and Linux.
Oct 14, 2007 | Canon PowerShot SD750 / IXUS 75 Digital...
Memory "locked up"?
My camera does that too. If you mean that your camera says that there are no images, then all you have to do is start taking pictures all over again. these will show up in the memory. if the computer says that, im not sure what to do. hope this helps
Oct 11, 2007 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
220 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
