I need to replace the carriage belt for a HP T1100 44" plotter where can I get instructions on how to replace the belt..
  • 4,323 Answers
Hi
If you haven't bought the belt then you can buy the belt online and you'll get the instructions with the belt. You can buy the belt from this link---
HP T100 replacement belt
In case you have a belt with you then please look at the service manual for details---
HP T100 parts and service manual
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Aug 25, 2010
  • Daniel Scott
    Daniel Scott Sep 01, 2010
    I hope the issue got resolved. If it is resolved then please accept the solution or post back for assistance.
    Daniel
02.1.10 error plotter t610 and solution
The error code 02.1:10 means the plotter has a communications problem between the main logic board and the carriage PCA. The possible parts at fault are: The Carriage PCA, Trailing Cable, or the Main Logic Board, all available here: Designjet T610 Parts
You can watch this video to see how to remove the covers Designjet T610 Belt Replacement How To Video
The service manual is here: Designjet T1100-T610 service_manual
Sep 18, 2013 | HP Designjet T610 InkJet Printer
Error code 02.1.10
02.1:10 service station error- failure to reach home position .
you need a service tech to replace the service station within the plotter
Aug 14, 2013 | HP Designjet T1100ps Printer
During initialisation it shows dat there is jam
during the warm up cycle the carriage has to reach both ends of the scan platten if for any reason it is not able to achive this it throws the error Paper jam or 86:01 ( both mean the same thhing)
what you need to do:-
1) disconnect the plotter from the mains
2) open the central lid and using a torch look carefully along the carriage path for any obstacles or debris that may interfere with the carriage motion.
3) assuming there is no obvious blockages look carefully at the carriage drive belt to see if the imprinted teeth have worn off you may also see what looks like mouse droppings on the print platen
4) remove the right end cap - move the sercvice staion out of the way of the carriage and then gently ease the carriage to both left and right extents checking all the while for debris, leave the carriage on the left and leave the service station out of home position, return the mains lead and allow th plotter to initialize checking to see if the plotter is able to move both assemblies as required.if not then call out a qualifed enginner to replace defective drive belt or carriage assembly or indeed the service station
Jul 05, 2013 | HP DesignJet Z2100 InkJet Photo Printer
86:01 error in designjet 500 plus Paper jam...
System Error: 86:01
Problem Description: Carriage-Axis shutdown.
Corrective Action:
If this error code appeared but was NOT caused by a paper jam, then try the following:
  • Too much friction in the Slider Rod. Enter the Printer Information utility and check the Scan-Axis usage. If the percentage is close to 100%, then lubricate the Slider Rod.
  • The Carriage is bumping into the Service Station. If the carriage is stuck at the right hand side of the Printer and cannot be moved out to the center of the Print Platen it is because the Service Station cannot uncap the Printheads. In this case replace the Service Station/Aerosol Fan Assembly
  • Perform the Carriage Movement test
Aug 26, 2011 | HP DESIGNJET 500 InkJet Plotter Printer
My problem is after claibration i receive a message POWER OFF AND CHECK PRINTHEAD CLEANER PATH
Something is blocking the printhead cleaner assembly from moving forward and backward.
Turn the plotter off, open the printhead cleaner access cover (RH side) and see if you can move the cleaners to the front of the machine.
If you can move them fairly easily, then try (with the plotter still off) to move the carriage assembly (holds the printheads) to the left of the machine.
Check the condition of the carriage belt for frayed areas or missing belt teeth.
(I suspect a worn out carriage belt is causing the problem)
With the cleaner assembly to the front, and the carriage to the left, turn the plotter back on and see if the error continues.
May 03, 2011 | HP DesignJet 5500PS InkJet Printer
I have problem with my 5500 hp: check printhead path 2
The most common cause of the Check Print Head Path Error 2 is a worn out carriage belt. Open the top cover and locate the carriage belt. It is the long thin belt that extends the full length of the plotter. Use a light and look under the belt for debris that looks like pencil erasure crumbs. If the crumbs are there, the belt is disintegrating and needs to be replaced. See: http://www.lpscomputer.com/c-732-designjet-5000-5500-belt.aspx
Dec 01, 2010 | HP Designjet 5500 (42 in.) InkJet Printer
Check printhead path
Check for free carriage motion by unplugging the printer while the carriage is in the print area of the plotter. Open the top cover and move the carriage to check for free movement. If there are rubber crumbs under the belt, the belt is worn out and needs to be replaced. Manual can be downloaded from: www.lpscomputer.com/ec/manuals.htm
Parts available at: http://www.lpscomputer.com/c-736-designjet-1050c-belt.aspx
Oct 01, 2009 | HP DesignJet 1055cm InkJet Printer
Carriage belt replacement
Use the carriage replacement procedure in the service manual. Download here: www.lpscomputer.com/ec/manuals.htm
Aug 10, 2009 | HP DesignJet 500ps (42 in.) InkJet Printer
HP 750c+ plotter not responding
turn and unplug for 30 secs then open and remove / re-install each ink barrel according to your manual. You will have to go through the ink installation on your keypad one by one.
Apr 28, 2009 | HP DesignJet 750c plus InkJet Printer
Replacement carriage belt for HP DesignJet 800
The part number is; C7769-60182 runs at around $70.00.
This component needs to be installed by a service technician. You can seriously damage this plotter if you remove the carriage ribbon connectors and do not install them properly. You will fry the pca board (a $1,100 mistake).
Nov 19, 2008 | HP DesignJet 500ps (42 in.) InkJet Printer
463 people viewed this question
k24674
jasbo
jasbo
