Question about Sharp LC-46D64U 46 in. LCD HDTV
I have a lc46d64u, does not come on ops blinks and power blinks
  • 74 Answers
REPLACE PRE SCALER BOARD INSIDE OF TV
Posted on Aug 25, 2010
My Sharp tv was affected by a power surge and I have no power. Is there a way to determine if it is the power supply? Thanks
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Feb 12, 2016 | Sharp Aquos LC46D64U 46-Inch 1080p LCD...
LC46D64U
What is the problem you faces with your Sharp TV? Provide more details please. If you wish to get more details about the faults to Sharp flat panel TVs. check this link.
Feb 05, 2013 | Sharp Televison & Video
Samsung 2243nw blinks black and white
Are you sure its the monitor and not the computer or graphics card. Almost sounds like the computer has booted into some type of default mode or is at the DOS "command line prompt".
Not quite sure what "cable" you are speaking of sound like your talking about the power cable and what would not have any effect if not getting video data.
Are you sure that your Op System has come up?
Apr 17, 2012 | Samsung SyncMaster Computers & Internet
Aquos model LC46D64U...approx 2 years old..Won't power up and get the power light flashing 3 times then the OPC light once..which is repeated...Any ideas...I believe this is quite common with Sharp TV's
I have a Sharp LCD 46 in.tv do this often.Yes,it is.This problems,the tv Tuner signal board have problem,but the tv is still useable.The POWER and OPC light indications flashes.Just push the power switch again,wait see tv turn,not POWER and OPC flashes again,push the power switch agian and wait.Have to do this like 3 or 4 times sometimes,than the tv backlight will come on,tv will work.Don't know but,if u require to pushing power button more 10 or 12 times,the tv Tuner signal board don't take an turn on the tv backlight get the tv to work.The Tuner signal board is dead,time to replaced the tv Tuner signal board.
Oct 18, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
The camera doesn't power on. The battery is fully charged. The power button blinks and gows off.
Make sure the Lens assembly is pushed op to the camera body, Samething just happened to mine
Jun 26, 2010 | Olympus Stylus 7010 Digital Camera
Hifonics zeus z400 red diagnostic light blinks on a bench test ? whats that mean any one know.
yes you have a internal fault of the amp. the circuit that puts it into safe mode is bad and or a channel or power supply and that is a very small chip on the board know as a op amp. needs to be repaired.
Jan 12, 2010 | Hifonics Zeus Z400 Car Audio Amplifier
Have a hd52w56 when power up lcd blinks 3 times and then goes off... I have replaced the green tube(was cracked) and then was working . then the screen went green and the fuses popped, change the fuses and...
On your Deflection board it is the one on bottom to the left CK capacitors cp150 2200uf 16v if it is puffed up ont op it is Bad replace 2 more caps in same circuit cp114 cp120 220uf 35v resolder all pins on FBT flyback transfomer.
Nov 10, 2009 | RCA HD52W56 52" Rear Projection HDTV
The power red tringle is blinking and there is an ''error code?'' in the blue window E--03 that is laso blinking.
the amp is in protect mode because it see's a fault with the internal outputs of the amp. it has to be repaired.
could be a simple op amp inside causing the issue but requires great knowledge of electronics to diagnosis. hopefully this help. good luck
Aug 05, 2009 | Car Audio & Video
Mitsu. VS-50707 problems
12 = No error detected, check power supply.
check all your voltage coming out of the power supply and check the fuses.
Dec 10, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Open Questions:
See all Sharp LC-46D64U 46 in. LCD HDTV Questions
Sharp LC-46D64U 46 in. LCD HDTV Logo
133 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
