Question about HP Photosmart C5280 Printer
C5280 print cartridges can't move
I've just set up my new printer and it says on th little screen that I have to remove tape or cardboard which is preventing the print cartridges from moving, but I don't know where this tape or cardboard is, I cant see it... Can you help me?
Thanks,
Jess
  • 1 more comment
  • hbarnard1963 Oct 11, 2008
    I have the exact same problem! I couldn't make it all the way through setting up my printer b/c the screen prompt says "raise cover and remove cardboard or tape that is preventing the print cartridge from moving" ...but I can't find any tape or cardboard! Please help me so I can finish setting up my brand new printer and actually put it to use.
  • magnus488 Nov 19, 2008
    There is no tape or cardboard to remove. It just doesn't move.
    I have looked where the printer cartridges are installed. Nothing there. No cardboard. No tape. Nothing in the help files.
  • Anonymous Mar 15, 2014
    new hp 74 cartridge does not work. It says to remove cardboard and already did that
Well, this is probably a little too late for you, but in case anyone else has the same problem:
I had the same problem with my printer (it's an HP C4180) but here is hp's solution to the message telling you to remove tape or cardboard:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01389539&lc=en&cc=us&product=2512008&dlc=
Hope this helps someone.
Marla
Posted on Mar 06, 2009
The tape is ON the cartridge. It needs to be removed b4 U print.
Posted on Dec 18, 2008
Open the front door and look inside, where the cartridges are installed. Make sure that the carriage is moving freely and doesn't get locked.
Posted on May 05, 2008
Do I remove the metal strip on the printer cartridge before putting it in th eprinter?
Hi, There is a piece if tape to be taken off and then you can put it in the printer. The tape covers the print head for packing. Turn on your printer and open the cartridge bay and put it in the slot making sure the copper part meets the other copper part in printer. Then close cartridge bay door and your good to go.Note: The cartridge should snap in when installed correctly.
Nov 18, 2011 | Office Equipment & Supplies
Red exclaimation mark on C5280
Try first unplugging power cable, and see if it clears the error
Jul 29, 2008 | HP Photosmart C5280 Printer
HPm2575 All-in-One: Printer was working fine. I put in new toner cartridges (yes, I removed the tape first) but now I get the message: "Cartridge Blocked: Raise cover and remove cardboard or tape that...
The sensor that senses the Cartridge may be blocked by toner residue. Clean it then reinstall the new toner cartridge.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
Jan 04, 2011 | HP Photosmart 2575 All-In-One InkJet...
How do I align ink jets?
Microsoft Windows 95/98/Me:
(Applies to all printers)
  1. Click Start, Programs, Lexmark Series.
  2. Click Lexmark Control Panel.
  3. Click Print Cartridge installation.
  4. Depending on which cartridges you are using and which printer model you have, select Install Color Cartridge or Install Black Cartridge or Install Photo Cartridge.
  5. Carefully remove the tape covering the printhead of the print cartridge. Important: Be sure to remove all of the tape. Do not touch the copper area on the back of the cartridge.
  6. Insert the print cartridge into the print cartridge carrier.
  7. Push the cartridge back until it clicks into place.
    • If the print cartridge moves loosely in the carrier, it is not locked into place. Repeat step 7.
  8. Click the appropriate Cartridge Installed option in the printer software.
    • If you choose to install a new print cartridge, you will be prompted to align your print cartridges. The printer will print a page with a bi-directional alignment pattern. Follow these steps to align the cartridges:
      1. On the printed test page, locate the number under the Bi-directional Alignment pattern that comes closest to forming a straight line.
      2. Enter the number as the Bi-directional Alignment setting in the Alignment Cartridge screen.
      3. Click OK.
  9. Close the front cover of the printer.
Nov 13, 2009 | Lexmark JetPrinter Z11 InkJet Color...
Refer to printer documentation error message
I kept having the same problem as what was experienced by gobigforgod. What should I do ? Pls help.
Mar 26, 2009 | HP Photosmart C5280 Printer
How to change lexmark Cartridge
      3. Click OK.
Dec 09, 2008 | Lexmark X1150 All-In-One InkJet Printer
How to change cartridgeon HP desktop D4160
from HP's web site: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00641960&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN Step one: Replace the old print cartridge
  1. Make sure the product is turned on.
  2. Open the print carriage access door.
  3. Wait until the print carriage moves to the right side of product and is idle and silent.
  4. Press down on the print cartridge to remove it from the slot, and then slide it out of the print carriage.
  5. Remove the new print cartridge from its packaging, and then carefully remove the plastic tape by using the pink pull tab. Figure 1: Remove the tape c00442146.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00442147.gif
  6. Slide the print cartridge at a slight upward angle into the print carriage until it snaps into place. Figure 2: Inserting the print cartridge c00642241.gif
  7. Close the print carriage access door. WARNING: Keep both new and used print cartridges out of the reach of children.
  8. Wait until the print carriage moves to the right side of the product and is idle and silent.
Step two: Align the new print cartridge
  1. Load Letter or A4 size, unused, plain, white paper in the input tray.
  2. Open the printer Toolbox . Follow these steps to open the printer Toolbox .
    1. From the File menu in the software program, click Print . The Print dialog box appears.
    2. Click the Properties button. The Print Properties dialog box appears.
    3. Click the Features tab.
    4. Click Printer services . The printer Toolbox appears.
  3. Click Align the Print Cartridges .
  4. Click Align , and then follow the on-screen instructions. The product prints a test page, aligns the print cartridges, and then calibrates the product. Recycle or discard the test page.
Dec 23, 2007 | HP 83 3-ink Black UV Cartridge Multipack...
New printer, blank pages
To remove the printhead:
Ensure that the printer is on and open the printheadcover.
----The printhead holder will move to the center.
Press for some seconds the resume/paperfeed button.
----The printhead holder will move a little to the right.
Press and lift the tiny grey handle now visible at the left and in front of the printhead holder, now you can remove the printhead.
Sep 23, 2007 | Canon i80 InkJet Printer
HP Photosmart C5280 Printer Logo
1,294 people viewed this question
Seeker5211
Seeker5211
