Question about Sony BRAVIA DAVHDX275 Theater System
I have a Sony DAV-HDX275 Theater System that I'm trying to connect to an old 17 LCD Dell Monitor. The cable I have is a HDMI to DVI connector. My monitor will pick to the digital signal but nothing appears on the screen. I've tested to cable on my satellite box and it works fine. Any suggestions on how to get the DAV-HDX275 to appear?
    Sergeant:
  • 224 Answers
This is because it is transmitting an compressed encrypted signal and the monitor is made to recieve uncompressed signals,You can sometime get around this by changing the output to vga or analog on the theater system.
Posted on Aug 25, 2010
I need to connect a VGA dell monitor my Toshiba Laptop
HDMI is digital
VGA (the 15 pin connector) is analog.
If your connector has the digital to analog interface it should work, but likely it does not have that chip and thus will not work.
Your description of the problem tells me it may never work as you have it connected. Possibly it might be that the monitor is required to be powered on before the laptop is booted, but that only works in some cases.
I have also seen some work if a 2-step connector is used.
VGA to DVI connector, followed by DVI to HDMI connector.
DVI was the step toward digital that came before the HDMI standard was implemented and was only partially digital. DVI and VGA do not carry control signals nor audio. HDMI carries both those as well as the video.
YMMV but I think it would be cheaper and more efficient to actually purchase a monitor with a digital input (HDMI or DVI).
Without the digital/analog converter interface a digital output device (your laptop with HDMI out) can never operate an analog device (your Dell monitor with VGA input).
Mar 12, 2017 | Dell E193FPp 19" TFT LCD Flat Panel...
Dish Network 5.0 IR Remote Sony DAV-HDX275
The code for the 6.3 ir/uhf pro remote when set to uhf is 794. Fist hold down aux until all lights blink then press 2 then enter 794 and press #.
Jan 25, 2009 | Durabrand HT-3915 System
Can't get XBOX 360 to have audio through surround sound speaker
Make sure that you have the RC Cables (red and white) plugged into the audio ports that coincides with the component video inputs. If that wont work then try plugging the audio and video cables into the inputs for the satellite, since that works. That way you can isolate the issue. If it still wont work try using the XBOX 360 HDMI cable. That has both audio and video.
Jan 03, 2009 | Sony BRAVIA DAV-HDX267W Theater System...
Sony KF50we60 hdmi-dvi sound cuts when plugging into a ht-sf2300
DVI = HDMI without the audio connectors. So basically you need to connect your audio in some different way, PS3s allow you to keep your video signal as HDMI and change the Audio signal to component, so that is one way or doing it, not sure if the blue ray players allow you to do this though.
Nov 22, 2008 | Sony Grand WEGA KF-50WE620 Television
No sound when trying to connect PS3 to DAV-HDX275
It's likely the sound settings on one or more of your items are not set right or switched off.
Oct 16, 2017 | Sony BRAVIA DAV-HDX267W Theater System...
Codes for DAV-HDX275 BRAVIA
Amigo conseguiste resposta para trocar a regiao do home theather de 1 para 4? No aguardo, em.maciel@ibest.com.br
Aug 11, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Sony Trinirton TV and DAV-HDX 275 System
Here are a couple of the most common reasons for your problem:
Make sure you have selected the right input source on the DAV-HDX275 that your TV station source (cable, satellite, direct TV or whatever you get TV stations from) is connected to on the DAV-HDX275.
Also make sure that if you are using a digital input (HDMI, optical, or coaxial) from the TV station source, that the DAV-HDX275 in set for a digital input and on the right source.
If you are using an analog source (red and white RCA jacks) for the TV stations , make sure you do not have the digital input activated for that source on the DAV-HD275. You need to select the analog option.
You must also be sure that you have a cable, whether it is analog or digital, connected from the cable box to the DAV-HD275.
I hope this was helpful to you, it is always very important to double check all the connections and make sure the stereo is set to the right type of input (digital or analog).
If you have found this to be helpful, a good rating is always appreciated. Thanks and let me know if you need any more help.
Jun 22, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Home Theater System
YOU HAVE TO CARRY THE SOUND FROM YOUR SKY BOX OR CABLE BOX ETC,INTO YOUR SOUND SYSTEM,THEN INTO YOUR TV
Dec 29, 2007 | Audio Players & Recorders
Sony BRAVIA DAVHDX275 Theater System Logo
118 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
