Question about Honda Black Max 2600 PSI Pressure Washer
Blackmax 160,will not build pressure - Honda Black Max 2600 PSI Pressure Washer
    Problem Solver:
  • 18 Answers
Your bypass may be stock need to pulled and grease this happen when you let the unit seat for long periods of time
Posted on Aug 25, 2010
What kind of oil to ues on pump ona husky 2600 preassore washer
I use the SAE30 Non-detergent Mineral Pump oil as it is formulated for the high pressure pump.
Feb 28, 2015 | Homelite 308653009 Blackmax Husky Pressure...
Honda blackmax 2600pressure washer will not start
Is the gas tank topped off? Is the water hose plugged into it and turned on? Is the gas valve open instead of closed? is the throttle turned on fully? Is the spark plug wire attached all the way? Should work after all of this.
Jul 12, 2014 | Honda Black Max 2600 PSI Pressure Washer
Cannot find fuel shutoff valve
Some units does not have a fuel shutoff valve.
Sep 27, 2013 | Homelite 308653009 Blackmax Husky Pressure...
I have a porter cable compressor, but the pump won't shut off, and the pressure won't build it
Hi
Here are a few things to check, you may have already checked some of these.
*Electricity...Compressors will run best with full 115Vot 15AMP/Or 220V electrical supply from a circuit, over the shortest electrical cord as possible.
*Air Leaks..Place your ear close to the compressor and listen for air leaking, if you hear air that is not normal and means you have to locate and repair whatever it is that is leaking.
*Check the air unloader valve... The air unloader valve will blown out air when you turned off the compressor, that is normal.
But it should not have air leaking out of it all of the time. If so then it is faulty and in need of repair/replacement.
*Valves...If either the intake or exaust valves fail, breaks, or fails to seat, then your compressor will run 24 hours a day and never build up to the correct pressure for shut-off.
*Gaskets...Check to see if your gaskets have failed.
You could have a gasket failure between the pistons and you will never know it because it shows no external air leak.
If this situation happens then the air will only cycle between cylinders and never build up the correct air pressure.
One way to check the gasket is remove the air filter, then put your hand over the intake.
If correct then it will **** you hand against the intake.
If the valve or valves have failed then you will feel the air sucking in and blowing out.
*Piston Rings and Cylinder...The piston rings could be stuck,broken, or worn and not allowing the correct pressure to build up in your tank.
A worn cylinder will also contribute to the problem of pressure build-up.
*Pressure Switch...Check for air leaks at the pressure switch, it has a rubber diaphram that can fail and leak air out of the system.
Please take time to rate me
Bud
Nov 01, 2012 | Porter Cable Air Tools & Compressors
Changed fuel filter on my 05 Audi a4 3.0. Now I'm not getting no pressure build up by fuel rail
If the fuel pump check valve check valve is bad, the car may be unable to start. If the car does not start, turning the key so that it is one click away from starting, then repeating this process several times, may build up enough pressure so that the vehicle starts. If that is the case, the check valve is bad and needs to be replaced. check the fuel pressure regulater also. good-day ! If fuel pressure is low, disconnect the vacuum hose to the regulator. You should see an increase in pressure, if the regulator is not leaking. No change would indicate a bad regulator, check this first and get a fuel pressure reading on it to determine the pressure.
Apr 18, 2012 | 2005 Audi A4
Pressure not building in 1800 broaster
In order to build pressure, you need to first make sure that you have enough product to generate enough steam to build pressure. In a Model 1800 you need about 5-6 pieces of chicken or the equivalent to build a sufficient amount of pressure. You also have to have enough heat to create the steam, so check the oil temperature with a thermometer to make sure the actual temperature of the oil is close to the set temperature. If you have enough product at the proper temperature but no pressure is being generated, you need to determine where the steam is escaping. If the steam is escaping around the cover, replace the cover o-ring. If the steam is escaping from the exhaust stack in the back right corner of the unit, then your pressure regulating valve needs to be cleaned or rebuilt. The pressure regulating valve is mounted to the front of the cooking well just below the countertop. If the unit is several years old you should go ahead and get the rebuild kit for it.
Apr 09, 2012 | Kitchen Appliances - Others
I have a husky scout 1.5 gallon air compressor. It only builds pressure to about 38 psi. It doesn't build up any more pressure.
You have either warped or broken reed valves on the valve plate or a broken piston ring and/or a damaged cylinder. Any of these will allow a small amount of air compression but as the tank gets pressure in it, it gets harder to push more air into it. If the reed valves or piston to cylinder seal is compromised more and more air will leak past the bad reed or the piston as the pressure goes up in the tank. You'll have to disassemble the air pump to find out what's damaged and needs replacing.
Mar 03, 2012 | Air Tools & Compressors
Runs all the time. Why?
The pressure switch should cut off the compressor when cut-out pressure is reached. If however, there is a leak, or the reed valves /gaskets in the head/piston are faulty, the pressure will not build up enough to shut off. With the compressor running, spray soapy water on all fittings including around the head and drain valve. If no leak is found and pressure only builds to less than 50psi suspect reed valves. Parts are low in price and available from various on line stores including www.toolpartsdirect.com Good luck
Oct 15, 2011 | Stanley Bostitch CWC200ST 3HP Oil Lube...
Where can i find blackmax parts
there are a few vendors on the web, or you could go to Coleman, who bought Sanborn, the mfg for BlackMax.
Oct 23, 2009 | Air Tools & Compressors
Mercury 200 blackmax oil to fuel mix
Fuel oil ratios are,50/1. Eg.50 litres of fuel and 1 litre of oil. Hope this helps
Aug 29, 2009 | Furuno Navpilot 500 Designed for Use with...
Honda Black Max 2600 PSI Pressure Washer Logo
69 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
