Televison & Video Logo
Posted on May 05, 2008
I hav a samsung lns4095dx/xaa. The problem im have is when i turn it on i have lines on teh screen.
  • vietnameezbo Jun 15, 2008
    i have that too, just happened last night, one line across the screen towards the bottom of the screen
  • shbegack247 Jun 30, 2008
    need replacement lcd screen when i turn on alot of colorful lines run across the picture screen like a web , how much does one cost and where do i get one?
3 Related Answers
Anonymous
  • 304 Answers
  • Posted on Jul 17, 2009
SOURCE: samsung lns4095dx/xaa after 30min the screen goes
The first place to start is with the Main bd. The second cause would be the T-con bd. Have a trained Samsung tech troubleshoot to find out and repair the set.
Anonymous
  • 22 Answers
  • Posted on Oct 29, 2009
SOURCE: samsung lnt4065fx/xaa with 100's of colored lines
Sound like one of two things: A test screen, or a broken TV. More likely than not, your television is broken. Try hitting TV/Video on your remote, and if that doesn't work, power the TV off, unplug it, and plug it back in. If none of the works, it's time to call a repair man.
Anonymous
  • 14553 Answers
  • Posted on Mar 29, 2012
SOURCE: samsung hlr5688/wx/xaa vertical lines on half the screen
That is a DLP type set----likely a bad optical light engine used for picture and processing picture information from inside the set.
Not going to be the lamp either.
Testimonial: "Thanks! I was hoping it wasn't the dlp chip or the dmd board... Thanks again!!!"
Pixels on bottom of tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
I have a Samsung Hlr5667wax/xaa DLP TV and the screen has gone green/green plaid pattern.
when the color wheel stops the picture will be all over the place. and you will have lines when it starts to fail as its not going fast enough for the picture. wining sound is it wearing out.
I HAV E A SAMSUNG LNT375HAX/XAA AND ITS NEVER TURN ON MAKING A SOUND WITH 3 TIMES RED LIGHT ....CAN ANYONE HEP ME PLEASE
This problems,the power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
2helpful
2answers
When you turn on the TV it takes about 20 to fully turn on. sometimes we get pink lines on the screen.
CHECK POWER SUPPLY BOARD ...OR REPLACED
POWER BOARD NO:
Samsung BN44-00167A BOARD, POWER (VERISONS SX07,SX05,SS03,SQ01)
Samsung BN44-00165A BOARD, POWER (VERSIONS SX08,SX06,SS04,SQ02)
Samsung LNS4041DX/XAA White horizontal lines
Hi my name is Roety,
I can help you with your issue ,
If the lines are present on every input you most likely have a bad screen. We usually replace the mainboard first because its cheaper .
Check part prices at encompass.com login as a guest
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
1helpful
Our Samsung Model HLP5063WX/XAA - dark images
I suspect that you may need to replace the ballast for the lamp and the power supply board.
2helpful
Samsung lnt4065fx/xaa with 100's of colored lines
Samsung lns4095dx/xaa after 30min the screen goes
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
