Question about New Balance 1400 Treadmill
I can not get the treadmill to power on. - New Balance 1400 Treadmill
    Problem Solver:
  • 6 Answers
I have the same problem and have isolated it to the main console board. When you flip the main power switch, does the console display light up briefly and then go dark?
Posted on Jan 02, 2011
Epic 550 treadmill
If you wish to get some derails about treadmill repair then check the below added link
http://electro-medical.blogspot.com/
Jul 07, 2016 | Epic View 550 Treadmill
The console does not power up...I reset the reed sensor to go closer to the magnet, still does not get power. Is there something else I can try
Trouble Shooting Treadmill with No Power - YouTube
? 1:23
https://www.youtube.com/watch?v=N6Yg5S0WML8
Jan 20, 2011 - Uploaded by WilkinsFitness
Trouble Shooting Treadmill with No Power ... Disconnected wiring harness at console can also cause no power as well as faulty harness.
Troubleshooting a Treadmill That Won't Start - Livestrong.com
www.livestrong.com > Sports and Fitness
Jun 6, 2015 - If your treadmill doesn't start, you will need to troubleshoot the possible cause. ... If your treadmill is not properly plugged in, power surges and fluctuations in your ... If the console lights up, but the treadmill won't start, the motor ...
How to Determine If a Treadmill Console Is Broken ...
Dec 29, 2015 | Exercise & Fitness
GE3100T treadmill stopped working
HI,
All the treadmills have a power switch with Auto reset. If there s any overload detected it will automatically reset to off position To prevent any further damages. Just check the power switch of the treadmill. If its it off position then turn it one and check the treadmill. If the switch again rest to off position then try to call for a tech to repair the treadmill.
Ajin
Feb 23, 2013 | Exercise & Fitness
I have an Ifit treadmill. I was changing speeds and it turned off and won't restart. It beeps when i turn it on but no lights on console.
Power issues with ProForm treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the machine is plugged into a working outlet, make sure the safety key is in the keyhole on the console. If the safety key is not plugged into the machine or if it is pulled out during operation, the treadmill will not operate.
Finally, make sure the circuit breaker located on the frame near the power cord is set to "Reset." The circuit breaker is set to "Reset" if the top of the button is pushed in. When the breaker is tripped, push it back to the "Reset" position and wait five minutes before powering on the treadmill.
If the ProForm treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Increase Engine Horse Power.
Jun 02, 2012 | Proform Exercise & Fitness
System check failed
  • Press the "On/Off" switch to turn the treadmill off.
  • 2Unplug the power cable at the bottom, base of the treadmill.
  • 3Push the safety switch in.
  • 4Plug the cable back into the treadmill and set the "On/Off" switch to "On."
  • ssincerely. Merry Christmas.
    ERNESTO CUADRAmanagua, nicaragua
    Dec 26, 2011 | Tunturi T80 Programmable Treadmill
    Treadmill (powerfirst treadmill) shorting out power . overload switch shorting out power.? how can we fix this problem?
    Check here with powerfirst spare parts
    http://www.partsfortreadmill.com/parts-for-treadmill/treadmill-controllers/power-first-pf906-treadmill-controller.html
    and also here for treadmill help in general
    http://www.treadmillsrepair.co.uk/
    http://www.partsfortreadmill.com/repair/repair.htm
    Jun 14, 2011 | Sport & Outdoor - Others
    The power is on but it won't run
    Power issues with treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
    If the treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
    Thanks for the rating Good luck
    Dec 22, 2010 | Exercise & Fitness
    It does not turn on says safe
    This message appears when you remove the Safety key.
    Kindly provide me with the make and model of the machine?
    Are you sure that the key is intact? Is it properly placed?
    Thanks!!
    Aug 21, 2010 | Exercise & Fitness
    No Power To Console
    treadmill will not start
    Dec 16, 2008 | Endurance TF6iHRC Treadmill
    New Balance 1400 Treadmill Logo
    160 people viewed this question
    Top New Balance Exercise & Fitness Experts
    Matt Olenzek
    Matt Olenzek
    Howard
    Howard
    Are you a New Balance Exercise and Fitnes Expert? Answer questions, earn points and help others
