Question about Xerox XA7-192i 19" LCD Monitor
I have a xerox xa7-19i monitor and it keeps tripping the power. i have had a look inside and nothing is shorted or blatently blown so i dont know whats wrong, anyone know what to do?
  • posty07 Aug 29, 2010
    Hi thanks, no it was tripping the whole house power. but yes ive had a look inside and none of the capacators seem to have a bulge or look burnt out. the wires are fine and everything. i realise there must be a short circuit of some sort but i cant see what it is. everything looks fine, any ideas what it may be? i know you said probably a resistor but im not so sure, thanks again, adam
    Sergeant:
  • 223 Answers
I assume you mean the monitor itself keeps shutting off and on? These LCD style monitors are infamous for failed power supplies, due to faulty capacitors inside the unit (which are very hard to detect). the capacitors buldge and sometimes leak when they are faulty. they work for a very short time, then fail. BE VERY CAREFUL inside any monitor as Capacitors Can give you a whopper of a shock, Even after being unplugged. if its your house power breaker, Id look to a frayed power wire, or the wall receptacle. Try a different outlet see if the problem moves with you, which would point to the monitor itself.
Posted on Aug 25, 2010
My xerox monitor xl-795d will not power on
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 30, 2010 | Xerox XL-795D (Black) 19" LCD Monitor
XEROX Monitor Product No : XM3-19W Model No: 900W Power: AC 100-240V 50/60Hz 1.2A Problem : " RGB Analog " When Starting the monitor afte 3 second display and then Black screen.
Common failures in LCD monitors are due to bad caps as hown in my albums.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Basic LCD monitor troubleshooting guide:
Oct 06, 2010 | Xerox XG-91D 19" LCD Monitor
My xerox monitor will not start up without turning it on and of a number of times
Aug 20, 2010 | Xerox XG-91D 19" LCD Monitor
When i try to turn on my moniter the light keeps flashing and nothing happens, i tried unplugging it and plugging it back in nothing seems to work
Look inside first for bad DC filter caps in the power supply.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Aug 19, 2010 | Samsung 19" LCD Syncmaster 931BW Monitor
I have a Xerox xr3-19GS which will not turn on. It was working fine until we had a power failure while it was on and we were not home. It was plugged into a backup power supply, but this ran down before we...
Are you getting any indicator light on the front panel? Main AC fuse is OK? You need to check and see if the 5vdc and the 12vdc power supply is working, these two voltages should be present the minute the monitor is plugged into the wall outlet.
If you can send me pictures, then I may be able to guide you more, budmrtn@aol.com
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Jul 22, 2010 | Xerox XR3-17GS 17" XtraBrite LCD Monitor
One day the monitor just would not power on
First thing to check, fuse and DC filter caps in the power supply.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Jun 25, 2010 | Xerox XA7-192i 19" LCD Monitor
I have a xerox monitoer flat screen,it cuts off after about 2ominutes on my pc then i have to switch the monitor off then put it back on after another 2ominutes then it comes on again but will cut off...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Jun 02, 2010 | Xerox XA7-172i 17" LCD Monitor
Monitor does not have a picture and no green light.
Power supply will be the first place to check.
May 19, 2010 | Xerox XG-91D 19" LCD Monitor
Screen won't turn on - power button continues to flash. Checked cords - unplugged plugged back in - blue light keeps flashing. Hit keys on keyboard and on mouse - nothing. Tried holding down power button...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed LG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 19, 2010 | LG W1934S-BN 19" Monitor
Xerox XA3-17 makes noise, flashing, than nothing happens.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Apr 08, 2010 | Xerox XA3-17B 17" LCD Monitor
Xerox XA7-192i 19" LCD Monitor Logo
124 people viewed this question
Top Xerox Computers & Internet Experts
Jack McCann
Jack McCann
steve morris
steve morris
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
