Question about Sharp XL-UH242 Shelf System
I plugged it in and everything is connected but it wont turn on. All i see is the red flashing timer light. Help please
Why does my kinivo bth220 headphones have a flashing red light on them no matter how long i charge them and they will not turn on
The batteries won't charge. You might want to google around for replacement batteries.
First I'd try a factory reset. PRess the +, - and multifunction button for 6 seconds until the blue light flashes and it shuts off. When you turn them on next, it's in pairing mode and try again.
Aug 10, 2014 | Kinivo Bth220 Bluetooth Stereo Headphone -...
I have a 59028 timer, and when I turn the lights on they flash - versus staying on.
59028 is a Woods in-wall timer.
See Woods timers and manuals:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Manual for 59208 timer:
http://waterheatertimer.org/pdf/Woods-59018-59028.pdf
The lights are blinking so the red and white wires are connected together.
Here's what to do Switch has 2 wires.
1) Green wire connects to bare copper
2) Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
4) If electric box does not have white wires described above, then connect timer-white to bare ground.
5) Turn on electricity, and push ON-OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Nov 20, 2010 | Hardware & Accessories
I have a 56' that wont show picture
Power board is bad.. I had the same issue.
Apr 13, 2010 | Samsung HL-S5679W 56" HDTV
When I turn on my N64 with everything plugged, the red light wont turn on!
What's the RED light For ? usually indicates charging ..if flashing if steady then it's fully charge to a GREEN light unless it's already Solid RED
Sep 18, 2009 | Video Game Consoles & Games
Blackberry pearl wont stay on and red LED light keeps flashing
my phone wont stay on and when it does come back on it shuts right back off. the LED light on the front keeps flashing red. ive taken the battery out and everything and nothing seems to work. help please!
Apr 07, 2009 | RIM BlackBerry Pearl 8100
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
Stand by/timer light flashes red television will not turn on
I will need to know the model number of your set to help you as well as if the light blinks a certain number of times in between pauses. Please respond to this same post.
Jul 16, 2008 | Televison & Video
Tv wont turn on after fixing convergence problem
Check the pins with a strong magnifying glass to make sure they are solderd correctly with none of the pins bridged with solder, then recheck all the wire connections to make certain they are correctly hooked up.
Apr 16, 2008 | Samsung HC-P4752W 47" Rear Projection...
Whirlpool door lock
hi
We have a whirlpool AWO?D4705 washing machine. The red light is flashing to say clean pump.wee cannot find our manual , can you help please?
Jan 20, 2008 | Candy CNW136 Front Load Washer/Dryer
Well, I have found out that the number of red light blinks is a "blink code" that indicates the nature of the fault with the TV. Usually these are various failures of internal fuses or circuit boards. There's a fair amount of information on threads at techlore.com on this, so try searching there. Teh specific codes and manuals are usually it seems under license from Sony and not available for free to the public. Sorry!
Oct 17, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sharp XL-UH242 Shelf System Logo
44 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
