Question about Siemens Optipoint 420 Standard Op420 Voip Ip Phone
We had a storm go through and now I have six Optipoint 420 Standard phones with the LAN port not working. I've reset the phone to factory settings, reapplied my configuration, and installed the 420std_v5510.app software and successfully ran the limited Ping from the phone's Web diagnostics page. What can I do to fix the LAN port?
    Sergeant:
  • 223 Answers
I have a hard time believing six would all fault the same way. I would first check your router/switch for problems which is common to fault on power spikes,(often fixed with a 1 minute power down) then check your phone servers connection. hope that helps you. cheers
Posted on Aug 25, 2010
  • Lee Payne Aug 25, 2010
    Thank you gurvy for your quick reply. The phones are on different POE switches, in different buildings. I did plug the computer directly into the CAT5 jack and had connectivity on a few of them so I am fairly certain it is a problem with the LAN port. The VoIP side of the phone is working fine and it can make and receive calls. I was just hoping there was diagnostic software or a component I could replace to keep from having to limit these phones to areas where there are no computers.
    Thanks again - LP
Change internal directory on optipoint 500
The extension name and extension number are set in the system programming. Use manager 'e' and change them in the station view. If you are swapping people around and want them to keep their extension numbers and names, you should re-patch the cables feeding to the wall sockets rather than change the programming (if you can).
Oct 20, 2014 | Siemens optiPoint 500 Standard Corded...
How to put your lg 420 back to factory setting
in the menu under settings/phone settings there should be an option to restore your pone to factory defaults.
Jun 15, 2011 | Cell Phones
How to access optipoint 410 config menu
Press 1, 0 & 3 at the same time, this can be quite awkward & may need several attempts to succeed, but it does work.
Jan 21, 2010 | Siemens optiPoint 400 IP Phone
BlackBerry Storm 9530 Network Blocked
My BlackBerry 9530 network is block.and MEP check failed. How can i do pls pls help me
Sep 17, 2009 | Cell Phones
Can Siemens optiPoint 500 phone be used at home
An "Optipoint 500" phone can not be used at home!
It is a digital phone, specifically designed for Siemens digital phone systems. Do not plug it in at home. That could damage the phone or may knock your phone line off.
However you can use a "Optipoint 500 IP" phone at home for voice over IP calls. But this would be connected into your broadband router and would connect via the web to your companys Siemens phone system.
Nov 25, 2008 | Siemens optiPoint 500 Standard Corded...
Features keys
To add an Extension Key, enter [*91] and choose “Repdial Key” from the menu. Enter an extension or group number and press the [ü] key.
Sep 17, 2008 | Siemens optiPoint 500 Standard Corded...
Brother mfc 420 network
I don't have enough info to suggest a solution.
Here are my questions: Is it attached to a router? Did you install it on your PC as a TCP/IP printer? When you go into the printer properties, what port does it list?
Mar 15, 2008 | Brother MFC 420CN All-In-One InkJet...
Changing the time on a siemens optipoint 500
here you go , follow this on your main phone to reset your time.
press sevice button ( top left )
press *95
press *95 again and press tick
press tick again
press right arrow key until you come to time
press tick key . then press *
enter time (hhmm) then tick key
press main service button and your done.
Jul 12, 2007 | Siemens optiPoint 300 basic...
Siemens Optipoint 420 Standard Op420 Voip Ip Phone Logo
126 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
