Question about Whirlpool 9.7 Cu. Ft. Top-Mount Refrigerator - White-on-White
Whirlpool model number ER2CHMXPL02. Freezer drains into refrigerator and water puddles in bottom of fridge. The pan underneath is dry.
  • 4,793 Answers
Use a syringe to blow up the drip hose from the drip tray to clear the s... in the pipe .
Posted on Aug 25, 2010
Water leaksin bottom of freezer whirlpool GX2FHDXVBO4
most of the time drain in freezer is clogged,,,, must be cleaned out
or bottom drain pan underneath fridge has been knocked unlevel
Aug 30, 2014 | Whirlpool Refrigerators
Ewave ERW121 puddles in bottom of fridge
If you have located the drain pan, look for a flexible tube that extends into it. That's the drain line. You should be able to trace the tube back into the freezer section and you will be able to clean it
May 21, 2013 | Refrigerators
My whirlpool French door fridge is leaking all over the floor. The drip pan underneath is bone dry. I can't find the drain hole inside the fridge to see if it is clogged. Is letting it thaw for tw
there is a water tube connection at the bottom of door on hinge side that has a spring and allows it to swing with door. it also has a fitting there so the door can be removed.it is the tube running inside the door to the ice water dispenser. if it has one, it can leak at the fiting
Jul 07, 2012 | Whirlpool GX5FHDXVY Stainless Steel (248...
Occasionally my freezer will defrost and will make a big puddle of water on the floor.
the drain from the freezer is probably plugged as well theres a drain pan under the fridge , look underneat an u will probably find the problem , make sure the drain pan underneath is not full of stuff
Oct 16, 2010 | Miele KFN8762SDED Bottom Freezer...
GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 19, 2010 | GE Profile TPX24PBDCC Side by Side...
Where is the defrost drain in a whirlpool refrigerator model number ET1FHMXMQ00
It's part 7 in this diagram. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5149338&diagram_id=929467#d929467
It's behind the rear cover inside the freezer. From there the water drains to the drip pan underneath the fridge where it's evaporated by the condenser fan.
Jan 30, 2010 | Whirlpool ET1FHTXM Top Freezer...
Whirlpool refrigerator leaking from top of unit
Listened to other posts and figured drain plug was clogged. It was with ice. Removed bottom pan and back panel of freezer, removed ice on bottom, put hot water in drain to thaw ice until it flowed into pan underneath fridge. Thanks for the ideas.
Jun 02, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
No cooling no freezing puddle on floor
Your defrost drain line is frozen over. Turn off the fridge and defrost the drain in the lower rear portion of the freezer.
Apr 23, 2009 | Kenmore 53642 / 53644 Side by Side...
Water in bottom of fridge
Thanks to all who spent money or shared their experience to have somebody do this repair, and I really mean it.
I have a Whirlpool TopLoad Fridge (not a side by side).
Things you'll need
30 minutes
Small socket for cardboard panel on lower back and panel inside freezer
Bicycle Pump
4 Towels
Hair Dryer
1. Take everything out of freezer
2. Turn dials off in fridge for both compartments
3. Pull fridge out so you can get behind it and unplug it
4. Be vigilant of ice maker line if installed
5. Pull cardboard panel off on back
On the left side you should see the back of the skinny drip pan and a small line. That line goes from the freezer and is most likely clogged.
6. Blow dry the back of the freezer enough so the ice is thawed at the bottom of the back panel.
7. Remove the two screws on the back panel. You may just be able to pull it toward you enough to get behind it. You'll see the coils and fan, and underneath these you may see some ice sheets and there should be a hole. That is the drain line that is clogged. I heated up some water and poured it over the drain to thaw the line. You may want to remove the crisper drawers and put some towels down there to catch the overflow. Once the ice is thawed enough at the drain. Go to the back of the fridge and place the end of the bicycle pump at the bottom of the drain hose. Apply pressure to get a good seal but keep pumping. You may have to go back and forth between pumping and thawing, but you'll know it is clear when you hear air going into the freezer and then the wonderful moment when water drips into the drip pan as advertised!
Keep those fridges less full so that the door stays sealed and keep the seal clean and also keep your doors from having too much stuff so the weight of the door doesn't pull away.
Okay, put it back together, turn everything on and be careful of your cord and lines when pushing the fridge back. Thank the Lord ours has wheels and man,was it cruddy underneath. Vacuum those coils underneath the fridge too for proper air circulation.
Blessings to you!
tay
Sep 15, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool 9.7 Cu. Ft. Top-Mount Refrigerator - White-on-White Logo
192 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
