Question about Briggs & Stratton Garden
10 hp. riding Snapper mower. Engine turns over but won't fire no spark. I replaced the coil and spark pplug, still won't start.
  • 653 Answers
SOURCE: snapper rear engine riding mower clutch
It is time to replace the driven wheel. When you flip the mower up on the back end (after closing the vent on the top of the fuel cap), the driven wheel is the disc that has rubber on the outer edge that rides on the silvery disc that comes off the end of the motor. The last time I bought one was about 7 years ago, at which time it cost me about $7.85. I would expect it to be around $11-12 these days.
Posted on Apr 07, 2009
wadembly
  • 489 Answers
SOURCE: How to replace lower deck spindle bearing on my
take the deck off or take the belt off of pulley there is a nut on top of pulley loosen nut with a brass hammer hammer it down & it should drop the spindle out to replace bearings
Posted on Jul 09, 2009
mowerman1857
  • 389 Answers
SOURCE: I have a Snapper rear engine riding mower. Mod#28085S
If one goes to the starter, the other has to come from a 12 volt source, either ignition switch or battery
Posted on Oct 04, 2009
bbreton
  • 437 Answers
SOURCE: Snapper Hi-Vac riding mower that won't start with starter
You may need a 300cca battery, an ignition switch or a solenoid to get things going again. I also would check to make sure the starter gear has not locked in the flywheel teeth; it will burn up the starter. You should be able to go to the snapper website and put your model of mower in and find the parts and diagrams you need.
Good Day.
Posted on Oct 26, 2009
SOURCE: belt diagram for snapper lt 200 riding mower
replace drive belt Snapper LT200 tractor
Posted on Jul 01, 2011
No spark to plug motor truns over but no start
if the motor turns over but there is no spark, i would put a new spark plug in first if that doesn't solve the problem, it will be related to the coil. check the coil wire to be sure it is not cracked and damaged. there are many you tube videos that show how to check and replace a coil. relatively easy job. good luck
Feb 29, 2016 | Snapper RE100 28" 10HP Rear Engine Riding...
Hot fire one coil and orange fire on other
what is wrong with an orange spark? is it a high performance race engine? if not then as long as there is spark, fuel, air, and compression it should run. any one of those missing and it won't
Mar 28, 2013 | kawasaki Fh641v 21hp 21 Hp Riding Lawn...
Engine wont fire....
There should be 1 black wire that grounds the coil(s) for kill. Be sure this black wire is not grounded when switch is in on or start position. It will be connected to the coil(s) at the flywheel.
Feb 10, 2013 | Snapper 21 hp* Briggs & Stratton...
My Kohler Command 20 HP running fine, shut down, won't restart. How should I troubleshoot this problem?
check for fuel try starting fluid if it fires on that then you have spark if it does not then you have a spark problem and seeing the command engine has two coils check the safety switches on the mower side
Aug 11, 2012 | Garden
I have a snapper 28 hi vac riding mower that won't
first try and start it with carb cleaner or starting fluid with the air filter out if it fires then its a carb/fuel problem if not it could be a spark problem remove the plug connect hte wire back up and crank the engine over while looking for spark if no spark disconnect the kill switch wires from the side of the engine should be a single wire near the throttle cable if spark with that off the problem is in the wiring or safety switch if still no spark its the coil
Apr 23, 2012 | Briggs & Stratton Garden
I have a snapper sr1030 but it is not firing i have replaced spark plug
It will take 3 things to make it run. Fuel, fire and compression. Try this. Squirt a little starting fluid in to the carburator and try to start it. If it fires you then need to check to see if there is gas getting into the carb. If it doesnt fire, you are not getting any spark due to a shorted coil, bad coil or shorted wire. If it has been outside for a while where it is damp, your magneto and coils may have enough rust on them to prevent them from firing.
Mar 11, 2012 | Garden
I have a John Deere riding mower Model RX75 which will not start, I replaced the spark plug and it ran just fine for one day except that it Back-fired when I shut it off it never did this in all the years...
Weak spark can be caused by a bad ignition coil. The ignition coil is located under the engine fan/shroud, next to the flywheel. Check to make sure the coil lead and plug cap are not grounding against the engine robbing your spark as well.
Aug 03, 2011 | John Deere Garden
Snapper mower electric start problem
On most mowers, that red wire will connect to the battery. that could be your problem.
you didn't say if it is a rider or not, or how old it is.
Touch the wire to positive post on the battery, with the key off, remove quickly if it sparks.
if no spark, hold it to the battery while turning the key.
if the engine tries to start, connect it permanently.
Apr 14, 2009 | Garden
Garden Logo
281 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
