Word perfect 12
Every time I click on word perfect to open it or open a document, it opens and closes within seconds, whats going on and how do I fix this!
  • 3 Answers
If this is a behaviour that has recently started may be you need to scan you machine for virus...It might be a complication from viruses...
If the problem still persists try to reinstall the package again...
lets see if that works..
Posted on May 06, 2008
How do I access the backup files in my Word Perfect 12 program?
When you click on the Open or File tab, doesn't a drop down list come on with a choice to click on that file? I am not familiar with newer Word Perfect but, I do recall this
Nov 04, 2017 | Corel WordPerfect Office 12 Standard...
Tip
2010 BMW 528XI Garage Door Opener Homelink Setup
**** >>> This setup I performed with my new 2010 BMW 528XI Garage Door Homelink and Chamberlain Garage Door Opener <<< ****
Chamberlain:
01. Power off or unplug the garage door opener motor power supply (which is mounted on ceiling of the garage) ;;;
02. keep the garage door opener transmitter in your hand (do not press any button at this time) ;;;
03. In your 2010 BMW 528XI Homelink button (which resides under rear view mirror) press the 1st and 3rd homelink button together for about 30-40 seconds (i.e., until the yellow light blinks fast) and when the yellow light next to the homelink button blinks fast release from pressing the (homelink) buttons ;;;
04. now hold the garage door opener transmitter closer (means within 2-4 inches) to the homelink button (either 1st or 2nd or 3rd) whichever you are planning to program to open the garage door ;;;
05. now press the garage door opener transmitter button and chosen homelink button (either 1st or 2nd or 3rd whatever you need) together ;;;
06. the yellow light (next to homelink button) initially may blink slowly but after few seconds (may be 10-20 seconds) will blink fast; once it started blinking fast release from pressing both garage door opener transmitter and homelink button ;;;
07. Now plug or power on the main garage door opener motor (which is mounted on garage ceiling) ;;;
08. On the main garage door opener motor (which is mounted on garage ceiling) press the "LEARN" button (once you press it may have yellow/orange color light; make sure the light is on) ; then within 30 seconds do the next steps #9, #10, #11 very carefully ;;;
09. go to your car and press the homelink button you programmed and hold it for 4 seconds and then release it --> 1st iteration ;;;
10. again hold the same homelink button you programmed and hold it for 4 seconds and then release it --> 2nd iteration ;;;
11. again hold the same homelink button you programmed and hold it for 4 seconds and then release it --> 3rd iteration ** important note; generally three iterations are not necessary; and steps #9, #10, #11 must be performed within 30 seconds ** ;;;
12. during one of the iteration you will hear "CLICK" sound one-time from Garage door motor (which is mounted on ceiling) and if you have light attached with it; it will blink once (** if you hear the CLICK sound and/or light blinks once**) then the particular homelink button is programmed ;;;
13. now press the programmed homelink button; the garage door will open or close (but always it will take 3 or 4 blinks in yellow light or 2-3 seconds before the garage door opens or closes and which is normal) ;;;
** Thats it, your 2010 BMW 528XI Garage Door Opener Homelink setup is complete ** ;;;
You can program rest of the homelink button the same way but following from the steps between #4 and #13 ;;;
Hope this steps will help you to program chamberlain Garage door opener in 2010 BMW 528XI Homelink. ;;;
** possibly the above same steps may work with other BMW 5-series cars homelink too (but I'm not sure) **
on May 29, 2010 | BMW 528 Cars & Trucks
HOW DO YOU PUT REFRIG IN DEFROST MODE WHEN IT HAS ELECTRONIC DEFROST CONTROLLER
You didnt give the make of the ref.; But your solution is here for most all
The newest defrost feature in modern fridges is the electronic adaptive defrost control board. *Maytag has one version, see picture...to put this adaptive defrost style of fridge into defrost, short with a small screwdriver between L1 and test on the adaptive defrost board, wait 3 seconds and you should hear a "click" noise from the relay and the fridge will shut off and go through a defrost cycle. A close up common way *this* version of the Maytag/JennAir control is wired.
Amana also has a version of adaptive defrost, see info sheet for some help on the Amana version. Press refrigerator light switch five times in six seconds to initiate defrost cycle. Pressing five more times within six seconds will cancel defrost and go straight into the run mode. Similar operation on both bottom mount and SxS refrigerators. After the defrost terminator/thermostat opens, six minutes of dwell time occurs before the compressor and condenser fan motor will operate. After defrost terminator/thermostat open, 10 minutes of dwell time occurs before the evaporator fan motor will operate.
Frigidaire has also jumped into the market with an adaptive defrost board. The fresh food section light switch and light bulb must work. To initiate a defrost cycle, open the door and push the light switch in and out 5 times within 6 seconds. The compressor and fans should shut off and the defrost heater should come on. Open the door and push the light switch in and out 5 times within 6 seconds to remove the refrigerator from the defrost mode and back into a cooling mode.
Frigidaire - referance model FSC23F7DSB3
This product comes equipped with an Adaptive Defrost Control (ADC). To activate manual defrost, press and hold the Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. A ?¿½d?¿½ in the freezer temperature window and ?¿½F?¿½ in the refrigerator temperature window will display when the heater is activated. To deactivate manual defrost, press and hold Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. ?¿½d?¿½ and ?¿½F?¿½ will be displayed until the defrost cycle is complete. (approx. 8 minutes)
For some Whirlpool refrigerators - some Kenmore refrigerators are made by Whirlpool ( 106.######## )
The refrigerator/freezer defrost system can be checked by manually initiating a defrost cycle. There
are two methods of initiating the ADC Test Mode.
First Test Method:
1. Turn the thermostat off for 15 seconds.
2. Turn the thermostat on for 5 seconds.
3. Turn the thermostat off for 15 seconds.
4. Turn the thermostat on for 5 seconds.
5. Turn the thermostat off for 15 seconds.
6. Turn the thermostat on for 5 seconds.
7. Turn the thermostat off.
In 3 to 8 seconds the ADC should turn on the defrost heater (with the bimetal closed). NOTE: The test mode will terminate when the bimetal opens. If the refrigerator/freezer is already in defrost, Test Mode can be terminated by unplugging the refrigerator/freezer from the wall outlet and waiting 30 seconds before plugging it back in. The refrigerator/freezer should immediately go into cooling mode if the thermostat is closed.
If this first test procedure fails to make the ADC initiate a defrost cycle, try the following procedure to make the ADC begin the Test Mode.
Second Test Method:
1. Disconnect the refrigerator/freezer from the wall outlet for at least 30 seconds.
2. Turn the thermostat off.
3. Reconnect power to the refrigerator/freezer.
Within 3 to 8 seconds the ADC should turn on the defrost heater (with the bimetal close). If the unit fails to go into the defrost mode during this test, the problem may not be with the ADC. A defective bimetal may be the cause of the failure. The ADC will only go into a test mode if the bimetal
is closed. If the ADC senses an open bimetal it will return to the cooling mode within 3 to 8 seconds.
HELPFUL HINT: Upon entering the Test Mode, the relay mounted on the ADC board should turn off the compressor and turn on the defrost heater. Listen for the relay to click.
?¿½ If the relay clicks one time when entering the Test Mode, check for continuity in the defrost heater.
?¿½ If the relay clicks two times, check for an open bimetal.
Maytag S-S Refrigerator MSD2756GEW forcing defrost cycle
I replaced my defrost heater two weeks ago, but the frost built back up on the evaporator coils. Replaced the adaptive defrost board with new ( Maytag p/n 6100598 8 ) board. Want to force a defrost cycle to see the heater work, so I shorted the L1 pin to adjacent pin (now called DOOR instead of TEST) for three seconds and nothing happens. Compressor keeps running, fans still going etc. Tried pressing the door switches 5 times in 6 seconds and that doesn't work either. Any hints on how to get the defrost cycle to initiate?
This might help, a copy:
The issue is that some 12002104 ADC boards have been shipped in the 61005988 ADC board box. Do not reorder the board, the 12002104 board will function the same in place of the 61005988, but you must use the forced defrost method for the 12002104. Jumping "L-1" and "door" will not initiate the forced defrost function.
To Initiate Forced Defrost Cycle:
Cycle cold control on and off three times in six seconds. The cold control needs to be left in the closed (call for cooling) position for the defrost system to energize on all platforms. It is not enough to cycle the cold control knob, the contacts must actually open and close (open doors for a period of time if necessary to force the control to call for cooling). In most cases, you can hear the contacts open and close if they are doing so.
To Terminate Forced Defrost Cycle:
Disconnect power for five seconds.
You were right. I cycled the cooling controls three times and it went into a defrost cycle. Thanks.
Aug 08, 2011 | Refrigerators
When I have one document open and want to open another one, Word superimposes the second document on the first. In other words, I don't have two windows open, rather one. I don't know what I did to program...
You can't open or view two documents at the same time, when you open a new document, of course it will minimize the first one and the second will be open. All you can do is to switch from document to another.
pressing ALT TAB, let you switch from documents or files that are currently open.
(hold ALT key then press TAB)
Jul 18, 2010 | Microsoft Windows XP Professional for PC
MODEL #WHDRR418G1WW GE WASHER,THE LIGHT (RED0 ON
unplug unit for 1 minute plug back in and open and close lid 6 times within 12 seconds this will reset the motor.
Feb 26, 2010 | GE Washing Machines
How to fix remote car key
1.Insert key in ignition and pull out
2. Within 5 seconds, insert the key in the ignition and pull out again.
3. Within 40 seconds, close and open the driver's door twice, then insert and remove the key from the ignition again.
4. Within 40 more seconds, close and open the driver's door twice, then insert the key in the ignition and close the driver's door.
5. Turn ignition switch from LOCK to ON to OFF three times, leaving the key on for one second and off for one second each time.
6. Remove the key from the ignition lock.
The doors will lock and unlock themselves at about 2 second intervals. The number of times that the doors lock is the number of remotes that are programmed into the car. If the car locks/unlocks 5 times, there are no codes registered.
Oct 01, 2009 | 2005 Scion xA
How to open without format when i open my drive it displayed do u want to format if i foramt my drive i will lose my data pls tell me how to open it without format
Windows has found a problem with the F.A.T. (File allocation table), thus windows wants to format the drive. Other Dos mode commands like FIXMBR, (fix master boot record) may make retrieving your data impossible.
There is a way to get around this with out loosing all your data.
Before we get started I need you to check the data cable & power cable connected to the drive. Unplug the power cord from the PC. Open your case. Disconnect the power cable & data cable from the drive. Than re-connect the power cable & data cable, follow the data cable to the motherboard & check it's connection.
(By doing this you are making sure the cables are fully connected, sometimes they come loose but you can't tell just by looking at them). Put your case back together & plug in the power cord.
Load your windows CD into CD-ROM. Start up your system & at the same time press the F8 key on your keyboard every two seconds. A screen like the one below will load;
Choose your CD-ROM with windows in it.
Windows will see you have a version installed & it will give you other options. Read the screen prompts. You want to create a partition within the free space of your drive. Follow windows instructions. Windows will creating a new partition . Install windows into that new partition. (This will be a full install). Your old windows will not load.
The data within your old partition will not be deleted!
When you have finished installing windows update it. Install motherboard drivers, printer drivers & programs ect. When finished you can now copy folder & data to the new windows. (All this will take time). Most data will be located in folder shown below. You can copy & past the data / folders from the old partition to the new windows;
C:Documents and Settings User nameApplication DataMicrosoftAddress Book
C:Documents and Settings User nameDesktop
C:Documents and Settings User nameFavorites
C:Documents and Settings User nameLocal SettingsIdentities
C:Documents and Settings User nameMy Documents
Data from any program you may have installed.
When you are 100% sure you have recovered all your data, you can delete the old partition through windows disk management. How to run disk management?
Click the start button & click Run. Type, diskmgmt.msc into the run window & click ok. Within in disk management you'll see all partitions on your hard drive, you'll also see your CD-ROM & any other drives What was once your C: drive will most likely be labeled to another letter. To find your old windows right click on a drive within disk management & click open. (Make sure you do not delete the wrong partition / Windows).
To delete the old partition right click on the old partition & click, Delete Partition. Close all opened windows & restart. Windows will automatically add the drive space to your new partition.
Operation complete.
Mike
May 06, 2009 | Maxtor Hard Drive
Keyless control not work
here ya go follow the steps exactly and it will work and dont forget to rate me please,
* Remote programming
Start with drivers door open, unlocked, and no key in the ignition.
Insert and remove the key from the ignition switch twice within 5 seconds.
close and open the driver door twice within 40 seconds.
Then insert the key into the ignition key cylinder and remove it.
Close and open the driver door twice within 40 seconds.
Then insert the key into the ignition key cylinder and close the door.
Turn the ignition switch from LOCK to ON and back once and remove key
Locks should cycle once.
Within 40 seconds press the LOCK and UNLOCK switches on the transmitter switch simultaneously for 1.0 – 1.5 seconds.
Within 3 seconds after the previous operation, press either one of the switches for more than 1.0 seconds.
Within 3 seconds after the transmitter switch has been turned OFF, the LOCK–UNLOCK operation will be automatically performed once if the registration of the recognition code of the transmitter is completed correctly.
In case the LOCK–UNLOCK operation is performed twice, the registration of recognition code has failed.
Perform the registration procedure from the beginning once
Feb 03, 2009 | 2005 Toyota Camry Solara
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
