Question about Kenmore Ovens
Giving f-1 code - Kenmore Ovens
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F1 means that the control board (ERC) has gone bad and the electronic range control (ERC) should be replaced to resolve the issue. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 27, 2010
I went to do a self clean on my oven and I opened the door right as it was trying to lock. The door was open when it locked so the lock is out and now I can't shut the oven door. I tried turning off...
give this a try:
  1. Disconnect power from unit for a couple of minutes.
  2. Re-apply power.
  3. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
If this does not work, let me know what error code appears on the display. It should have be an F code with 1 or 3 numbers.
May 28, 2011 | Ovens
Hello! I have a Thermador double oven and it is beeping F-7 as it is finishing up a self-cleaning. In addition I am also getting F-1 F-1. The bottom oven cleaned and unlocked with no problems. Now the...
Hello, Per my manual:
F7 - This is caused by close contact to the control panel for more then 32 seconds,such as someone leaning against the controls or objects hanging in front of controls.
F-1 - Touch OFF or turn power off at the circuit breaker, wait 3 minutes and turn it back on. If condition persists, note the code number and call an authorized servicer.
Hope this helps,
Vicki
Oct 15, 2010 | Thermador SC272T Electric Double Oven
Hgc5-1 hobart gas convection oven board giving a 3 blink code after flame shuts off what is the code error seems like maybe a limit
Test wire nuts on wire #54 and #55 (on 550 degree high limit switch) for continuity, should show shorted if shows open, limit switch is bad. Test by jumping if oven works switch is bad.
Sep 01, 2010 | Ovens
Ge built in 1993 oven shows an F-1 sign and beeps
Hello there:
any time you recieve the f-1 and sometimes a f-o error with the beeping this is from the electronic range controle board or erc for short and this means that that part has fgailed and needs to be replaced if you go to repair clinic.com you can look up you oven model number and get parts from there or if you have a appliance repair center in your home town give them a call and tell them the ovens model number and tell them you need a erc or electronic range controle board ok?
Hope this helps
Best regards Michael
Aug 16, 2010 | GE Ovens
F-7 ERROR CODE
sir,
check these links
Link 1
Link 2
Thanks Good Luck
Appreciate to rate as "Fixya"
May 21, 2009 | Jenn-Air JMW8527C Electric Double Oven
Wall oven error code
Having the same problem.
Has anyone found a solution to this problem?
Thank you
David
m5beemer(at)gmail.com
Sep 03, 2008 | Bosch HBL 745 Stainless Steel Electric...
Lower oven
hi
shut off power to the unit, let it sit for a while then turn the power back on. test the oven again, if the code comes back call 1-800-Jenn-Air and ask them what the code means.
Apr 02, 2008 | Jenn-Air JJW8430D Electric Double Oven
Whirlpool electric range RF361 bxdn 0. error codes? PF?
hi Jon
look on the back of the unit, there should be an envelope that has a paper in it, that paper should tell you what the code means.
Apr 01, 2008 | Ovens
E2/F2 Error
The Model number is a RBD306PDB6 i found that one as far as the code
F2=
E2 Keypad not connected
1. Check keypad connector for firm connection.
E3 Key held down too 2. Press CANCEL. If error code returns after 60 sec., replace keypad.
long, or key is shorted
Feb 17, 2008 | Ovens
F9 code on stove
Here's what F9 code means:
1. Door lock safety circuit on ERC sensed Replace the door latch assembly
2. Door Lock Warning Check door lock circuit or Replace Clock
Try pressing and holding the door latch to unlock position and then press cancel for a few seconds. The latch should return to its original position.
Jan 23, 2008 | Ovens
Ovens Logo
19 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
