Question about Traxxas Rc Revo Nitro Monster Truck
My Revo 3.3cc won't start... It's not at TDC, it's not flooded and I removed the glow plug and added some after run oil to no avail. What should I do next? The Revo has only about 12 runs on it and during the last run it ran perfectly...
2 Suggested Answers
micromend
  • 748 Answers
SOURCE: my revo is getting fuel light on start remote are
Hi
You've checked the glow plug externally to see the wire get red? If so, as long as you've got fuel and fire then it has to start. My guess here is that you have either a bad glow plug, low batteries, fuel air leak or clogged pressure line. Put a charged battery into the starter. Remove the glow plug and try to start - fuel should spurt up through the glow plug opening. Now connect the glow plug and touch it to the engine. Try to start and you should see the glow plug wire glow red. (do this only for a second. Now disconnect the pressure tap from the muffler and try to start. All else fails, replace the fuel line to the carb and the pressure tap. Your carburetor can leak air through the rubber gasket . Also, Traxxas fuel tanks have a cracking problem. Good luck
Posted on Apr 14, 2010
Engine not turning, it got stack on top tdc.
engine has been run with fuel too lean, and ran too hard, engine rebuild or new engine is neccessary
Jan 26, 2013 | Traxxas Rc Revo Nitro Monster Truck
Engine not moving, looks like the piston got stack on top tdc.
This is a typical Issue. You can try turning the flywheel by hand to see if you can get the piston to move from TDC, If that does not work you will probably have to remove Glow-Plug and insert something Brass, Wood, Plastic Strong enough to push on piston but as mentioned not a screwdriver etc. due to possibility of damage to piston.
Then you can push the piston down.
If using a dowel of wood or plastic and you cannot push the piston down you can gently tap on the device you decide to use "LIGHTLY" and it should move off of TDC.
Revo 3.3...engine doesnt stay on...
Could be a couple of things. Firstly the glow plug may need changing or youre running slightly rich. If you was replacing the glow plug you should retune the engine anyway. When the fuel is entering in the engine where the glow plug is theres either to much fuel and flooding plug out or the plug is not up to the job of burning the fuel. Replace plug and retune. You have had car for two years so guessing you know how to tune the engine.
May 27, 2010 | Traxxas Rc Revo Nitro Monster Truck
3.3 revo hard to start after started it will not idle and when it dies it does not want to restart. This did not happen until I drve it thru alot of wet grass last year
Hi
2 stroke engines are very simple. If there's fuel (under pressure) and a spark it will run. Check the glow plug by trying to start it with glow plug removed but still connected and touching the engine body. If the little center wire glows bright red, then it's OK. Only do this for a second or so. If the plug is OK then it has to be a fuel problem. Traxxas has a long history of cracked gas tanks. Good luck
Apr 30, 2010 | Traxxas Rc Revo Nitro Monster Truck
My revo is getting fuel light on start remote are on both motor and glow plug engine will just turn over but will not start up
Hi
Apr 14, 2010 | Traxxas Rc Revo Nitro Monster Truck
I have a revo 3.3 nitro and im having problems starting it im am indoors about 70 and im flooding the engine i go through the steps for a flooded engine but the easy start won't turn i let it cool...
i'm new to revos two but i just bought a couple and had the same problem with one of them, make sure your glow plug is ok or just replace it and adjust your high speed needle, i'm in oregon i had to richen mine about 1/4 turn. i also noticed both of the models i got were set differently from the factory. there's info on traxxas website on where the factory needle settings should be.
Feb 02, 2010 | Traxxas Rc Revo Nitro Monster Truck
I have a traxxas revo 3.3 and it turns over but it will not start what do i do
The glow plug could be bad. If the motor turns over and is getting fuel I would replace the glow plug.
Jan 07, 2010 | Traxxas Rc Revo Nitro Monster Truck
The thing you put on the back of the truck will not work only the motor lite comes on but i no its not the glow plug
Have you charged the battery in the EZ Start wand? If you have is the motor turning over at all? If the motor is turning over but not firing it could be the glow plug. If the motor trying to turn over but won't, the engine might be flooded. If it is flooded remove the glow plug and turn the truck upside down. Fuel will run out of the engine. If fuel runs out of the engine, put the truck back down on its wheels. Cover the engine head with a rag and turn the engine over with the EZ Start wand with the glow plug still out. This will remove all excess fuel from the engine. Reinstall glow plug and try to start again.
Oct 21, 2009 | Traxxas Rc Nitro Stampede Rtr 2wd Monster...
Traxxas Rc Revo Nitro Monster Truck Logo
335 people viewed this question
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
John mullen
gbob59
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
