Question about Samsung Televison & Video
When turning on the tv, it "clicks" many times before actually turning on
  • 74 Answers
FAULTY POWER SUPLLY CAPACITORS REPLACE
AVERAGE REPLACEMENT POWER SUPPLY £80 TO £120
Posted on Aug 25, 2010
Red LED Light Blinks 7 Times Tv Wont Turn On PLEASE HELP!
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
You must have through knowledge in electronics to proceed. This is a very skilled wor. You must have all measuring instruments, and ability to follow its schematic diagram.
Jun 12, 2012 | Sony KV-36XBR400 36" TV
GE Guide Plus Gemstar. It keeps clicking when I turn it on. Clicks four to five times but never actually turns on
If a standard set (glass picture tube) you have either a problem in the main power supply or in the High Voltage circuit which is triggering shutdown as protection.
What is the model number of your TV?
May 28, 2012 | Televison & Video
Tv will not turn on and green light blinks 3 times constantly
Your main power board located in the center where your power cord will plug into is going bad, actually it's just a relay. I have the same problem, tv works for hours til relay overheats, then tv shuts off and tries to restart, hence the clicking and the 3 green flashes, mine will actually restart after 15-30 minutes. search online for the board, ranges anywhere from 150-280. I haven't found anyone to sell just the relay. I am trying tv with rear panel removed and cover removed from relay to see if relay will not malfunction? Board is a simple plug and play, just remember to have the tv unplugged.... you can actually remove the rear panel while on it's stand, just don't remove the screws holding the base onto the tv.
Jul 14, 2011 | Toshiba Regza 52XV645U LCD TV
L.G TV plasma. Model No. 60 PC1D AA We are having problem turning on our television. It takes us about 30-35 clicks until we can successfully turn on our television. We have to press the power button...
I would replace the capacitors in the power supply if there are any dried up components and get it fixed before it fails completely and does serious damage.
Mar 31, 2011 | Televison & Video
Tv takes 20 minutes to turn on, keep hearing a clicking sounc
Ur tv the Ballast board the help to turn on the tv projection bulb is dead.Try website like Tvrepairworld.com to buy the Ballast board for the replacement.The Samsung/Akai tvs use the same Ballast board.When in the website go to the menu that said Samsung/Akai circuit boards.Pick that option click on it,u will see a picture of a Ballast board look like.
May 31, 2010 | Samsung HCN4226W 42" Rear Projection...
Samsung LNT4061FX makes clicking noise before coming on.
Replace capacitors in power supply you will see that they are bulged on top
Sep 13, 2009 | Televison & Video
RCA light comes on and then goes off. Tv doesn't turn on
replace CP150 and CP114 you can get them at the following link they also have the ITC222 service manual which is listed under Thomson as Thomson makes your TV for RCA. The Capacitors are listed under the RCA parts and they do send instructions with pictures of where the capacitors are located as well as how to remove the board.
http://servicemanuals.vstore.ca/
May 27, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
When you turn 'on' the tv...the tv continuously 'clicks'
The clicking noise is caused by the relays on the power supply board trying to power up the system. Your TV has detected a problem that's causing the power supply to shutdown. Someone knowledgeable in electronics can track down the problem. The SOURCE of the problem could be another board other the power supply.
Mar 15, 2009 | Samsung 46 in. Flat-Panel LCD HDTV
Sony Trinitron TV takes multiple manual clicks to turn on.
If you mean the actual mains switch needs multiple cycles, it could be faulty.. does anything, say a power indicator, come on when the TV doesn't?
If the actual switch is OK, then you probably have a fault in the power supply section... often faulty electrolytic capacitors. U need service.
Mar 26, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
46 people viewed this question
Jerry Greenberg
Jerry Greenberg
