Question about Kenmore Sewing Machines
I have a Kenmore sewing machine, model 14502 or 14401. My top thread keeps getting wound around the bobbin case holder. Any suggestions would be greatly appreciated! :) Thanks much!
techworm
  • 56 Answers
SOURCE: thread getting caught around bobbin case
It isout of time you need to time it.by adjusting the screw on the bobbin holder turn it left or right and the tension knobe and foot tension.
Posted on Nov 12, 2007
lavon82931
  • 17 Answers
SOURCE: Thread is bunching up around the bobbin casing
On the bobbin case is a small screw if it is to loose the thread won't feed like it should make sure that screw is tight but not so tight you can't get the thread through it. Also check to make sure you have threaded the top right. hope that helps
Posted on Oct 14, 2008
kent581
  • 87 Answers
SOURCE: Upper thread knots up with bobbin thread when sewing a stich
Thread test
Test your thread quality to start, thread your machine and LIFT the presser foot (this opens the tension disks). Pull your top thread straight back. If you feel no tension no mater how much thread you pull, your thread is good. If that your machine passes that test, then let me know, we can go to step 2. If not, try different spool of thread, same test until you get a smooth pull (tip: always check your thread this way when you thread your machine)
Step 2:
Pull on your threaded bobbin thread while it’s in the machine. Does it pull smooth and even? If so, go to step 3. If not, try a new bobbin (bobbins get bent or distorted if wound too tight).
Clean thoroughly in the hook and bobbin case area and oil 1-2 drop is all.
Thread knotting on the bobbin can be a lot of things but here's some guidance:
Tension:
If the thread is loose on the bottom of the fabric, it's actually the top thread is too loose. Think of 2 little elves playing tug of war in your machine, one on toip and one underneath. If you have loops on bottom, the top needs to pull harder (tighten top tension)
Jamming bobbin case:
If it is damaged from turning out of place once, it could have rough spots on it that makes the thread hang on it, and keeps making it turn over and over. Use a finger nail board (fine sanding) and smoothall rough spots. Then reset the bobbin case taking care to put the notch in the bobbin case in alignment with the proper spot in the machine (basically 5 o’clock) when looking at the round area where the bobbin case goes.
Posted on Mar 18, 2009
SOURCE: thread knotting around bobbin case
hello, I had the exact same problem and could not find the solution until i took my machine to my sewing sensei and i solved my tedious problem. It was actually not a tension problem at all but a threading problem. Make sure you have threaded your bobbin correctly and that when you pull on the bobbin thread that the bobbin turns the right way. (mine must spin anti clockwise to work)  Make sure that when you pull up the bobbin thread using the needle that it is not over the feed dogs connective bar but under it. A big problem when the thread gets caught around the bobbin case wheel is that the thread is looped around the feed dogs once and that causes the thread to get caught around the bobbin wheel. In conclusion, thread the bobbin correctly and read over your instruction book before spending the money to get it fixe in s shop.
Posted on Mar 31, 2009
Mongo32
  • 111 Answers
SOURCE: Sewing machine will not pick up bobbin thread.
needle's in backwards
Posted on Jun 11, 2009
How do I set a straight stitch? What is causing the top thread to break?
You do not say which machine you have. As for a straight stitch, make sure the needle is central and not in zig zag mode.
The thread can break for several reasons, such as. Incorrect tension.
:Wrong thread for the material.
: Thread in bobbin different from the top thread.
:Old thread.
: Not threaded correctly.
: Needle not inserted correctly, or incorrect needle.or the thread could be wound around the spool holder pin,
Try removing the spool and turn it around.
Hope this helps.
Mar 02, 2015 | Sewing Machines
LOWER BOBBIN BINDING UP
Readjust the needle timing and check the thread tensions top and bottom.
Jun 09, 2013 | Kenmore Sewing Machines
Thread caught behind the bobbin case holder
Take off the presser foot
take off the needle plate
take off the bobbin plate
take out the needle,
clip bobbin free,
Examine the bobbin carrier on how it fits into place. (important)
Lift out the bobbin carrier.
Each machine is a little different. You may want to take pictures as you do each step for later reference. Use something like an old egg carton or a muffin tin to keep your parts from rolling around or getting knocked off an lost.
Have fun.
Nov 05, 2012 | Pfaff Creative 4.0 Sewing Machnie
Kenmore bobbin issues
try these suggestions
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
Oct 25, 2012 | Kenmore Sewing Machines
Bobin jumps when sewing
Could be in around the wrong way, poorly wound or not under tension correctly. Or even the wrong bobbin for this machine.
I suggest that you check that the bobbin is correct, ie do you have several that came with the machine and are they all the same in shape and diameter? Consult the manual if you have one.
Nextly, wind a fresh bobbin taking the thread from the spool through the tensioner (if your machine has one on the top) and then onto the bobbin. Keep a little tension on the thread spool with the handle of your scissors to ensure that the bobbin winds smoothly and evenly. Use your finger tip to nudge the thread to fill all areas of the bobbin. You want a neat smooth wind so the thread will then flow smoothly off the bobbin when it is in the machine making stitches.
Now, load the bobbin into the bobbin holder or bobbin case as per your manual, ensuring the thread is correctly into the tension spring and bobbin is rotating the right way around.
Now thread up and test sew again.
Apr 09, 2011 | Brother Sewing Machines
I can only get a small amount of thread wound on the bobbin.It stops and wont take any more. The bobbin case keeps moving & I cant get it back in correct place
I assume you are placing the bobbin at the TOP of the machine, then wrapping the end of the thread several times around the bobbin in a counter-clockwise motion?
Have you made sure to "scoot" the empty bobbin next to the bobbin bar to the right? Is the thread going from your spool, directly TO the bobbin? Because it is supposed to wrap around the tension "nut" (where you start to thread your machine) before going to the bobbin.
Apr 24, 2010 | Brother XL-2230 Mechanical Sewing Machine
Thread gets caught on the bobbin holder and won't
Hello there:
have you tried to adjust your stich pattern and slowed down your feed rate also doublecheck the bobin to ensure that it is installed fully in the casing and is not warped at all ok?
regards mike
Aug 18, 2009 | Kenmore Sewing Machines
I need an instruction manual for the Babylock Pro II Model B15
hi!there similar bobbins winder in any brand of sewing machine uses mostly in domestic particularly in industrial manufacturing in this fig.check it out if similar to your bobbins any how itmay be he86acf3a.jpglpfull onethe bobbins winder that was a thread and shoul be clockwise rotation when coming out to bobbins case,if you to wound the thread on your bobbins winder, pull threads on spool then wind this in several times 4 to 6 rotation clockwise loop thread on top machine there is bobbins winder disc for tension put winder bobbins on shaft winder near hand wheel push the latch against bobbins winder to fit thead run machine to wind the thread.After hread wound in bobbins winder cut thread and insert winder to bobbin case as shown.
insert bobbins to shuttle hook case under needle foot holder
lift the cover plate you can see under this is the shuttle hooke415486.jpgafter set up was made on bobbins thread,set also the upper loop thead beginning at top of machine start on spool, pull thread and loop to upper disc tension then to the slot portion as in figure
insert on lever dial goes to the needle adjust tension to #8 range to #12 for cotton fabrics two layer sewing.
Mar 17, 2009 | Baby Lock Sewing Machines
Thread test
Step 2:
Tension:
Mar 16, 2009 | Sewing Machines
Oct 14, 2008 | Kenmore 15208 Mechanical Sewing Machine
Sewing Machines Logo
85 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
