Question about Milwaukee Tool Milwaukee 1/4 Sheet Orbital Palm Sander - 6016 - 6
Palm sander 6016... i have to replace the
Palm sander 6016... i have to replace the cord.. but i can only get the halves apart about 1/4 inch..... Also .. how do I remove the Fan... I have no puller..
  • 2,176 Answers
You dont need a puller for the fan, remove the lower pad assembly and the torx screw holding the bearing in place. use a screwdriver to gently lift the fan. the bottom of tool has to be disassembled to open the halves. Go to Milwaukeetools.com and type in your model number under the download section for a parts/tool explosion. Let me know if you need more assistance
Posted on Aug 26, 2010
I keep getting shocks from skil pp gf30 palm sander
The case should be plastic and the sander is supposed to be double insulated. About the only way to get a shock is from a damaged power cord. Check for splits or exposed wire where the cord enters the sander.
Feb 19, 2014 | Drills
Where to apply grease
There are no parts in your sander to grease. The only place there is grease is in the three sealed bearings on the armature and in the platen. Everything should be clean and dry inside the sander to make it less likely for sawdust to stick inside the tool. Blow everything out and replace the bearings if they are not turning freely and smoothly.
Dec 01, 2012 | Dewalt D26441 - Palm Sander, 1/4 Sheet
How to take apart the Makita 1/4 palm sander in order to replace the electrical cord? I have removed the four screws in the plastic part but it seems to have a snap section that isn't releasing. It...
you have to remove the platen on the bottom also, go to makitausa.com and you can download a parts explostion for this tool to see what I am talking about. If I have helped you would you please vote accordingly and thank you
Sep 08, 2011 | Makita Bo4556k Palm Grip Finishing Sander...
Just hums
It has a siezed bearing. Type your model number in here and when you take it apart, you will be able to find the bearing, and order the part.
http://www.blackanddecker.com/Parts.aspx
If you had posted your model number and type number, I could have given a direct link to your tool.
Dec 07, 2010 | Black & Decker 1/4" Sheet, Heavy Duty,...
How do I secure a piece of sandpaper on the dewalt orbit palm sander?
I think your model holds the paper with glue that is on the sand paper.Just take apart the back cover of the sand paper to expose the glue.
Nov 08, 2010 | Dewalt DW421 5'' orbital sander
How do I replace the power cord for a makita palm sander? Specifically once all the visible screws are removed how does one separate the two body havles?
without knowing what the model number is you also have to remove the pad assembly and usually you will find some there if all removed you can GENTLY pry the cover halves apart. Go to Makitatools.com with you model number and you can download a breakdown for this tool.
Mar 14, 2010 | Makita Tools & Hardware - Others
The motor buzzes slowly, it seems to be labouring and the plate rotates very slowly. Its as if the motor is blocked up inside. I've taken it apart and removed as much fine dust as possible but this hasn't...
sounds to me like the bearings are locking up, you can go to Dewaltservicenet.com and type in your model number and download a parts explosion for this tool so you can see the replacement part numbers. when you had it apart did you see any indication that the field was rubbing on the armature?? I would take a close look at the bearings though.
Jan 23, 2010 | Dewalt D26441 Heavy Duty 2.4 Amp 1/4 Sheet...
I need to remove the fan on my black and decker pad sander but theres no way to clamp the armature to unscrew the fan
Why would you want to remove the fan? There is a good chance that the fan is molded to the shaft and can not come off.
Jul 13, 2009 | Milwaukee Tool Milwaukee 1/4 Sheet Orbital...
Cannot disassemble Milwaukee 6016 to replace brushes
exactly what screws did you remove. you have to remove the bottom platen first (pad) then remove the housing screws. you need to remove the fan also and then might need to apply some pressure to split the housing halves.
Mar 03, 2009 | Milwaukee Tool Milwaukee 1/4 Sheet Orbital...
How many Types of Sanders?
Belt sanders: Belt sanders are useful for removing large quantities of wood stock quickly. They are generally used for rough sanding before fine finishing with a smaller sander. Palm sanders: Palm sanders are ultra-portable and useful for finishing small projects. Orbit sanders: Orbit sanders are usually more heavy-duty than palm sanders and appropriate for larger projects.
Aug 27, 2008 | Bosch 3X18 Belt Sander
Milwaukee Tool Milwaukee 1/4 Sheet Orbital Palm Sander - 6016 - 6 Logo
265 people viewed this question
Top Milwaukee Tool Tools & Hardware - Others Experts
Bill Boyd
Are you a Milwaukee Tool Tool and Hardware - Other Expert? Answer questions, earn points and help others
