Question about Frigidaire ATF6000ES Front Load Washer
Middle of cycle message comes up "err7" - Frigidaire ATF6000ES Front Load Washer
Good day, FRIGIDAIRE GALLERY SERIES 4y old well mantained and clen even strainer. the electronic system suddenly went off change of cycle does not show the change of minutes an 18h shows on screen, disconect for a wile appears to work, it starts and stops after 10 minutes and beeps ready no lights then goes crazy again. Please help email: arupro@setarnet.aw
Posted on Aug 29, 2010
  • arupro Aug 29, 2010
    Sorry I was asking not giving a solution duggg :)
My lg intello wd 8074fhb washer will be in the middle of wash cycle and an error message comes up se ..Can you tell me what this error message means..
LG's 'SE' means 'sensor error'. Sorry but you will need a repair visit I fear ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jun 12, 2011 | Washing Machines
Err 7
Err7 is a motor error.Check out the following Haier washer manual link (page number 17).
for washer manual click here
The only solution suggested is to replace the motor.
Jan 08, 2009 | Haier Washing Machines
HAIER HW-C1460TVEME-U
Err1 : Door not properly shut
Err2 : Drainage error (clean filter check hose
Err3 : temperature sensor short circuit
Err4 : Heater error
Err5 : water fails to meet specified level within 8 mins check tap, water pressure
Err6 : motor error
Err7 : motor error
Err8 : water exceeds protective level check circuit
End : end of wash cycle
Unb : after the last rinsing cycle finishes spinning fails completelt due to unbalance of the laundry
only reason I know is i looked through the manual after getting it myself could be something to do with running a bath while washer on or something perhaps not enough water getting in if powder channel blocked
Sep 12, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Trouble shooting
if it doesent spin at all could have a problem with motor carbons if you access the motor you will see two long stick like objects attached to the metal casng on the motor remove and chack the contacts have at least 10 mm of corbon
Sep 04, 2008 | Haier XQG50-11 Front Load Washer / Dryer
I have the HAIER HW-C1260TVE-U washing machine, and for some reason it won't do the spin cycle? at the end of the programme in says something like "UNB END". Any ideas?
Hi Mate;
Just had the exact same problem with the spin cylec and now its stopped completely, I was getting ERR 7 on the display, its telling you that there is something wrong with the motor.checked the motor and found that one of the Carbon Brushes was sticking/Stuck, Just 2 phillips head screws and the carbon brush is out, mine had a bit of melted plastic/casing snagging the Carbon brush, i just jusd a bit of fine sand paper to clean the Brush, put it all back together and lo and behold everyting works.
Hope this helps
Listed below are all the error codes:
Display messages:
Err1: Error message. Door is not properly shut 20s after program is started.
Correction: Shut the door properly.
Err2: Error message. Drainage error, water not emptied within 4 min.
Correction: Clean the filter and check the drain hose for blockage. If error still exists, please contact the maintenance personnel.
Err3: Error message. Temperature sensor is not properly connected or damaged (display at the end of a program).
Correction: Contact the maintenance personnel.
Err4: Error message. The heater may be broken or the desired temperature is not met within the specified time due to an overloaded laundry (display at the end of a program).
Correction: Reduce the load and restart, or contact the maintenance personnel.
Err5: Error message. The required water level is not reached within 10 min, or the water level exceeds the protection value.
Correction: Check to see if the tap is turned on and the water pressure is correct. If error still exists, contact the maintenance personnel.
Err6: Error message. Motor speed error. It may be not properly connected or damaged.
Err7: Error message. Motor overheat protection or is damaged.
Err8: Error message. Water level exceeds protection value.
Regards
Bull
Jul 29, 2008 | Washing Machines
Ld error message
It most likely means long drain, the drain line could be clogged or kinked. You could also have something jamming the drain pump or a bad drain pump.
Jan 21, 2008 | Kenmore Oasis HE 27082 Top Load Washer
"PE" error message on LG Dishwasher LD-12AS1 LD-12AW2
The PE error code indicates that the machine has a water pressure sensing error. Check and clean the filters on both sides of the inlet water line. Good luck!
Sep 13, 2007 | Dishwashers
Frigidaire ATF6000ES Front Load Washer Logo
193 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
