Compaq presario V1000 display problem
I'm having problem with my laptop's display. the monitor would go dim and barely readable. I could use it for a few minutes then the monitor would dim? please help.
  • 3 Answers
I have compaq v1000 latop have one problem power online no issu but battroy running for laptop gang
Posted on Sep 14, 2009
  • thanasingh20 Sep 14, 2009
    tanks for information... but i change alternative battroy more than 2 i change same problem repited sir pl i csamange battory rateing 14.4v but that is 10.4v battry same is repet
  • 5,568 Answers
Is this only when you are operating from batteries or also on AC (through the adaptor) as well?
You should also establish what the complete model number of your system is, there are many in that series:
If the problem is only happening on battery operation, the pack may have one or more failed cells, reducing the available voltage below the level that the display inverter needs to keep the fluorescent backlight at full brightness.
The display is the power hungriest part after the processor itself.
The pack should have a rating on it and any multimeter (everyone should have one-digitals are dirt cheap) will tell you if the pack is charging up to its rated voltage.
Posted on May 05, 2008
My compaq presario 1200xl310's monitor remains black. I just purchased a new ac adapter for it. It had been unused for about a month. When I inserted the new adapter and powered it up---no screenlight-up....
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
Sep 30, 2009 | Compaq Presario 1200 Notebook
No monitor display on my laptop notebook
Aug 18, 2009 | Compaq Presario Notebook
Multiple lines on screen
Try connecting an external monitor to the your laptop and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Mar 15, 2009 | Compaq Presario M2000 Notebook
My laptop, hp compaq nx6110 has a screen problem. Its dim
Check the "Power Options" in your "Control Panel" (classic view). For whatever option you have picked, click "Change plan settings". There you can either "Restore default settings", or manually "Change advanced settings". If you choose "advanced settings", look for "Display" / "Display brightness".
Feb 26, 2009 | HP Compaq nx6110 PC Laptop
I Have a Compaq V3000 Laptops. The display is very dim. HELP!!
It miight be the backlight for this unit. It all depends on whether the screen came with the backlight. There is a remote chance that the display circuitry on the motherboard is faulty too. Try to plug a monitor into the VGA port and check to see if it is dim there too.
Feb 16, 2009 | HP Compaq Presario v3000z Notebook
Compaq presario v1000 starting problem
check the smps of battery of your laptop.
Sep 24, 2008 | Computers & Internet
Presario 900 display faults
try to increase its brightness from Power options/Control panel..
hope it works u out
Jun 23, 2008 | HP GF939ATABA Notebook
Lc display
how many hours do you have on that monitor could be lamps or just fusses
Nov 20, 2007 | Compaq Presario 900 /1500 Series EVO...
Presario 700 very dim screen
i would say its the inverter. worst case senario it would be your lcd screen.
Oct 30, 2007 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
185 people viewed this question
David Payne
David Payne
