Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
Soap Where do you put it???
    Problem Solver:
  • 3 Answers
As you look at the despenser drawer it has 3 chambers. The left chamber is for Prewash detergent, middle for Fabric conditioner, right is for Liquid or powder detergent. Or use a plastic ball in the main drum!
Posted on May 14, 2008
Downy goes first than soap
I fill the washer with water first
Then open the lid put in the soap
3/4 cap full,then then 2/3 cap downy
(Both together-bleach as well- if a white load)
I add only to clear water after it fills
Then allow the water to mix the soap
Then add the cloths a few at a time
NEVER put the cloths in & add soap
on them with no water or use the silly
places on the top they say to add stuff
You only add soap etc to plain water &
no cloths & mix first,then cloths go in
Common Sense as to what is taking place
The part about the softener was just silly
It is in the water mixed with soap etc & all goes out
at one time
It is a one step deal
Water,Soap,Downy,then Cloths your done
Nov 04, 2014 | Samsung WF337AA Front Load Washer
Where do I put the Finish powerball in my KENMORE 24 in built in dishwasher? There are two places to put the soap. One has a cover and the other does not.
If you have a water softener, just drop the entire tablet into the bottom of the dishwasher at the beginning of the cycle. This is to allow extra cycles to get all the soap out, since soap goes a lot farther in soft water. If you don't have a water softener, put the tablet in the part with the lid, and close the lid. You don't need anything in the other (pre-wash) part.
Aug 03, 2014 | Kenmore Dishwashers
I have a Semi Automatic Whirlpool Sparkle washing machine my question is can i put water in the dryer just to remove soap from the clothes
Whether your dryer is electric or gas, DON'T PUT WATER IN THE DRYER!!! If you need to get more soap out of the laundry, run it through another cycle without soap.
Jul 27, 2014 | Whirlpool Washing Machines
Bissell cleanview carpet cleaner
There are a few things that can cause a Bissell carpet cleaner to not dispense water. First thing to check is the belts if your machine is a Pro Heat. The flat belt goes around the motor shaft and the pump. As the motor runs it spins the pump. This is a stretch belt and stretch belts should be replaced at least once or twice per year to work properly as they will lose elasticity even if the machine has never been turned on. The first thing to check is to see if water will spray from the upholstery tool. If it sprays but you still get no water at the floor jets then check and clean the jets to insure they are not clogged. Getting water from the upholstery tool means the pump is working ok. If not, make sure the water tank and soap tank are not empty. Even if the water tank is full make sure the soap tank is full too. I would suggest NOT putting any soap in the soap tank because that is what causes most of the problems. Put plain tap water in the soap tank and try the machine again. Hold the trigger down giving it plenty of time to flush out any air bubbles and/or soap from the pump and the lines. If you still can't get any water from to the floor jets the most likely problem is the heater is clogged with mineral deposits or soap gunk. When a machine sits in the closet for months the soap in the lines coagulates and will clog things up. Which is why if you want the machine to work for a long time NEVER put soap in it. To do a better job of cleaning put your soap and hot water into a sprayer and use this solution to pre-condition the carpets. Pre-conditioning gives the soap and hot water a chance to dissolve the gunk in your carpets, then use fresh hot water in the machine to flush the soap and dirt from your carpets. Your machine will last longer and your carpets will be cleaner and stay clean longer because you rinsed out the soap. If you try this method you will be amazed how much cleaner your carpets will be.
If you need to clean the heater you will need to separate the handle assembly by removing all the screws. First make sure the machine is unplugged. You'll have to figure out which screws need to come out, it's not too tough. The heater is inside the handle. Look at how it comes apart so you will know how to put it back together. The heater is the silver metal thing with wires and hoses. Remove the screws that hold the cover on being sure not to lose any of the tiny red gaskets. Remove the cover and clean the soap or mineral deposits from the heater core, put the cover back on and put it back together and it should work fine. To keep it from getting clogged again simply make sure you use soft water if minerals were the problem and never put soap in the machine.
Oct 22, 2013 | Vacuums
Won't dispense soap. Changed batteries twice,
Sometime the viscosity of the soap could be the culprit. If you had changed to a thicker soap sometimes those pumps can't handle it. Try a less viscous soap and lets see what happens. Good Luck PAL
Jul 26, 2010 | NRS iTouchless Stainless Steel Automatic...
How do you use the tube for the detergent
Put the tube into a bucket with detergent that is recommended for your machine then put the wand into low pressure mode and if it has a valve where the hose connects turn the valve to the on position and pull trigger and watch to see if soap starts being drawn out of the soap bottle if it starts pulling the soap up continue to allow it to flow till you get your part soaked with soap, then let it set for 10 minutes then hit it with high pressure hose to wash off, when it is clean then put it on low pressure and pull hose out of bucket with soap and then allow the soap to be pulled out of tube and until there is no longer any soap coming out then store the hose for use later. some machines have a control valve at the end of the wand by turning the tip or pushing tip in or pulling it out some models requires you to use quick disconnect fan tips to lower pressure to use soap.
Jun 15, 2010 | Karcher G3025OH Pressure Washer
Soap door does not open
I have a 1 year old whirlpool that had this problem ... items in silverware compartment were blocking the soap door. when we opened the DW, the soap door was open, but could not open properly during the cycle due to kitchen utensils in the way ... took a while to figure this our as it was intermitent (both the problem ... and us putting tall stuff in front of the soap door). Our soap door needs 3.5" of free space in front of it ... I think it's a design flaw. Good luck.
Oct 22, 2008 | Frigidaire 24 in. FDB750RCC Stainless...
Were do you put the soap in a pls 602 dishwasher??
Hi spikey_legs
When you open the draw and look into it you should see what looks like a knob and just above it should be a little pice that sticks out about 2cm push down on that and it should open the soap dispensor. hope this helps.
brent
Sep 30, 2008 | Dishwashers
SOAP DISPENSING
The soap dispenser is intended for both liquid and powder detergents. If you have a problem with mildew, then you may need to clean it occasionally with bleach water.
Aug 07, 2008 | Hotpoint WMA50 Front Load Washer
Where do i put the soap?
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=618960&thid=548073
Posted by dopaMEAN on Apr 26, 2008
I have a Bissell Dirt Lifter that has the giant clear store compartment that you supposedly put the water in?
Do i mix the soap in with the water in this compartment or is there another location where i add the soap..
We have looked the machine over and see no other place to really put the soap...
will it ruin the machine if we just add the soap with the water in the detachable compartment?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
According to your description you do mix the water with the Bissell soap in order to dispense the solution onto the spot, it will not ruin the machine if you mix the water and soap together.
You may want to refer to your owner’s manual and check out the trouble shooting guide for no water coming out. You may want to contact the factory or manufacturer to see if they have service tech support or to send out a new owner’s manual for your current model #. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ By Phone Customer Service:
(800) 237-7691 Hours:
M-F 8:00 a.m. - 10:00 p.m. ET
Saturday 9:00 a.m. - 8:00 p.m. ET
Don – The Vac Man
Go Ahead. Use Us.
Apr 26, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
74 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
