Repair paint pealing in microwave I'am told their is a spray paint made
to paint inside surface of microwave need to know name of manuf.
and maybe where it can be purchased
thanks in advance tony
I have seen where so do not know that certain pieces of vac and be taken apart. Open and unscrew to look inside to see whats loose causing that problem.
Please be extremelly careful with microwaves, they produce radiation. My best advise is to take it to a repaar shop and ask for a quote. Microwaves are so cheap nowadays that maybe is better to buy a new one if the repair cost over 50% of the price of a new one.
you need to sand that stain down with sandpaper and then re-paint the area with a high temperature paint......hardware stores should sell it....it's trade name is called...."mr. touch up"......it is speciffically made for microwave ovens but is also very good for your oven.....the paint must be high temperature type since your oven is high temperature.....good luck
There are two spray tips up behind the brush.
Check to make sure the spray tips are clear.
If paint got into them it could reduce the spray.
If you need further assistance call BISSELL Consumer Services.
1-800-237-7691 Mon-Fri: 8am to 10pm ET Sat: 9am to 8pm ET
The Pumps on these go bad after a couple of months. They rust and will
sometimes spray and other times not then eventually not work at all. If
your a handy man pull the top off it and remove the pump motor and
replace it yourself. The part number is 603-5029 you can put this number
in google shipping and get it to your door for about $15 and replace it
yourself or have a friend do it. Ebay has tons of them once again just
put in the part number and a list of them will come up.
Thanks and have a good one
Sincerely, CRTN
If you do this the vinegar will likely disperse hard water scale as it cleans the inside of the element. While it shouldn't stain anything it will likely cause sputtering as it breaks down the scale. If your goal is to clean and disinfect a surface that is vinegar friendly, I would consider taking the extra step of spraying the surface with a spray bottle with the vinegar. Bleach in steam might puff back at you in a cloud and burn your eyes and skin so be VERY cautious on the bleach.
HERE is the manual, just instead of shampoo use water-based paint and do nut put that nozzle on the sprayer. WASH IT WELL after you use it. Honestly - you better off buying a spray can. Painting with Kirby - MESSY. May sound strange from someone who makes living selling Kirby stuff but I just hate salespeople making it sound as if Kirby vacuum is ONLY appliance that you ever need to buy...
The hepta filter has a place on each side to push in.The top
comes off and the filter is inside.The new one is about 24.00.
Remember to clean the dust filter .This is located in a chamber
below the cannister . Remove the cannister and there is a grey plastic tab,it will comes up and dust filter is right there-pinch
it and it will peal out.It can be hand washed and air dried.
Parts at TotalVac.com
Is it spraying and sucking up ok? Check the filter inside the dirty water tank, it needs a 1/4 in. gap from the top to the top of the filter. If it isn't spraying out a good stream along the bottom, maybe running a mix of vinegar and water may clean out the lines to help it spray better.
The problem was a clogged heating unit which is located in the lower handle. There are two clear hoses going up the inside of the left leg of the lower handle that go to the heater and to the in-line water switch all within the lower handle. I unplugged the metal heating unit water lines and electrical connections (label the connections as you take them apart if you have a hard time remembering things...there were seven connection in all be it water and/or electrical). Removed the heat unit out and then removed the 6 screws holding the heater cover. Inside was a white powdery pasty debris (lime deposit ?) and the water path was clearly blocked in four different places. I cleansed the water trough with a little water and soft toothbrush and several toothpicks then reassembled. If you need new washers go to Orchard or ACE hardware. Take the old rubber washers(they are red) with you for comparison. I didn't need new washers...I just gently cleansed them. I immediately ran clear water through the machine and actually cleaned the carpet with a water rinse only. Will go back and finish the carpet the right way tomorrow. I had only used my machine three times before this happend over a three year period. A friend told me to always rinse it two maybe three times with clear water after using it and before storage. This took me exactly 42 minutes to disassembly and reassemble. Cost savings is several hundred dollars since I have a 5 bdrm house and would need a professional cleaner to do the small dirty traffic lanes all around the house.
