Question about Medline Industries ~:~ MEDLINE INDUSTRIES, INC. ~:~ Excel 1000 Wheelchair
Wheel locks will not hold. flip off when setting them.
  • jlrbiz Aug 25, 2010
    Tried taking the nut/bolt loose and adjusting the lock by moving it forward and back. It is not too tight no adjustment helps.
    There is a rivet involved that seems to be worn, nothing I can do with it. It sounds like a replacement of the locks is in order.
Click on the link below to order a new lock set for your Excel 1000 wheelchair
http://www.allegromedical.com/wheelchair-accessories-c545.html?gclid=CMHw5oje1qMCFQsEbAod0gg5vA
Posted on Aug 26, 2010
  • 1,675 Answers
Hi, if i remember right, have these got and adjustable nut and bolt that you can undo the nut adjust the bolt then do the nut up again to lock the bolt, if it is, just wind back the bolt a tad a few turns, as it sounds like your locks are adjusted to tight, so if you can just adjust the nut and bolt, if its a bar type configuration, there may be the same sort of thing on that at one end, just do the same, loosen it off, obviously if that still does the same thing, try adjusting it the other way just to see, but it is showing all the signs of being too tight and not to loose hope this helps please rate and vote thanks
Posted on Aug 25, 2010
2000 ford f250, four wheel switch locked in in cab, no front wheel drive, lock in both front wheel hubs and now have 4 wheel drive. Flip off switch inside and no longer in 4 wheel drive.
I really don't know quite how to tell you this. Everything seems to be working just fine buy your question. When your using 4 wheel drive, you engage the hubs first, then push the 4 wheel drive button or turn the switch. Ease it in and out of gear or shift on the move and you should be in 4 wheel drive at this point. To take it out of 4 wheel drive, reverse this procedure. Turn the switch off and ease forward and you will be out of 4 wheel drive. If your not going to use your 4x4, turn the hubs out to reduce ware on the axles. If you will be using 4x4 again soon, leave the hubs in and all you have to do is turn the switch to 4x4 and your set to go. I hope I explained this well enough. Good luck.
Feb 10, 2015 | Ford Cars & Trucks
Wheels locked up
what machine?? Hydraulic trani of not?
Have you flipped it up on the Auger and taken the bottom cover off yet?
Jan 08, 2014 | Troy Bilt 5.5hp Self Propelled Mower
How to load the wire , l have never used one before
On most welders the spool is set up so the wire is pulled from the bottom, goes into a small hole then through the feed wheels and another small hole. There is a lever that you flip to separate the wheels which allows you to feed the wire and once you get the wire started through both holes lock the feed wheels in place and adjust tension so that the wire will slip if it hits something hard (test on a piece of wood).
Apr 12, 2011 | Hobart Handler 140 Mig Welder
How do you set the combination?
Open the lock with the existing combination. Inside the flap, you'll see a small chrome lever. Push the lever to the left (as you're looking into the box) and **** it up into the offset slot. This puts the lock into the "learn" mode. Select your new combination and rotate each wheel until the numbers line up at the opening index. Flip the lever out of the "learn" position, and back into the "home" position.
Test your new combination several times, before closing the door.
Nov 03, 2010 | Master Lock 5400d: Portable Select Access...
How do I fold my jogger (The Twinner II-16). I bought it used without a manual. Can manuals be located on the internet? Thanks
There are 4 pins that need to be pulled. 1st Flip the stroller over and remove the 2 back wheels...sqeeze the metal piece by the wheel and pull the wheel straight out. Pull the 1st 2 pins, they are between the back wheels and the front wheel, on either side. The bars these were holding in place will swing up. Then pull the 2 front pins (by the front wheel) and flip the front tire up. The front wheel also comes off but isn't neccesary.
Sep 15, 2010 | Baby Jogger City Twinner Stroller
Front wheel wont swivel
check for missing bearings in the swivel section
loose or worn shaft
replace the front wheel swivel unit
May 07, 2017 | Phil & Teds E3 Twin Seat Jogger
How do I release the lock on my Craftsman belt sander to lighten the belt. It's an old Model # 315.1172
I checked Searspartsdirect.com for that model number and they listed that number, but with an extra 0 at the right end. I couldn't find a belt release lever illustrated anywhere like that on my old Craftsman belt sander. On mine, you just flipped the lever either forward or back to release and tighten the belt. (still works great) There is a spring that pushes the front roller assembly forward when the lever is operated.
Dec 03, 2009 | Cars & Trucks
The ingnition won't turn and the sterring wheel is not locked. what can i do?
ive had that happen before and usally if you move the steering wheel a little or flip the key over and try again it usally works the steering lock sometimes dosent line up and the key wont turn
Oct 24, 2009 | 2001 Toyota Corolla
80 GB Ipod Classic shows locked and click wheel not working
Slide the switch on the top of the ipod to where it shows white instead of orange. If it is already off hold, then you may have a broken hold switch.
Aug 10, 2009 | Apple iPod MA446LL/A MP3 Player
Disable v-cast key
With the phone closed, hold down the multi-function button on the lower-right side of the phone for a few seconds; that will lock all of the buttons on your phone until you either a) open the phone, or b) hold down the same button for another few seconds to unlock the keys.
To the best of my knowledge, there's no way to set the button to ALWAYS be disabled when closed; you have to lock it every time you close the phone.
NOTE: Locking your keys can create another problem, at least on my phone, where I've disabled the option to anser a call by flipping it open (I prefer the option to view the caller and ignore it if it's not a priority). When I receive a call with the phone locked, I have to wait a few seconds after flipping the phone open before pressing the "answer" key; if I answer too soon after flipping it open, the phone tends to lock up for about 30 seconds, which obviously kills the call.
Apr 07, 2009 | 2007 Toyota Avalon
Medline Industries ~:~ MEDLINE INDUSTRIES, INC. ~:~ Excel 1000 Wheelchair Logo
Top Medline Industries Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Medline Industries Health and Beauty Expert? Answer questions, earn points and help others
