Question about Sharp Office Equipment & Supplies
I have a sharp ux355L document jammed but nothing in it
  • 52 Answers
There is a stack in the machine or one of the paper sensor is broken
Posted on Aug 27, 2010
My SHarp calculator shows a "P E" message and quits working. Can this be shut off so I can use the calculator?
From a Sharp Printing Calculator manual
When the paper jams, the printer stops and the error symbol
"P.E" appears. Turn off the calculator. Tear off the paper tape
and then pull the remaining part of the paper forward and
completely out of the printer
http://www.sharp.se/cps/rde/xbcr/documents/documents/om/30_cal/EL1611P_OM_GB.pdf
Feb 14, 2017 | Sharp Office Equipment & Supplies
Display says line error and print out says jam
• Check the connection. The cord from the TEL.LINE jack to the wall jack should be no longer than
six feet.
• Make sure there are no modem devices sharing the same telephone line.
• Check with the other party to make sure their fax machine is functioning properly.
• Have your telephone line checked for line noise.
• Try connecting the fax machine to a different telephone line.
• If the problem still occurs, your fax machine may need service.
Clearing a jammed document
If the original document doesn't feed properly during transmission or copying,
or DOCUMENT JAMMED appears in the display, first try pressing start/memory . If
the document doesn't feed out, remove it as explained below.
Important:
Do not try to remove a jammed document without releasing it as explained
below. This may damage the feeder mechanism.
Jan 17, 2011 | Sharp UX A255 Plain Paper Thermal transfer...
Ux355l copyer , when i press copy button to make a copy it say press wrong key, can u help me.
I tend to think that you are pressing wrongly. Place the document to be copied facing down on the fax document side and then press COPY/HELP key1 Load the document(s) face down.
(Maximum of 10 pages.)
The display will show:
READY TO SEND
• Set the resolution and/or contrast if RECEPTION
MODE
desired. (The default setting for
copying is SUPER FINE.).
2 Press the COPY/HELP key.
COPY/HELP
COPY MODE
START KEY: SINGLE
COPY KEY: MULTI
? If you are only making one copy of the original (or of each original)
and don't want to make a reduction or enlargement setting, press the
START/MEMORY key twice. Copying will begin.
and want to make an enlargement or reduction setting, press the
START/MEMORY key and go to Step 5.
3 Press the COPY key (MULTI ) if you
want to make multiple copies of each COPY/HELP
original.
ENTER # (01-99)
4 Enter the number of copies per
original (if the number is less than 10, 0 3
enter a "0" before the number).
Example: Three
copies per original
COPY RATIO
Originals
BC
A
MULTI COPY
AA BB CC
A B C
You can get its manual here.
Jan 08, 2011 | Sharp Office Equipment & Supplies
Can not reset machine from Document Jammed mode.
you will have to take this to a service agent as one of the paper sensors has jammed
Apr 09, 2010 | Sharp UX P100 Plain Paper Thermal transfer...
Sharp uxb700 document jammed appears in the message window blinking-cant clear it. no sign of any paper jammed already tried unplugging and clearing memory
If you lift up the panel and look underneath there are two black plastic "levers" one to the right and one to the bottom of the black roller. The larger one on the right was stuck. When I pushed on it and it popped up the "document jammed" message disappeared.
Sep 05, 2008 | Sharp Office Equipment & Supplies
Error Message: Check SPF/RSPF START to Resume
I just fixed this problem on my sharp all in one. The white rollers on the underside of the copier cover were not rolling well. I took an alcohol prep pad and started cleaning them, rolling as I went. A large piece of lint fell out. I put the documents in the document feeder and they fed through like a charm. Hope this helps.
Aug 06, 2008 | Sharp AL-1655CS Copier
I get a "document jammed" message.
1-there is probably a piece of paper on a sensor
2- a sensor is bad
try to locate the sensors and look carefully
there should be no more than three on this model
1-in the paper tray so it knows there is paper in the tray
2-under the drum/toner cartridge and on in the fuser
Jan 24, 2008 | Sharp UX 300 Plain Paper Thermal transfer...
Instructions for Sharp UX355LR
well, i got a copy of this kinf of fax machine.UX355L, not UX355LR, but i think it still works and it would help you.
SharpFax-UX355L.pdf">http://www.hotlinkfiles.com/files/1277341_fohhe/SharpFax-UX355L.pdf">SharpFax-UX355L.pdf
best wishes.
PS: If any problems contact with me.
bertelsman[AT]gmail.com
Jan 10, 2008 | Office Equipment & Supplies
22 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
