Question about Dell Inspiron 6000 Notebook
Error 2000-0334 - Monitor problem how do i remove replace my video card?
  • 2,229 Answers
This is the link to the Dell manual:
http://support.dell.com/support/edocs/systems/ins6000/en/sm/index.htm
Posted on Aug 25, 2010
My monitor says :"No signal" What is the problem?
To help you troubleshoot the monitor 'No Signal' issue, please find the steps given below:
- Turn off your computer.
- Unplug the cable running from your monitor to your PC and plug it back in, making sure the connection is firm. The most common cause of this error is a loose cable.
- Re-attach the cable running from your monitor to your PC. If the monitor is still not displaying a signal after firmly reattaching the cable, the problem could lie with the cable, especially if the cable has visible damage.
- Replace your monitor with another monitor if possible. If the 'No Signal' error still appears, the problem does not rest with the cables or the monitor, but with your PC.
- Open your PC case and locate your video card. Remove the card and then replace it firmly in its slot or, if possible, insert the video card into another slot on your motherboard. A video card that is not making a firm connection will not display images to the monitor. Close your PC case and test the monitor again.
- Replace your video card completely. Your video card may suffer from internal damage that is not allowing it to output a signal.
If issue persists, it is recommended to contact your monitor manufacturer for further assistance.
GuruAid.com
Jun 13, 2016 | AG Neovo SX-17P SX-17P 17" LCD Monitor 3...
Why does my computer say no imput signal
If you have used a desktop computer or have a dual-monitor setup, you have likely seen the "No-input Signal" error message on your computer monitor. The error message may point to a number of culprits. Accordingly, the solutions run from simple to complex. Prior to attempting advanced troubleshooting methods, check the connection first. Power off the computer and the monitor. Remove the cable that connects the monitor with the computer, then reseat it. Try a different port, if possible, then reboot the computer.
Connect the monitor to another computer if possible to eliminate the monitor as the faulty hardware. Shut down the computer. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove all cables and devices plugged into the computer. Make a note of the port into which your monitor is plugged. Remove the left side panel when facing the front of the case. Unscrew screws or manipulate latches to remove the side panel. This process varies according to the type of case you have. Please consult your manual if you are unsure of how to remove the side panel. Attach the antistatic wrist bracelet's clip to a metal object, then ******** the bracelet. Locate your video card. (This will be the card that contains the port with which your monitor interfaces.) Remove the slot cover screw that secures the card into the slot. Remove any power cables that connect the video card to the power supply. Pull the card out of the slot. Examine the gold pins to check for any damage. Reseat the card if it physically appears to be undamaged. You should hear a click once the card is secure in the slot. Screw in the slot cover screw. Attach the power cable from the power supply unit, if applicable. Leave the case open for now. Reconnect only the monitor, power cable and any devices required to boot the computer, then restart the computer. Shut down the computer again if you receive the "No-input Signal" error message again. Remove any cables and devices you plugged in to restart the machine. Remove the video card with a spare or replacement by following the instructions above. Connect necessary cables and devices to reboot the computer, then restart it. Shut down the computer and remove cables and devices if the display still won't work. Unplug the power supply's cables from all devices on the motherboard. Make a note of each plug-in so that you can correctly connect all devices with the new power supply. Remove the screws that mount the power supply. Fit the new power supply into the mounting area, and screw in all screws. Attach all required power cables to devices connected to the motherboard. Attach the cables and devices required to start the computer. Reboot. Hope this helps.
Dec 07, 2012 | Computers & Internet
I put the card on my PC and connect de monitor to the card (VGA). when system boot, the speaker of the board sounds beep, like everything is good, but no video. And yet the card plugging in the board, but...
Hello friend,
Please i think you card is not acceptable by the system, or have you checked another card on the system to see if it displays the same thing. And when you remove the card the system boots normal without any error. So check on the card make a change on it.
Jul 04, 2011 | Creative Labs 3D Blaster 4 Titanium 4200...
I have an MS9158E Mainboard. this computer has been a real workhorse. Today, it did not post on the monitor. Change monitor did not help. Did not post on network either. Do I need a new mother board? or is...
Remove the Power connection. Open the CPU Cabinet, Locate The RAM, remove the RAM by Sliding both Clips, Insert it Back to same Slot or another. Try to boot it again, if still same problem then, Change the Graphics Card with New one. If still have the problem then only Replace the Motherboard. Best of luck
Feb 03, 2011 | Matsonic MS9158E+ Motherboard
Upgraded power supply, upgraded to AMD 965 Quad core, Mother board stops at error C5, monitor blank during this. C5 error says reset video controller. HOW?
try this: 1. turn off the computer 2. disconnect the VGA connector (the cable from the monitor) 3. remove the video card from the motherboard 4. the motherboard has the on board video controller, connect your VGA monitor to that slot. 5. turn on the computer, I hope by now your monitor is ok ;-)
Feb 03, 2011 | Jetway Computers & Internet
I have an HP the monitor doent turn on but all the light are on how can i fix it.
1. unplug the monitor from the computer and check if you can see the monitor selftest (you will see diff color bars moving around) if you see the monitor self test then your monitor is working fine
2. check the cables. use a diff cable to connect your monitor to the computer. use a known good cable.
3. plug in your monitor to diff computer if it worked then you have to reseat your video card
(NOTE : before removing any internal parts from your computer. your pc must be off and the power cable is removed, after removing the power cable press the power button for about 5 secs to remove any electro static discharge)
4. after reseating the video card and still doesnt work remove the video card from the computer. use the onboard video card if you have one.
if it does work then the video card needs to be replaced.
you can also try to reset the memory by removing them and reinstalling them inside the computer
hope this help
Sep 07, 2010 | Computers & Internet
Boot performance monitoring error
>> Tired to reboot several times and still no video.
>> Waited until the next day and the video was working.
>> Very strange.
Sounds like overheating, either inside the monitor, or on the video-card, or inside the computer.
When it happens again, disconnect the data-cable from monitor from the desktop computer, and connect the data-cable to a laptop computer.
If the monitor works, then it's not the monitor that is the problem.
Also, when it happens again, have another monitor, and connect it, to see if the other monitor works, or if the video-card cannot "drive" either monitor.
Apr 05, 2010 | Computers & Internet
Old monitor wont switch on
hi friend,
First, try connecting your monitor to a known good PC, possibly the old laptop you are using now. If the monitor works, the problem is with the video card in your PC. If the monitor does not come on, it is the monitor. It is usually cheaper to purchase a new monitor than to have an old one repaired, unless the monitor is still under warranty.
Try plugging a known good monitor to your PC. If the monitor works, your old monitor is fried and needs to be replaced.
If Your monitor works when connected to another PC, the problem could be your video card. First, then you turn on your PC, do the power supply and case cooling fans run. If they don't, it could be the power supply.
Next, open the computer case. Before you do anything inside, unplug the power.
IMPORTANT!! Touch any metal portion of the computer case to ground yourself to the PC. The slightest static spark can destroy computer circuits.
If the video card is the card type that plugs into a slot on the motherboard, remove the retaining screw or fastener at the top of the card, carefully remove the card, handling the card by the edges as to not disturb the circuits on the card, and re-install the card. Sometimes simply re seating the card corrects the problem.
If that doesn't work, replace the video card with a similar type card. Maybe now is a good time for a video card upgrade.
If the video card is integrated into the motherboard, you can only install a new card into one of the PCI slots on the motherboard. When the PC boots for the first time, go into bios and disable the on board video card. hope this helps u
please rate me..............
thank u for using fixya
regards
sivaranjini
Nov 25, 2009 | Computers & Internet
Error message on Syncmaster- check signal cable
sounds like it might be a graphics card. if u have an old graphics or vidio card, open the case and remove your card then install the old one. if it works now youll know your card is bad. If u have an old video card and an open pci slot install it and move the monitor cable to the old video card plugin. if it works now same thing your graphics card is bad. to know which card to remove just remember which one the monitor is plugged into.
Jul 29, 2009 | Samsung SyncMaster 940B Monitor
My computer doesnt boot
Hi Ashish
There is no problem with ur system board.
Actually you are getting this problem because of Monitor problem.
The possible cause would be:
1. Your data cable connecting your board failed.
2. The display IC of your monitor failed.
3. If you have Video card then remove video card and try connecting data cable to monitor port other than ur video card.
most probably u are dealing this problem due to failure of ur display IC.
Troubleshoot first by connecting other monitor with ur system if available.
gimme ur acknowledge by rating me
Thanx
Romy
Aug 05, 2008 | Computers & Internet
Dell Inspiron 6000 Notebook Logo
147 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
