Question about Asrock 775VM800 Motherboard
How to fix a motherboard that does not turn on at all.
  • Art Ellison
    Art Ellison Aug 25, 2010
    Has it occurred to you that the problem might not be the motherboard? You'll need to tell us a little more about the problem.
  • 3,287 Answers
Make sure there is power at the outlet, surge suppressor, power strip. Be sure any connected UPS is on. Try again.
Remove any recently installed hardware and go for boot. If the PC boots, check to make sure that the new hardware does not overload the old power supply - if it does, replace with a higher capacity power supply and go for boot.
Open the PC. Look for indication of power - LEDs, fan, etc. Replace the power cord between the outlet and computer if one is available, and go for boot.
If possible, obtain a power supply tester to determine if the power supply has failed. Replace any failed Power Supply and go for boot.
Disconnect power. Disconnect all non-required cables and accessories. Leave only the power and data cables for power supply, boot drive, video card, mouse, memory and keyboard connected - everything else should be removed (with the exception of the small cables that go to the MoBo headers for LEDs, and switches on the case). Everything means both data and power cables. All controller cards should be removed as well unless using on-board or built-in controllers. Reconnect power and try for Boot.
Add devices, cables, etc one at a time to determine which is causing the fault. A PC that boots and shuts down shortly after could be an indication of overheating / over load. Clean dirt & dust from case, ventilation slots, etc. Make sure all fans spin freely - replace any that do not.
Those are some things to start working on.. hopefully, you'll find the problem and not have to go further. Good luck!
Posted on Aug 25, 2010
How to fix mainboard when can't turn on
What makes you say that Motherboard needs fixing? If you hear cpu fan working and hard drive turning plus some indicator lights especially one for HDD then Graphics problem most likely, BUT with not clear explanation by you what you mean not you mean not turn on, naturally PC need good working PSU, motherboard to be Ok, Graphics and Memory only to be able to get into BIOS, all other devices can be re-connected later.
Apr 23, 2013 | Epson L200 Original Continuous Ink Tank...
Hi shut down my pc went to turn it on and would not turn on the led on the motherboard is red is that normal
Hi. i had that problem. it happens in many foxconn motherboards. all you have to do is\
---Buy a UPS, otherwise you will have problems.
remove the power cable that comes from POWER SUPPLY to the MOTHERBOARD.
put back the power supply cable to the motherboard.
fix all cables correctly. then you may start the computer.
GOOD LUCK.
Nuno ----- nunex2@yahoo.com
Sep 10, 2010 | Foxconn (945G7MA-8KS2) Motherboard
I turn on the system and the Sony Computer Entertainment screen comes up with some type of graphic design and will not go any further into the menu.
ok my name is Juan I got 3 solutions for you the problem you have is with the VGA chip under the chip there is about a 100 small pins directly connected to the motherboard and one or more of this connections are not making a good contact some ps3's they don't turn on at all some turn on but they freeze right away and here is your 3 solutions
1._ trow your motherboard away
2._ buy another motherboard or ps3 I have motherboards on sale for 70.dls on ebay
3._ send your motherboard to me and I can fix it the only way to fix this problem is to put the motherboard in an special oven controlled by computer the computer will bring the temperature up to the point of melting the joints under the VGA to make any broken connection make contact again this is why the temperature has to be controlled by computer to bring the temperature up to the melting point of the solder and don't cause any other damage t any of the electronics and if you have saved games they will be there after your motherboard gets fix but if you buy another motherboard you will lose all of your games let me know what you think about it
riverajuan@univision.com
Jun 02, 2009 | Sony Playstation 3 (PS3) Console
Turn on ps3 then a couple of seconds later it turns off
this is what is call the red light of dead like in the xbox 360 red rings of dead in the playstation is call green red light of dead this is what had just happen to your console but good news now we do fix this and other major problems but let me tell you that not all motherboard can be fixed like 6 out of 10 can be fixed but you have to send your unit or a least the motherboard with a prepay return label and if you have paypal account and your motherboard can be fixed what we do is that once is fix we send you a bill for 70 dls and you can pay this using your paypal account and sorry but this is the only way to fix the red blinking light
Apr 01, 2009 | Sony Playstation 3 (PS3) Console
My PC won't turn on at all anymore...
The problem is *********** board. If you can not get any signal but you are getting power to your motherboard then the board is not sending power anywhere else. Replace the motherboard and all will be ok
Feb 09, 2009 | Biostar TFORCE4 U 775 Motherboard
When turning on computer it doesn't power on just the power light
check the power supply,batery @ maybe u should by new motherboard
Jan 01, 2009 | Intel Motherboard
When i turn on there is display
Probably power supply or motherboard. Too old to fix really, you might get away with a powersupply but it's hard to tell.
Jan 14, 2008 | ASUS VIA KT133 Chipset A7V133 Motherboard
Asrock 775VM800 Motherboard Logo
125 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
