Question about Ryobi Garden
How hard is it to replace the starter pull cord on a Ryobi 725r gas weed trimmer?
  • 183 Answers
With the proper tools, it is a moderate level project for the DIY mechanic. You will need T15, T20 and T25 torx drivers. 5/8" spark plug socket, Large lip-joint pliers, phillips head screwdriver, 40" of #3.5 rope and about an hour. Start by removing the shaft from the engine. Take pictures as you go. This will make reassenbly easier. The black housing removes next. This will expose the clutch drum. There is a T15 or T20 screw in the middle of the drum. It removes counter-clockwise. Next is the clutch itself. Remove the sparkplug and lower the piston to the bottom of the cylinder. Push as much of the old rop down into the cylinder as you can, then raise the piston up to "lock the cylinder. Now you can use the pliers to turn the clutch counter-clockwise to remove. Don't lose the little washer that is ontop of the clutch, or the thick washer that is under the clutch. Be careful with the clutch, you don't want to damage or misposition the springs on it. They are pretty difficult to reinstall. Next, remove the airbox cover and disconnect the throttle cable. Remove the remaining screws form the tan plastic housing and take it off. Inside this housing is the recoil pulley. Remove the pulley, install the new rope. Wind the rope on the pulley and pass the loose end thru the eye and tie on the handle. To tension the spring, install the pulley and wind more of the rope around the pulley. Reassmble in reverse order. Make sure to get the clutch tight. Failure to tighten the clutch properly can cause major damage.
Posted on Aug 25, 2010
Replacment of starter pull cord
Remove the recoil cap cut the knot of the old cord off pull out the string. Cut a new cord the same length thread it in and knot it . rewind the spool until the cord in the spool. fish the cord out of the pull hole and tie on the pull handle
Aug 04, 2009 | Ryobi Factory Reconditioned 18" 40cc...
How to remove drum connector off ryobi weedeater
I believe there are four phillips headed bolts around the outside edge of the housing
Jul 23, 2009 | Ryobi Garden
I have a Ryobi 725R weed trimmer. It starts and will run on 1/2 choke only. After about 5 minutes it shuts down, like it's out of gas but all fuel lines are full. Help??
Your carburetor is dirty. Disassemble and spray with carb. cleaner. Make sure the small screen is free of debris as well. Use a Den tek Brush, (http://www.dentek.com/shop.php?target=products&product_id=7), to clean the small portals in carb.
If you need further assistance, just let me know.
Jim
Jun 07, 2009 | Ryobi Garden
The pull rope broke on my ryobi 705r/725r gas trimmer. I have all the screws off but it seems to be held on by the center shaft that spins. What do I do now?
I have the same issue of clutch removal on a Ryobi 725r. Actually the clutch finally died after many years of use.
Instead of using a screwdriver to hold the piston I recommend using a piece of clothesline rope. It will be easier on the internal components and won't scratch up the cylinder walls or piston. Just be sure to leave a small amount hanging out of the spark plug hole so you can pull it out afterward.
Apr 15, 2009 | Garden
Replace pull cord on ryobi model cs30 weed wacker
Good fix, mrfixit-jerr! Also, if you remove the rear cover (4 screws) you can stabilize the crankshaft by inserting a screwdriver between the lobe of the shaft and the counterweight.
Apr 03, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 2 cycle gas trimmer 705r/725r
The gas nipple that come out I have...whats goes in the other hole?
Aug 28, 2008 | Ryobi Garden
Ryobi Line trimmer
you have to remove the starter housing, inside will be 2 knobs that spring out when the cord is pulled that contact the flywheel cap of the motor and rotates the crank. check if they are missing or damaged and that they ejecting when the cord is pulled. if not; replace.
Jul 24, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
157 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
