Question about HP LaserJet 2430n Printer
2430N printer This is a work printer. We are getting the black line down the left side of the paper. We were told that they can not send out a tech to fix it. Is there anything that we can do ourselves to fix the problem?
    Problem Solver:
  • 10 Answers
This is usually one of 2 problems either you have a bad toner cartridge (most of the time this is the issue) or you have a bad fuser. if replacing./trying another cart does not fix your problem machine is most likley in need of a fuser.
to replace fuser
remove back cover
Remove the fuser-cable cover by releasing one tab on the cover, and then rotating
the back of the cover toward the center of the printer.
Disconnect two cables at the left, inside, of the printer
Disconnect the fuser cable at the right side of the printer
Remove four screws securing fuser
Tilt the fuser slightly toward the back of the printer, and then slide the fuser out of the back of
the printer.
reverse for reinstall
Posted on Oct 22, 2008
LARGE HORIZONTAL BLACK LINE- PSC 1610 PRINTER COPIES
NO, I DID NOT GET IT FIXED. YOU TOLD ME TO SCAN SOMETHING TO THE PC, WHICH I DID. SENT PAGE TO MICROSOFT WORD AND THE BLACK LINE WAS STILL THERE. I BELIEVE MY SOLUTION IS TO JUNK THIS THING AND BUY ANOTHER.
Jan 28, 2010 | HP PSC 1610 All-In-One InkJet Printer
Lines in printing
...maybe its time to replace fuser fixing film!?
Nov 10, 2009 | HP LaserJet 1020 Printer
My HP LaserJet 2430n prints black smudge lines down the left side of the page. How can I correct this?
check the fusing unit in the rear of the printer and check your print cartridge for smudges.
Sep 28, 2009 | HP LaserJet 2430dtn Printer
HP LaserJet 2430 prints vertical grey bands
It is a bad Toner Cartridge or Fuser. Most likey a bad toner cart.
Mar 07, 2009 | HP LaserJet 2430n Printer
Black line on left side of paper
inside the printer on the paper pulling roller there will be some powder got collected on it due to this a black line appears on the paper.the power faLLS FROM THE TONER WHEN THE WASTE POWDER COLLECTING SECTION IN THE TONER GETS FULL SO IT FALLS on the roller while printing and this happens.take a air blower .bolw in to all the parts of the printer.keep the printer off .remove the toner cartridge.and keep the toner assessing door opened.and then blow the air in the printer.and then check out.
Feb 09, 2009 | HP LaserJet 3055 All-In-One Printer
Black line down my faxes
Open up the document feeder and clean the scanner glass. Look straight down at the bottom inside of the door
Jan 30, 2009 | HP J4680 Office Jet All-In-One Printer
Replacing paper pickup roller
on both sides of pickup rollers there are white bushings rotate the white bushings towards you
Remove the left-side bushing by sliding the bushing to the left.
Slide the roller and shaft toward the left until they clear the hole in the right-side bushing, and
then lift the right end of the shaft.
Slide the roller and shaft toward the right and lift the roller and shaft together out of the printer.
install your new roller then reverse this process to reinstall
Oct 21, 2008 | HP LaserJet 2430n Printer
Black line across top of page - I know there's an easy fix - just don't remember what tech told me
  1. Remove the toner cartridge.
  2. Get a paper towel or cotton swab.
  3. Clean off the glassy part of the toner by turning the gear on the side by hand while wiping the drum surface clean and remove any black lines of toner you see from the cartridge.
Jul 25, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Lines down left side of paper
replace the Black PCU
http://www.websitetoolbox.com/mb/copierquestions
May 15, 2008 | Ricoh Aficio CL2000N Laser Printer
HP LASERJET 2430N
Hi, It seems you could be having a fuser problem if the line is running vertical all the way down. In that case you would have to replace the fuser to correct the problem!
Nov 30, 2007 | HP LaserJet 2430n Printer
HP LaserJet 2430n Printer Logo
103 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
