Question about Nelson Sprinkler: Traveling Tractor
The casing holding the arm has broken. Is this a common part or can I order one?
  • 43,501 Answers
Here is a tip about how to get parts for your traveling lawn sprinkler and also a great article about how traveling lawn sprinklers work.
Traveling Lawn Sprinklers
heatman101
Posted on May 19, 2011
Champion lawn mower Starts but revs flat out
your governor spring may be in the wrong hole. start engine and move governor arm either way. one way should slow engine down. if this is the case then move your spring to a location that will hold arm in that spot. if this is not the case then you may have a broken or damaged flyweight on your governor inside engine
Oct 17, 2014 | Garden
Top rack of dishwasher not getting clean
The most common problem with the top rack not getting clean, is either the middle spray arm is broken and not turning (if equipped) or on some model the pop up spray arm is either clogged with debris and not turning or the pop up part is broken. Make sure to check the spray arm under the top rack, if your has one, to make sure the feed tube is attached all the way from the side to the spray arm part. If part is missing or broken, as this is often the case, you will need to determine which parts are either missing or broken, and replace those parts. If the pop up part is missing or broken, this piece comes usually with the bottom spray arm in an assembly. Your owners manual should be able to direct you further.
Good luck.
Aug 11, 2010 | Dishwashers
Arm on the case broke off
mcdevito75 here, I hope you have a warantee with the watch, even if you don"t contact Luminox watch with this problem, Hold onto that broken piece off the watch. Problem is the case is 1 solid piece, the watch company will want to see the broken case and piece offf the watch, hopefully they might figire a defect in the case cause the piece to break off and replace the case for you for FREE, I doubt it BUT, you never know.
Jun 29, 2010 | Luminox Navy SEAL Dive 3901 Wrist Watch
Replace the rear wiper arm shaft
There is a plastic cover that pops off at the pivot end of the wiper arm. pulling up on this with a hook of some kind from the furthest end should release it. Under it you will find a nut that holds the wiper arm to the shaft. It's quite common for the nut to come loose and the shaft spins without moving the arm. Try tightening this nut (with the ignition on, be sure the wiper motor is off, then turn off ignition and put the wiper arm in the parked position). This is a common problem if you've ever tried to turn on the wiper when it was frozen to the glass.
Feb 26, 2010 | 2000 Honda Odyssey
The wiper arm on my rear window is broken. How
remove the cover at the bootom of wiper arm,there you will see a nut that holds the arm, remove that nut. grab arm and wigle and pull up on it until it comes off, then install new arm in the same position.
Feb 24, 2010 | 2006 Subaru Outback
Screws for ACER PREDATOR front cover linkage
These screws are pretty common. Take one of the screws down to your local hardware store or small electronics store and I'm sure they have replacements.
Dec 23, 2009 | Computers & Internet
The Lower Spin arm comes off during operation
Find a local appliance dealer and order a replacement flange.
Dec 21, 2009 | Frigidaire PLDB998A Built-in Dishwasher
Broken water dispenser arm
I just fixed this today. 01/2/08
First, I got some super glue from Lowes especially designed for plastics.
I first glued some metal strips to the back or the broken off lever, so it will have extra support once glued back. I then applied glue to the broken surface of the lever arm and the support arms I glued earlier.
Super glue it awesome, just had to hold it in place for 1 minute, then let it cure for a few hours... working good as new.
I'm glad this worked for me, as I did not want to have to search for the part and then worry about taking the refrigerator apart.
After repair, I had to educate my wife on how to slam a cup into the arm HEHE.
Dec 10, 2008 | Frigidaire PLHS267ZA Side by Side...
Broken nozzle and upper spray arm
Thanks for the help. Like the other guy said the "ninga star" thing unscrews and using the plastic part inside I just pop the spray arm back on. Screw it back and it works again.
Mar 15, 2008 | Frigidaire GLD2445RF Built-in Dishwasher
How to replace latch arm for omega 1000 juicer?
Getting the old one out is the hardest part if the arm was broken off like mine. First locate the rectangular part where the arm attaches to the case. If the old arm, or most of it, is still attached, grasp it and pull firmly away from the case until you hear a click. Then, still pulling it away from the case, push it up toward the top of the case until it slides out. If the arm is broken off you have to pry it from the top until you hear the click. I used a small paring knife. Once you get it this far, wedge something like a toothpick behind it to keep it pulled away from the case. Then you need to push this push this part up. It is pretty tight so you might want to use some type of tool, like the blade of a flat screwdriver. Once you get the old one out, putting the new on in is just the reverse of taking the old one out.
Dec 11, 2007 | Omega 1000 Juice Extractor
Nelson Sprinkler:  Traveling Tractor Logo
119 people viewed this question
Top Nelson Garden Experts
Dennis
Mike Squire
Phil Walker
Phil Walker
Are you a Nelson Garden Expert? Answer questions, earn points and help others
