How do I get the service manual for the RCA 52W20B? I noticed you have posted small sections of the EW circuit. I am having trouble with pincushion and width. Changed Dl 106, and checked TL120, DL030, DL032 etc.
  • 8,617 Answers
You can get the service manual with schematics from www.servicemanuals.vstore.ca
Posted on Aug 26, 2010
Lg 29 tv horizontal. Pincushion problem
Check all the components at the horizontal out, and vertical out section circuit. Check the transistor/s used at the pincushion circuit.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 20, 2014 | Televison & Video
Sony KP-48S35 Picture
Since this recovers on its own, there are a few possibilities:
1) There are bad connections on the board that self-correct as the unit heats up a bit.
2) There are capacitors in the convergence and pincushion circuits that are starting to fail.
If you can solder, you can repair this yourself. First look for poor solder connections that appear to be grainy or have rings and resolder them. If that fails to resolve the problem, we next have to look for failing capacitors. I will look up the most probable caps in both circuits and post the circuit designations here.
Keep up posted on your progress.
Dan
Jul 14, 2008 | Sony KP-48S35 48" Rear Projection...
Pin problems
I assume that the pincushion problem to your TV, ie, the display have curved vertical lines [X] shape. If so, the pincushion circuit should be troubleshooted. Check the transistor of this stage. Try to download the repair manual to this set. It will have all details. Is it a Sony TV? If so, try this link. http://electronicshelponline.blogspot.com/Pull up older posts.
Dec 26, 2013 | Televison & Video
RCA G35831AT
This is a loss of the "pincushion correction" circuit. These sets are known for bad high voltage capacitors in the horizontal circuit that cause a loss of pincushion correction. It could also be loose solder connections in the horizontal circuit. This can be a dangerous circuit to work with. Have a shop check it for you. Thanks for using fixya.
Jan 11, 2010 | RCA G35831AT 35" TV
Need to locate the pincushion circuit on RCA F32632SB 32" TV
ok this might help rca labels their circuits this way..
0000 tuner
1000 the tv processor
1100 remote receiver
1200 audio IF
1400 a/v hifi outputs
1500 s-video inputs
1700 stereo audio demodulator
1900 audio output
2300 video IF
2400 sync separator
2700 luminance processor
2900 rgb bias and drive
3100 system control
3300 analog interface
3400 front panel assembly
3600 tuner control
4000 ac input
4100 b+ regulator
4200 degauss
4300 horizontal osc.
4400 horizontal output
4500 vert deflection
4600 standby regulator
4700 secondary power supplies
4800 pincushion correction
4900 x-ray protection
5000 kine driver
7500 fm radio
Jan 15, 2009 | RCA F32632SB 32" TV
I need to find the pincushion circuit on my RCA F32632SB TV to check a problem with the TV displaying an hour glass picture. Where can I find a picture of this or a manual to guide me to the circuit?
The pincushion it intimately related to the horizontal circuits,the electron beam must travel farther to reach the corners of the crt and it does to the middle and so without pincushion circuits the raster would be bowed in on the sides on crts 27 inches are larger.Pincushion corrections straightens the raster by modulating the horizontal yoke current at a vertical rate.In an RCA tv the pincushion circuits are usually numbered 4800and the pin amp will probably be numbered 4801,its drive transistor should be Q4802,R4802 will be the width control,and R4805 the e/w pin amplitude. its inputs from the vertical should be Q4801 (subtractor) Q4803 (buffer) you should have a parabola waveform at 4801,yoke current can be modulated here without effecting high voltage.when Q4802 conducts voltage should decrease across Q4801 and the voltage drop across the yoke increases. The east west pin amp control 4805 controls how much of the vertical parabola is input to U4801 to compensate for changes in width caused by variations in beam current.By varying the e/w control resistor you can know if the circuit fault is in the input or output,if the picture varies in size the fault is in the input to U4801,if it does not vary check the output or U4801......hope that helps
Have you ever had this problem?
Sorry Ginko, but a convergence problem would have the curves down from the top and up from the bottom. The hourglass shape is a pincushion problem. This can be as simple as a bad capacitor in the pincushion circuit.
Could you please confirm the model number so I can look up the probable part?
Thanks,
Dan
Jan 08, 2009 | RCA F32632SB 32" TV
Lxi projection television
This is most likely a bad capacitor in the pincushion circuit. The problem is that the service manual for this model is not readily available. I believe that it is similar to RCA models. I'll look up a few RCA types and try to supply you with a few suggestions.
Dan
Jun 19, 2008 | Televison & Video
Philips 27RF70 S125
look for any burnt capacitors in the horizontal sweep circuit. They usually cause the pincushion.
C-Dog
Feb 10, 2008 | Televison & Video
Generally,pincushion may be driven by a chip or IC,but pin out is normally a durable xistor. Servicer adjustments are minor for pin correction.Go to pin out circuit & measure voltages.Get back to me on your findings.
Nov 04, 2006 | RCA 32V430T 32" TV
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
Electro Med Services...
