Head light out on right side on lowbeam right sideout on high beam. No front directionals and left rear directional and brake light out. Problems all started at the same time
    Master:
  • 555 Answers
What is the make and model of your PC Desktop?
Posted on May 05, 2008
Hi,I have an Alfa 2001 156 cigarette lighter not working found some fuses near the battery but not one for the cigarette lighter
Fuse box in passenger compartment Alfa Romeo 156.
fuse box location.
The fuses for the main devices are housed in a control unit under the dashboard, to the left of the steering column. To gain access to them, remove the panel (A) releasing the tabs (B) in the direction of the arrow below and remove the screw (C).
fuse box layout.
1 Ignition auxiliary circuits relay 1 2 Heated rear window relay 3 Horn relay F1 (10A) RH headlamp- high beam F2 (10A) Headlamp high beam warning lamp, LH headlamp-high beam F3 (20A) Boot lid/tailgate lamp, central locking F4 (10A) Headlamp adjustment, RH headlamp-low beam F5 (30A) Electric windows(front) F6 (10A) LH stop lamp, LH tail lamp, RH licence plate lamp, RH rear fog lamp, RH side lamp F7 (10A) LH licence plate lamp, LH rear fog lamp, LH side lamp, RH stop lamp, RH tail lamp F8 (10A) LH head lamp-low beam F9 (15A) Cigarette lighter, heater/air conditioning (AC) F10 (20A) Wind screen wash/wipe system F11 (20A) Horn F12 (10A) Alarm system, anti-lock brake system (ABS)(with ESP), audio system, instrument panel, interior lamps F13 (10A) Anti-lock brake system (ABS), central locking, electric door mirrors, electric windows, glove box lamp, reversing lamps, stop lamp (high level) F14 (10A) Hazard warning lamps F15 (30A) Door mirror heater, heated rear window
Sep 13, 2017 | Alfa Romeo Cars & Trucks
I have a 98 Chevy Malibu My car was hit on the driver side weeks later the headlight stopped working I replaced the whole headlight nd bulbs The auto low or high beams work but only in one head light
You may need to change the wiring harness.
2000 malibu headlight problem - Tech Support Forum
www.techsupportforum.com > ... > Automotive Support
Dec 14, 2008 - 8 posts - ‎2 authors
I have a 2000 chevy malibu with headlight problems. ... High beams work correctly.... I suspect a ground problem but cannot locate the ground cluster. ... Grouped together there, one pink wire to the Headlamp Switch, and one to ... my Wife's car has lowbeam on the left side that just won't work and now the ...
Dec 20, 2015 | Cars & Trucks
I have a 1999 Ford contour lx neither the brake lights nor the turn signals will work what would cause this
a fuse number 24,,,
The following specifications are for the Ford Contour and Mercury Mystique manufactured throughout 1995-2000.
Fuses Rating Color Circuit Engine bay fuse box 1 80 Black Power supply to main fuse box 2 60 Yellow Radiator fan 3 60 Yellow ABS 4 20 Yellow Daytime running lights 5 30 Light green Fog lamp 6 30 Light green Not used 7 30 Light green ABS 8 30 Light green Air pump 9 20 Light bue PCM module 10 20 Light bue Ignition switch 11 3 Violet PCM memory 12 15 Light bue Horn & hazard flasher 13 15 Light bue Oxygen sensor 14 15 Light bue Fuel pump 15 10 Red Right-hand low beam Passenger compartment fuse box 16 10 Red Left-hand low beam 17 10 Red Right-hand high beam 18 10 Red Left-hand high beam 19 7.5 Brown Heated door mirrors 20 10 Black Windshield wipers 21 30 Light green Electric windows 22 7.5 Brown ABS 23 15 Light bue Reverse lights 24 15 Light bue Brake lights 25 20 Yellow Door locks 26 20 Yellow Main light 27 15 Light bue Cigarette lighter 28 30 Light green Power seats 29 30 Light green Heated rear window 30 7.5 Brown Engine management 31 7.5 Brown Instrument pannel lights 32 7.5 Brown Radio 33 7.5 Brown Front and rear sidelights (left) 34 7.5 Brown Interior lighting & clock 35 7.5 Brown Front and rear sidelights (right) 36 30 Light green Air bag 37 30 Light green Heated blower 38 Unused Relays Color Circuit Location Engine bay fuse box R1 Green Daytime running lights (Canada) R2 Black Radiator fan (high speed) R3 Blue AC cut-out R4 Brown AC clutch R5 Dark green Radiator fan (low speed) R6 Yellow Starter R7 Brown Horns R8 Brown Fuel pump R9 White Low beam headlights R10 White High beam headlights R11 Brown PCM power supply Passenger compartment fuse box R12 White Interior and courtesy lights R13 Yellow Heated rear window R14 Yellow Heated blower R15 Green Windshield wiper motor R16 Black Ignition R17 Unused R18 Black One touch window switch Driver's door R19 Blue Cruise control cut-off Central fuse box bracket R20 Unused R21 Unused R22 White Fog lights Interface module bracket R23 Black Turn signals Steering column R24 White Left-hand flasher Door lock module bracket R25 White Right-hand flasher Door lock module bracket R26 Unused Bulbs / Lights Wattage Type Low beam headlamp 55 9006 Halogen High beam headlamp 55 9005 Halogen Parking / Side light 5 2357A Wedge Front turn signal 21 2357A Bayonet Rear turn signal 21 1157 Bayonet Tail light 21 1157 Bayonet Stop light 21 1157 Bayonet High mount stop light 5 2723 Bayonet Fog/Driving light 55 893 Halogen License plate 5 6418 Festoon Reverse light 21 1156 Bayonet Front sidemarker 5 2357A Wedge Glove box Map light 5 64111 Wedge Dome light 10 6411 Feston Step/Courtesy light Trunk/Cargo area Engine compartment 10 89 Wedge Instrument-general Automatic trans indicator
Apr 15, 2015 | 1999 Ford Contour
Lowbeam headlights wont work, brake lights are out and check engine light is on...changed th dimmer switch, no luck
For the low beam problem, Swap relays 45 & 46 in the underhood fuse panel. Relay 46 is for the Low Beams. If that fixes the light, replace the relay that cam out of position 46.
Since the high mounted brake light is working, that indicates that the brake switch is good. You need to check the bulbs in the rear tail light assembly, if they are good, check fuse #34.
Sep 01, 2012 | 2004 Chevrolet TrailBlazer
Translating japanese to english on fuse box
is located under the dashboard on the driver's side. The fuse label is attached under the steering column. If something electrical in your vehicle stops working, check for a blown fuse first. Below table outlines detail fuse number, its ampere and circuits protected. honda-crv-interior-fuse-diagram-thumb.png
No.
Amps
Circuits Protected
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
7.5 15 10 7.5 (15) (20) _ 10 7.5 7.5 10 10 10 7.5 7.5 10 10 20 15 7.5 20 _ _ (20) 20 20 (20) 15 15 20 (15) 20 20 7.5 7.5 10 7.5 30
Power Window Relay Fuel Pump ACG ABS/VSA Heated Seats* Front Fog Lights* Not used Rear Wiper ODS (Occupant Detection System) Meter SRS Right Headlight High Beam Left Headlight High Beam Small Light (Interior) Small Light (Exterior) Right Headlight Low Beam Left Headlight Low Beam Main Headlight High Beam Small Lights MAIN TPMS Headlight Low Beam Not used Not used Moonroof* Door Lock Front Left Power Window HAC Option Rear Accessory Socket Accessory Front Right Power Window Accessory Power Socket on the Center Table* Rear Right Power Window Rear Left power window ACC Radio ACC Key lock HAC Daytime Running Lights Front Wiper
Dec 13, 2010 | 1997 Honda CR-V
I only get highbeams, not lowbeams. Daytime running lights work fine. People at Canadian Tire say it is most likely the relays. I lack the technical know how to know what those look like or where to find...
Power for the headlights goes directly from the battery to the headlight switch, then to the dip/flash switch on the column.
The fact that the high beams are working but not the low beam says the problem is somewhere between the switch on the column and the headlights.
Either the switch has failed, or there's a broken wire or open connector in the wiring harness.
The wiring for the low beams is a blue wire with red tracer. Check the wires coming off the steering column with a voltmeter to see if the problem is with the switch or the wiring forward of the steering column.
If you have power at the connector harness coming off the switch, then keep working forward to find the open circuit.
Jun 04, 2010 | 1993 Nissan NX
My left headlight highbeam light works and the lowbeam don't why
the filament on the low beam burnt out. but the high beam didn't. You have a filament for each. 1 for high beam and 1 for low beam in the same light bulb. You need a new head light.
Sep 07, 2009 | 1998 Ford Windstar
Headlight beam direction
Park the vehicle on a level surface, with the fuel tank about 1 / 2full and with the vehicle empty of all extra cargo (unless normallycarried). The vehicle should be facing a wall which is no less than 6feet (1.8m) high and 12 feet (3.7m) wide. The front of the vehicleshould be about 25 feet from the wall:
  1. If aiming is to be performed outdoors, it is advisable to waituntil dusk in order to properly see the headlight beams on the wall. Ifdone in a garage, darken the area around the wall as much as possibleby closing shades or hanging cloth over the windows.
  2. Turn the headlights ONand mark the wall at the center of each light's low beam, then switchon the brights and mark the center of each light's high beam. A shortlength of masking tape which is visible from the front of the vehiclemay be used. Although marking all four positions is advisable, markingone position from each light should be sufficient.
Fig. The head light alignment adjusters are located on the backof the assembly. Access holes are provided as necessary-2.0L Passat GLSmodel shown
Head lamps are adjusted from above. Do the following:
1. Open the hood
2. Look on top by the head lamps you should see two service holes (oneouter and one inner) where you will see a plastic adjustment screwwhich requires a hexagon wrench or a flathead screw driver that fits. Note the outer alignment screw is the hole located on top eg. driver side head lamps outter being the hole on the right side. innerbeing the alignment screw located in the hole on the left side of thedriver side head lamp assembly.
3. Lateral adjust/ horizontal adust is the right side hole.(which way to turn I've forgotten try incremental trial and error tilyou determine which way is left and which way is moving the beam to theright)
4. Vertical adjust is the adjustment screw located on theleftside of driver side headlamps assembly from above. turn counterclockwise to raise and clockwise to drop. its been awhile so i'm notquite sure .
5. Passenger side lateral and vertical adjust is symetrical. rememberoutter hole from above is lateral adjust and inner hole to the right inthis case for passenger side is vertical adjust.
More details: http://www.ehow.com/how_112704_adjust-headlights.html
Goodluck (remember rated this help).
Sep 04, 2009 | 2002 Volkswagen Passat
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
