SOURCE: heating doesnt work - no hot air in chrysler grand voyager
(check water/ antifreeze level first, make sure it's full, low water can cause it not to heat properly) it could possibly be either the thermostat- fairly cheap and easy to fix, great for DIY's- if that doesn't fix it, it could be heater core.
SOURCE: 2000 Chrysler Town & Country , no heat, blower fan working fine
Probably one of two things. First make sure that your coolant level is full. If the coolant is not flowing properly you won't get heat. If you begin to get heat while driving, but only when you are excelerating, this is your problem. If that is not it you may need to change the thermostat. This is noot hard as long as it is easy to get to and it should be easy.
SOURCE: No heat. Blower works fine. Noticed that the
If the blower is blowing air just fine, but you cannot control the temperature, you need to listen to air coming from the vents while turning the temperature from hot to cold. If you do n ot hear any change in airflow, then you may a temperature door in the dash broken. this is becoming a common problem on the Equinox
Tech JK
SOURCE: our carver 5500 turbo fanmaster
hi looking for a slid control for a carvar 5500 turbo fan master heater
